Hi,
When I try real push notifications, french accents are broken. I receive text like “ADR1218 arrivé à GVA de FRA”.
I have the same issue with the FlightXML Push Notification Testing Interface (AeroAPI Push Notifications - FlightAware ). For the summary “Arrivé à GVA” I receive “Arrivé à GVA”.
The FlightXML request encoding is set as UTF-8 (“content-type: application/json; charset=utf-8”). But I don’t know if it’s right or if text was broken previously.
Regards
dogrock
November 27, 2018, 3:55pm
2
We’re having a look. It looks like there’s a character set conversion error that’s occurring before the alert is sent.
Thank you for your feedback, will it be fixed soon?
Yesterday all alert I recieved had a brocken encoding.
Lufthansa #2386 est arrivé à Int’l de Genève (GVA) à 16:19 CET de Int’l Franz-Josef-Strauss de Munich (MUC) après 0:52 en route Destination (Int’l de Genève / GVA): Terminal 1
What can I do?
Regards
dogrock
December 13, 2018, 11:40pm
5
This bug has not yet been resolved. It’s currently prioritized for development, but I’m unable to provide an estimated time of fix yet.
Are you able to share the raw JSON you receive from the alerts? The messages appear to have correct formatting at the time of send. It looks as if the two byte characters (é: c3 a9) are being treated as a pair of code points (Ã: U+00C3, ©: U+00A9) on decode.
Here a log of last alert with request content and headers
2019-02-17 20:56:15,106 INFO connect.ConFlightXmlController - {"summary":"AFR1042 arrivé à GVA de CDG","long_desc":"Air France #1042 est arrivé à Int'l de Genève (GVA) à 08:55PM CET de Paris-Charles-de-Gaulle (CDG) après 0:43 en route","flight":{"actual_blockin_time":0,"aircrafttype":"A319","estimated_blockout_time":0,"filed_departuretime":1550425200,"origin":"LFPG","filed_ete":"00:56:00","actual_blockout_time":1550429880,"estimatedarrivaltime":1550434083,"filed_altitude":0,"actualdeparturetime":1550430723,"destination":"LSGG","filed_time":1550430901,"faFlightID":"AFR1042-1550211922-airline-0430","filed_blockout_time":0,"ident":"AFR1042","route":"","reg":"FGRHF","estimated_blockin_time":0,"filed_airspeed_kts":265,"actualarrivaltime":1550433358,"filed_blockin_time":0,"filed_arrivaltime":1550428560},"eventcode":"arrival","short_desc":"AFR1042 arrivé à GVA de CDG","alert_id":28701621}
2019-02-17 20:56:15,106 INFO connect.ConFlightXmlController - HEADERS:
2019-02-17 20:56:15,106 INFO connect.ConFlightXmlController - host: app.provatis.com
2019-02-17 20:56:15,106 INFO connect.ConFlightXmlController - user-agent: FlightXML/2.0 (mc_chan_flightxml)
2019-02-17 20:56:15,106 INFO connect.ConFlightXmlController - accept: */*
2019-02-17 20:56:15,106 INFO connect.ConFlightXmlController - content-type: application/json; charset=utf-8
2019-02-17 20:56:15,106 INFO connect.ConFlightXmlController - content-length: 859
2019-02-17 20:56:15,106 INFO connect.ConFlightXmlController - x-forwarded-proto: https
2019-02-17 20:56:15,106 INFO connect.ConFlightXmlController - x-forwarded-for: 216.**.***.***
2019-02-17 20:56:15,106 INFO connect.ConFlightXmlController - connection: close
Normally if content is UTF-8 like it is defined in the request header, my framework should decode correctly the request content but accents are broken
Is this resolved? I get these broken character for German language: Zürich instead of Zürich.
PHP SoapClient FlightXML Push Notifications.
Is there a way to set the proper encoding?
Thanks.
I could resolve it with:
mb_convert_encoding($string, 'Windows-1252', 'UTF-8')
dogrock
September 17, 2019, 7:57pm
10
This is normally the result of running a UTF-8 decode that only handles single byte characters on a string that is already UTF-8 and contains wider characters.
Thank you Airportinfolive! Your work-arround works well for me!
Before I had tried many combinations of encode/decode with ISO-8859-1 but I had not thought of Windows-1252.
