ANA1/ANA2 are 777-300ER flights between NRT and IAD.
ANA1 IAD-NRT shows up on FA as “773”
ANA2 NRT-IAD shows up on FA as “77W”
What is the possible reason for this? Is it because there are different (airline) dispatchers filing the flight plans with different equipment types? The 773 and 77W are fairly consistent on the respective flights (for the last couple of weeks at least).
According to the FAA’s Contractions publication, the official code is B773 so ANA1 is encoded correctly. I did notice that ANA2, with the exception of the past couple of weeks, also had B773.
It’s possible that someone erroneously entered B77W when he meant to enter B773/W and for some reason it stuck. (The /w indicates the aircraft equipment. A complete list is available here.)
Perhaps so. But 77W is also the code normally used for -300ER in airline timetables etc. which is why I thought the 77W was intentional.
What drew my attention to this was a JAL delivery flight from KPAE to RJAA which showed up as a “77W” and while I was looking around to see if I could spot other instances of “77W” I noticed this ANA1/ANA2 anomaly.
77W is the IATA code for the 777-300ER.; similarly 77E for the -200ER and 77L for the -200LR. The person filing the flight plan probably used the code from the reservations system instead of the ICAO code. About a third of B773 flights file as B77W, so it’s not uncommon.
I know these are the codes used by IATA. I was going to mention this in my posting but thought that dispatchers wouldn’t use IATA codes instead of the ICAO codes.
I know. My point was about airlines like ANA filing flight plans using B77W instead of B773 for their 777-300ER flights (and in the case of the IAD flight oddly doing this in only one direction).
Both QR and AF (about whom you asked) still use B773 for their 777-300ER flight plans.
A Boeing 777-300 is usually designated “B773,” but the tag for the All Nippon flight was “B77W,” a new international designation that controllers had not been told about, FAA officials said.
Edited to add: I found this link which indicates that B77L and B77W were officially added by ICAO on 9 April 2008. Since the 77L/77W have about a 4m larger wingspan than the 772/773, it does make a difference for ground controllers whether the aircraft is a 77W or 773.
Air France have now also started using the designator B77W for their -300ER flights.
