Thanks for the quick response.
With both receivers plugged into the RP;
I gave it a try – your 1<sup>st</sup> command (sudo apt install dump978-fa) seemed to work:
pi@pi:~ $ sudo apt install dump978-fa
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
libairspy0 libboost-atomic1.61.0 libboost-atomic1.62.0 libboost-chrono1.61.0
libboost-chrono1.62.0 libboost-program-options1.61.0 libboost-regex1.61.0
libboost-serialization1.61.0 libboost-test1.61.0 libboost-thread1.61.0
libboost-timer1.61.0 libhackrf0 libhamlib2 liblimesuite16.12-1 librtaudio5a
libsoapysdr0.5-2 libuhd003 limesuite-udev skyaware978 soapysdr-module-rtlsdr
soapysdr0.5-2-module-airspy soapysdr0.5-2-module-all
soapysdr0.5-2-module-audio soapysdr0.5-2-module-bladerf
soapysdr0.5-2-module-hackrf soapysdr0.5-2-module-lms7
soapysdr0.5-2-module-redpitaya soapysdr0.5-2-module-remote
soapysdr0.5-2-module-rtlsdr soapysdr0.5-2-module-uhd
Suggested packages:
gnuradio
The following NEW packages will be installed:
dump978-fa libairspy0 libboost-atomic1.61.0 libboost-atomic1.62.0
libboost-chrono1.61.0 libboost-chrono1.62.0 libboost-program-options1.61.0
libboost-regex1.61.0 libboost-serialization1.61.0 libboost-test1.61.0
libboost-thread1.61.0 libboost-timer1.61.0 libhackrf0 libhamlib2
liblimesuite16.12-1 librtaudio5a libsoapysdr0.5-2 libuhd003 limesuite-udev
skyaware978 soapysdr-module-rtlsdr soapysdr0.5-2-module-airspy
soapysdr0.5-2-module-all soapysdr0.5-2-module-audio
soapysdr0.5-2-module-bladerf soapysdr0.5-2-module-hackrf
soapysdr0.5-2-module-lms7 soapysdr0.5-2-module-redpitaya
soapysdr0.5-2-module-remote soapysdr0.5-2-module-rtlsdr
0 upgraded, 31 newly installed, 0 to remove and 7 not upgraded.
Need to get 5,889 kB of archives.
After this operation, 28.8 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://flightaware.com/adsb/piaware/files/packages stretch/piaware armhf dump978-fa armhf 7.2~bpo9+1 [143 kB]
Get:2 http://flightaware.com/adsb/piaware/files/packages stretch/piaware armhf skyaware978 armhf 7.2~bpo9+1 [2,491 kB]
Get:3 http://mirrors.ocf.berkeley.edu/raspbian/raspbian stretch/main armhf libboost-atomic1.61.0 armhf 1.61.0+dfsg-3 [30.9 kB]
Get:4 http://mirrors.ocf.berkeley.edu/raspbian/raspbian stretch/main armhf libboost-atomic1.62.0 armhf 1.62.0+dfsg-4 [31.1 kB]
Get:5 http://mirrors.ocf.berkeley.edu/raspbian/raspbian stretch/main armhf libboost-chrono1.61.0 armhf 1.61.0+dfsg-3 [35.5 kB]
Get:6 http://mirrors.ocf.berkeley.edu/raspbian/raspbian stretch/main armhf libboost-chrono1.62.0 armhf 1.62.0+dfsg-4 [35.7 kB]
Get:7 http://mirrors.ocf.berkeley.edu/raspbian/raspbian stretch/main armhf libboost-program-options1.61.0 armhf 1.61.0+dfsg-3 [136 kB]
Get:8 http://mirrors.ocf.berkeley.edu/raspbian/raspbian stretch/main armhf libboost-regex1.61.0 armhf 1.61.0+dfsg-3 [233 kB]
