Question? Can the New pro stick be used on a laptop? If so is just plug and play or is there a download needed?
some different drivers are needed (just to use it a different way than a TV tuner), and yes it there is no Reasoner why it wont work on a laptop
Thanks for the info!
It uses the same RTL2832 USB interface and R820T2 tuner as the Nooelec and RTL-SDR dongles - so the process of using the stick on a laptop is the same as using one of those. Should not be an issue.
