im getting an ajax error on my radar screen and have no idea why?
im using a pi 3 system brought from modmypiwith flightaware softwear loaded onto a sd card,
the system is running the lastest update but yet the error still comes,
i have switched the network from wifi to cable but yet i still get the error.which can be seen below
could anyone point me in the right direction on how to fix thjis please,
if you have installed the gui on your raspi you could see if it works directly on the raspi. as obi already wrote - i saw this behavior only if something with the network went wrong …
if the problem remains i’d suggest you download the flightaware sd-card image here and install it to a different/second empty sd-card and see if that works.
i would like the list to show the pics of the planes instead of flags and a hole lot of other stuff,
i have spent hours on google trying to find out how and so far still cant find an answer, however i have noticed other sites running the same version of the map.
so my qestion would be firstly is this possable?
secound where could i find this sort of map
and most inportantly how could i get this map onto my pi
i am a total noob to all this so sorry for being such a pain,
there is no way to change the map in skyview by just pressing a button. of course with coding skills in javascript/css/html you could alter the map and even layout of flightaware skyview.
most here in the forum use in addition to skyview virtualradarserver - another application to display the aircrafts on a map you find here - but i did not try this up to now: https://www.flightairmap.com
hey here and thank you for your reply
i will check that link out,
are the map files stored on the pi system for the skyview map if i can find the map then i might beable to have a play around with it,