Get:9 http://mirrors.ocf.berkeley.edu/raspbian/raspbian stretch/main armhf libboost-serialization1.61.0 armhf 1.61.0+dfsg-3 [105 kB]
Get:10 http://mirrors.ocf.berkeley.edu/raspbian/raspbian stretch/main armhf libboost-timer1.61.0 armhf 1.61.0+dfsg-3 [34.0 kB]
Get:11 http://mirrors.ocf.berkeley.edu/raspbian/raspbian stretch/main armhf libboost-test1.61.0 armhf 1.61.0+dfsg-3 [199 kB]
Get:12 http://mirrors.ocf.berkeley.edu/raspbian/raspbian stretch/main armhf libboost-thread1.61.0 armhf 1.61.0+dfsg-3 [64.4 kB]
Get:13 http://mirrors.ocf.berkeley.edu/raspbian/raspbian stretch/main armhf libhamlib2 armhf 3.0.1-1+b1 [319 kB]
Get:14 http://mirrors.ocf.berkeley.edu/raspbian/raspbian stretch/main armhf liblimesuite16.12-1 armhf 16.12.0+dfsg-1 [189 kB]
Get:15 http://raspbian.phirephly.design/raspbian stretch/main armhf librtaudio5a armhf 4.1.2~ds0-4 [38.3 kB]
Get:16 http://raspbian.phirephly.design/raspbian stretch/main armhf libsoapysdr0.5-2 armhf 0.5.4-1 [56.1 kB]
Get:17 http://raspbian.phirephly.design/raspbian stretch/main armhf libuhd003 armhf 3.9.5-2 [1,414 kB]
Get:18 http://mirrors.ocf.berkeley.edu/raspbian/raspbian stretch/main armhf limesuite-udev all 16.12.0+dfsg-1 [4,042 B]
Get:19 http://raspbian.phirephly.design/raspbian stretch/main armhf soapysdr0.5-2-module-rtlsdr armhf 0.2.2-2 [28.0 kB]
Get:20 http://raspbian.raspberrypi.org/raspbian stretch/main armhf soapysdr-module-rtlsdr armhf 0.2.2-2 [1,052 B]
Get:21 http://raspbian.phirephly.design/raspbian stretch/main armhf libairspy0 armhf 1.0.9-1 [13.9 kB]
Get:22 http://raspbian.phirephly.design/raspbian stretch/main armhf soapysdr0.5-2-module-airspy armhf 0.1.0-1 [20.3 kB]
Get:23 http://raspbian.phirephly.design/raspbian stretch/main armhf soapysdr0.5-2-module-audio armhf 0~git20160607-2 [32.4 kB]
Get:24 http://raspbian.phirephly.design/raspbian stretch/main armhf soapysdr0.5-2-module-bladerf armhf 0.3.2-2 [31.3 kB]
Get:25 http://raspbian.phirephly.design/raspbian stretch/main armhf libhackrf0 armhf 2015.07.2-11 [11.8 kB]
Get:26 http://raspbian.phirephly.design/raspbian stretch/main armhf soapysdr0.5-2-module-hackrf armhf 0.2.2-1 [23.8 kB]
Get:27 http://mirrors.ocf.berkeley.edu/raspbian/raspbian stretch/main armhf soapysdr0.5-2-module-lms7 armhf 16.12.0+dfsg-1 [39.5 kB]
Get:28 http://raspbian.phirephly.design/raspbian stretch/main armhf soapysdr0.5-2-module-redpitaya armhf 0.1.0-1 [15.5 kB]
Get:29 http://raspbian.phirephly.design/raspbian stretch/main armhf soapysdr0.5-2-module-remote armhf 0.3.2-1 [64.0 kB]
Get:30 http://raspbian.phirephly.design/raspbian stretch/main armhf soapysdr0.5-2-module-uhd armhf 0.3.2-1 [42.8 kB]
Get:31 http://raspbian.phirephly.design/raspbian stretch/main armhf soapysdr0.5-2-module-all armhf 0.5.4-1 [6,012 B]
Fetched 5,889 kB in 12s (454 kB/s)
Extracting templates from packages: 100%
Selecting previously unselected package libboost-atomic1.61.0:armhf.
