any tips for getting the piaware going? not seeing flights!!
setup nooelec TCXO USB, and all is “online”
not seeing anything at all…
If I put the stick (antenna in the same place) into my laptop and run the ADB 1090 program I do get readings which match with nearby flights.
Should I try re imaging the SD card? older / newer version?
I have been running on a pi2
To clarify, you had a PiAware working before with an old dongle and you swapped it for a new one? What is your antenna setup?
i had similar problem in past, when i have changed my antenna voila all works fine, not sure if the same problem for you but if can test other antenna would be better than do a sdcard format
Sent from my SM-N910F using Tapatalk
By the way. I noticed a similar defect with Flightfeeder. Part of an aircrafts can not be seen. I see a plane in the sky, I see the airplane on FR24 map, but it invisible for Flightfeeder.
For example now - These aircraft flew near Flightfeeder’s site
flightradar24.com/RSD74/97c2ea3
flightradar24.com/MOV116/97c2da5
Are you looking on your local interface or FlightAware.com? Have you enabled position-only flights on flightaware.com/account/manage ?
By way about “When this option is activated, you can see additional flights for which FlightAware does not have a filed flight plan”.
Is it possible to hide “flights for which FlightAware does HAVE a filed flight plan”?
Many wrong an aircrafts on FlightAware live map.
It’s very annoying.
No, do you have an example?
For example now -
de.flightaware.com/live/flight/SIA345
drive.google.com/file/d/0B_a0j1 … sp=sharing
And the map after few minutes - drive.google.com/file/d/0B_a0j1 … sp=sharing
other examples
Another ghost aircraft - its usual on the map
A two planes. One of them wrong
And reality on FR24 drive.google.com/file/d/0B_a0j1 … sp=sharing
By the way this is not always - FR24 and FlightAware
