Does anybody know the tail number of the plane that Bob is using for his tour? Any help would be greatly appreciated.
Looking at the schedule, I’d assume their on a bus???
Thanks for your reply. I have heard several different times that he takes a plane home every night after a show so that he can sleep in his own bed.
I’m guessing he lives nearest Oakland County Airport, so here are some charter aircraft based there; Click Here
So just check under General Aviation - aircraft flying between his home airport FlightAware KPTK , you should be able to figure which aircraft it is if it’s not blocked.
It may actually be more than one aircraft - if it’s a local biz jet company.
He has two planes, both Learjets I believe. Tail numbers are blocked, but yes he flies in right before the show and flies home as soon as possible once it ends.
Thank you for your help. I wasn’t able to find his plane on the site you gave me. It might be blocked. I was able to find this site with a picture of his plane.
myspace.com/lauracreamermusi … 5223084%7D
Can anyone make out the tail number?
I was involved with his 06/07 tour and we used a chartered Lear 55 for Bob Seger and the band used a few different aircraft including a Dornier 328 Jet, Gulfstream G-III, Westwind II and two Lear 35s. I’m pretty sure Seger doesn’t own any aircraft and will charter for his upcoming tour as well. His management team normally uses a broker to arrange the trips. He is a family man and will most likely fly home after every show to meet his family obligations. The band normally stays on the road…
I know you fly home after most shows. Is it weird transitioning back to your home life right after playing a huge concert like this?
A little bit. The big thing is that I just need a lot more rest when I’m home. I do try to go home as much as possible after each show. I’ve got my own plane. I’m very fortunate. I’ve done well in my life, so I’ve got a small jet and I’ll be right out the door at 11 o’clock. I got them up this morning for school at six.
