Any idea why this aircraft is shown twice on my local map?
Screenshot below is taken from ADSBx where it’s visible only once
And it’s not a second aircraft. no other site is showing it that way. Also the RSSI of the “shadow” remain at -49.5 all the time
Edit: After a while, the “shadow” is gone
Anonymous MLAT. (20 characters)
Thank you! (20 characters too)
obj
June 21, 2020, 1:56pm
4
In particular this can happen if you’re receiving a position via UAT or TIS-B, and also via (anonymized) Mode S MLAT.
on my screen above both were registered yellow which should be MLAT. But as i’ve never seen it before, it’s not mission critical. Just curious
You are also getting a non-anonymized MLAT result from somewhere that’s not FA.
Probably should have mentioned that.
So one is an anonymous FA MLAT result, the 2nd is an MLAT result from a differen mlat network you participate in.
Thanks for the explanation. Makes totally sense, i did not think about that.
system
Closed
June 21, 2021, 5:45pm
8
