A map of a single flight has the origin and destination in the wrong places on a map…
If I look at the area around an airport and zoom out I have denver north of winnipeg…all maps are like this…places are totally transpoded north to south and south to north,
want to include a screen shot…let me try that on my next post.
I’ve been having this problem for a few weeks. Cities are all messed up, no flown route. I have done several ctrl-reloads, updated Java, cleared temp files, cleared everything else. Still not working.
Unfortunately it’s not an option for me to use anything other than IE7 at this time. Do the maps no longer work with IE7??
The maps are tested and work in IE7. It may be an issue with a proxy upstream of you caching the corrupted javascript file that renders the map. Can you paste the contents of Session Diagnostics - FlightAware (minus the session ID - edit that part out)?
Below are the results of the url. As additional info, I have connected to the internet from several different places with the same problems. Below is for a connection from a hotel (I removed the IP address as well):
Your browser is Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; Ant.com 2.1.6 (build 61)(2206F9E5); .NET CLR 2.0.50727; .NET CLR 1.1.4322; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; InfoPath.2; .NET4.0C; .NET4.0E)
You are not using a mobile device
You may be behind a proxy
x_forwarded_for:
Your public IP address is
You are currently logged in.
Your username is mrbeverlin
Your user id is 69895
You can accept cookies from FlightAware
You have successfully logged in to FlightAware with this machine and browser at least one time in the past.
You have never chosen a language (locale).
No default locale detected.
Your region is US US/en_US
Your javascript is working fine.
Time (zulu) is Wednesday, 12-Jan-2011 02:16:40 GMT
Your account can view 4 months of flight history
x_forwarded_for:
I continue to have this problem and I have determined that it is a problem with my laptop only. Other machines on the same network display things correctly.
Is there a way to REALLY refresh Javascript on a machine? I have tried CTRL-F5 and every other combination.
If your maps are broken, please do a view source on a broken page and you’ll see a line at the top like:
… can you copy and paste that URL into your browser and paste the first line? It’ll look like:
/* maplayers.js:8dd4a8fc6 retrieved and parsed as js by emit.rvt for serving host vox.flightaware.com (public hostname via X-Forwarded-Server) by rowdy.hou.flightaware.com (from cache) */
/* maplayers.js:8dd4a8fc6 retrieved and parsed as js by emit.rvt for serving host vox.flightaware.com (public hostname via X-Forwarded-Server) by royce.hou.flightaware.com (from cache)
I’m also having the same problem after upgrading to Windows 7… I also get a messge in the Information bar that says “Content might not be displayed properly. The file was restricted because the content doesn’t match it’s security information.”
And like the original poster says eveything is upside down, and there is no tracking line…
