I installed a better antenna (the FlightAware 1090 one) and elevated it above the roof line. It works GREAT but when I did this I noticed I stopped receiving traffic close to the airport (KROC). I am only about a mile from the airport. I have the FlightAware branded (orange stick) SDR and am running PiAware 3.6.3 on a beaglebone. I can see commercial traffic taking off and landing that never registers. What could be going on?
Chris,
It is possible that the receiver is overloaded. The close in traffic overwhelms the receiver.
You could try lower the gain setting on the dongle (search the forums).
The extra high could also mean that the antenna sees more interference. Do you have an external filter? Sometimes it can help.
Those links might be relevant:
For Beginners - How-to SSH to RPi - Setup Putty in Windows
For Beginners - How to Set / Change Gain
Looking at your excellent stats it doesnāt look like you need a filter.
(Interference would mostly drone out weak, not strong close in signals)
I assumed that anyone with an Amateur Extra licence could search the forums on their own.
Well at least the 3rd link is one you donāt instantly find searching for āgainā.
And in my opinion it is a useful thread, so why wouldnāt i link it?
Anyway iāll stick to receiving radio waves as i have no radio license
(My internet connection over one twisted pair might be radiating quite a bit of radio waves but it seems you donāt need a license for that)
I do have the external filter.
The āstrong signalsā stat says 44% which from what I read sounds too high. The gain is set for -10 (AGC enabled) now. Maybe I need to insert a physical pad inline with the filter.
last5min:
"samples_processed" : 709230592,
"samples_dropped" : 10878976,
Thatās about 1.5% dropped samples, I wonder if a beaglebone black canāt keep up.
AGC does not work correctly for ADS-B signals.
Just use a gain of 42 and try with that.
Interestingly MLAT still seems to working for you.
But optimally there should be no dropped samples.
Still those dropped samples wouldnāt be the reason for only close in planes not being shown.
That is absolutely right. Lower the gain in steps. 38-42 dB should be about right.
What do the rssi figures look like for the close aircraft?
You want them to peak around -3db.
Also, which filter do you have?
i am about 1 nm away from my airport. i also have flights that āgrey outā because of overload on the dongle ( i am using an airspy miniā¦thanks to wiedehopf for the help). i agree that you will have to adjust the gain (this can take a while to experimentā¦use rssi as your guide, not the āgain scriptsā). we are both very close to local airports so must accept that some overload will occur if we wish to receive distant aircraft as well. this is a āgameā of balancing close traffic with maximizing distant targets.
The airspy overloads my RPI 3B+. It is there temporarily
I have to run it on an odroid XU4. The flash card died and I havenāt finished rebuilding it.
There is also a bigger Odroid N1 due out this week.
You may need to drop the gain another setting of two.
Also, native UAT978 support is due within a few weeks. You may want a bigger box if you want to run both(edit: sorry this only applies if you use an airspy).
Yep 40dB seems to be the magic number. Interesting. Iāll have to watch it tomorrow (when there is more traffic) but with a fedex Cessna 206 that just landed, I was able to see it all the way down to touchdown then the full length of the runway.
The only weird thing is that piaware-config wrote the new setting to /etc/piaware.conf and it did not take. Iām testing it by running dump1090-fa manually. I have to figure out why that is - the docs suggest maybe an override file in /boot (but there is not one). So something strange thereā¦
You need to edit /etc/default/dump1090-fa
The piaware setting only works for the piaware sd-card image.
I think the BBB is a little noisy for ADS-B. I havenāt looked at it on a spectrum analyzer, but there is apparently a strong emission on 1 GHz (donāt know how wide). I switched to a RPi-1B.
MobaXterm will tell you the load on the BBB after you SSH in.
The radarcape has a BBB. Maybe they modify it to clean it up.
Wz2b has about 7 times the traffic of gliderp. He may need more than an RPI1B.
I didnāt intend to recommend a 1B. With my traffic, the 1B runs into the 60%-70% load regime, or less. I have a spare 3B, and 3B+, should 978 MHz ever come online and I want to run both frequencies concurrently.
I intended to say that the BBB, and mine is an A6, is noisy. It certainly is in UHF, and Iāve read it is at 1 GHz. JFFT.
73
Thatās why Radarcape and FlightFeeder Blue come in metallic enclosures/boxes. Shielding.
Except the receiver is inside the shielding.
Antenna is what matters, in my experience.
The receiverās 50 ohm input impedance is low enough that will squelch any EM captured at the input.