(Reading database ... 136885 files and directories currently installed.)
Preparing to unpack .../00-libboost-atomic1.61.0_1.61.0+dfsg-3_armhf.deb ...
Unpacking libboost-atomic1.61.0:armhf (1.61.0+dfsg-3) ...
Selecting previously unselected package libboost-atomic1.62.0:armhf.
Preparing to unpack .../01-libboost-atomic1.62.0_1.62.0+dfsg-4_armhf.deb ...
Unpacking libboost-atomic1.62.0:armhf (1.62.0+dfsg-4) ...
Selecting previously unselected package libboost-chrono1.61.0:armhf.
Preparing to unpack .../02-libboost-chrono1.61.0_1.61.0+dfsg-3_armhf.deb ...
Unpacking libboost-chrono1.61.0:armhf (1.61.0+dfsg-3) ...
Selecting previously unselected package libboost-chrono1.62.0:armhf.
Preparing to unpack .../03-libboost-chrono1.62.0_1.62.0+dfsg-4_armhf.deb ...
Unpacking libboost-chrono1.62.0:armhf (1.62.0+dfsg-4) ...
Selecting previously unselected package libboost-program-options1.61.0:armhf.
Preparing to unpack .../04-libboost-program-options1.61.0_1.61.0+dfsg-3_armhf.deb ...
Unpacking libboost-program-options1.61.0:armhf (1.61.0+dfsg-3) ...
Selecting previously unselected package libboost-regex1.61.0:armhf.
Preparing to unpack .../05-libboost-regex1.61.0_1.61.0+dfsg-3_armhf.deb ...
Unpacking libboost-regex1.61.0:armhf (1.61.0+dfsg-3) ...
Selecting previously unselected package libboost-serialization1.61.0:armhf.
Preparing to unpack .../06-libboost-serialization1.61.0_1.61.0+dfsg-3_armhf.deb ...
Unpacking libboost-serialization1.61.0:armhf (1.61.0+dfsg-3) ...
Selecting previously unselected package libboost-timer1.61.0:armhf.
Preparing to unpack .../07-libboost-timer1.61.0_1.61.0+dfsg-3_armhf.deb ...
Unpacking libboost-timer1.61.0:armhf (1.61.0+dfsg-3) ...
Selecting previously unselected package libboost-test1.61.0:armhf.
Preparing to unpack .../08-libboost-test1.61.0_1.61.0+dfsg-3_armhf.deb ...
Unpacking libboost-test1.61.0:armhf (1.61.0+dfsg-3) ...
Selecting previously unselected package libboost-thread1.61.0:armhf.
Preparing to unpack .../09-libboost-thread1.61.0_1.61.0+dfsg-3_armhf.deb ...
Unpacking libboost-thread1.61.0:armhf (1.61.0+dfsg-3) ...
Selecting previously unselected package libhamlib2.
Preparing to unpack .../10-libhamlib2_3.0.1-1+b1_armhf.deb ...
Unpacking libhamlib2 (3.0.1-1+b1) ...
Selecting previously unselected package liblimesuite16.12-1:armhf.
Preparing to unpack .../11-liblimesuite16.12-1_16.12.0+dfsg-1_armhf.deb ...
Unpacking liblimesuite16.12-1:armhf (16.12.0+dfsg-1) ...
Selecting previously unselected package librtaudio5a:armhf.
Preparing to unpack .../12-librtaudio5a_4.1.2~ds0-4_armhf.deb ...
Unpacking librtaudio5a:armhf (4.1.2~ds0-4) ...
Selecting previously unselected package libsoapysdr0.5-2:armhf.
Preparing to unpack .../13-libsoapysdr0.5-2_0.5.4-1_armhf.deb ...
Unpacking libsoapysdr0.5-2:armhf (0.5.4-1) ...
Selecting previously unselected package libuhd003:armhf.
Preparing to unpack .../14-libuhd003_3.9.5-2_armhf.deb ...
Unpacking libuhd003:armhf (3.9.5-2) ...
Selecting previously unselected package limesuite-udev.
Preparing to unpack .../15-limesuite-udev_16.12.0+dfsg-1_all.deb ...
Unpacking limesuite-udev (16.12.0+dfsg-1) ...
Selecting previously unselected package soapysdr0.5-2-module-rtlsdr:armhf.
Preparing to unpack .../16-soapysdr0.5-2-module-rtlsdr_0.2.2-2_armhf.deb ...
Unpacking soapysdr0.5-2-module-rtlsdr:armhf (0.2.2-2) ...
Selecting previously unselected package soapysdr-module-rtlsdr:armhf.
Preparing to unpack .../17-soapysdr-module-rtlsdr_0.2.2-2_armhf.deb ...
Unpacking soapysdr-module-rtlsdr:armhf (0.2.2-2) ...
Selecting previously unselected package libairspy0:armhf.
Preparing to unpack .../18-libairspy0_1.0.9-1_armhf.deb ...
Unpacking libairspy0:armhf (1.0.9-1) ...
Selecting previously unselected package soapysdr0.5-2-module-airspy:armhf.
Preparing to unpack .../19-soapysdr0.5-2-module-airspy_0.1.0-1_armhf.deb ...
Unpacking soapysdr0.5-2-module-airspy:armhf (0.1.0-1) ...
Selecting previously unselected package soapysdr0.5-2-module-audio:armhf.
Preparing to unpack .../20-soapysdr0.5-2-module-audio_0~git20160607-2_armhf.deb ...
Unpacking soapysdr0.5-2-module-audio:armhf (0~git20160607-2) ...
Selecting previously unselected package soapysdr0.5-2-module-bladerf:armhf.
Preparing to unpack .../21-soapysdr0.5-2-module-bladerf_0.3.2-2_armhf.deb ...
Unpacking soapysdr0.5-2-module-bladerf:armhf (0.3.2-2) ...
Selecting previously unselected package libhackrf0:armhf.
Preparing to unpack .../22-libhackrf0_2015.07.2-11_armhf.deb ...
Unpacking libhackrf0:armhf (2015.07.2-11) ...
Selecting previously unselected package soapysdr0.5-2-module-hackrf:armhf.
Preparing to unpack .../23-soapysdr0.5-2-module-hackrf_0.2.2-1_armhf.deb ...
Unpacking soapysdr0.5-2-module-hackrf:armhf (0.2.2-1) ...
Selecting previously unselected package soapysdr0.5-2-module-lms7:armhf.
Preparing to unpack .../24-soapysdr0.5-2-module-lms7_16.12.0+dfsg-1_armhf.deb ...
Unpacking soapysdr0.5-2-module-lms7:armhf (16.12.0+dfsg-1) ...
Selecting previously unselected package soapysdr0.5-2-module-redpitaya:armhf.
Preparing to unpack .../25-soapysdr0.5-2-module-redpitaya_0.1.0-1_armhf.deb ...
Unpacking soapysdr0.5-2-module-redpitaya:armhf (0.1.0-1) ...
Selecting previously unselected package soapysdr0.5-2-module-remote:armhf.
Preparing to unpack .../26-soapysdr0.5-2-module-remote_0.3.2-1_armhf.deb ...
Unpacking soapysdr0.5-2-module-remote:armhf (0.3.2-1) ...
Selecting previously unselected package soapysdr0.5-2-module-uhd:armhf.
Preparing to unpack .../27-soapysdr0.5-2-module-uhd_0.3.2-1_armhf.deb ...
Unpacking soapysdr0.5-2-module-uhd:armhf (0.3.2-1) ...
Selecting previously unselected package soapysdr0.5-2-module-all:armhf.
Preparing to unpack .../28-soapysdr0.5-2-module-all_0.5.4-1_armhf.deb ...
Unpacking soapysdr0.5-2-module-all:armhf (0.5.4-1) ...
Selecting previously unselected package dump978-fa.
Preparing to unpack .../29-dump978-fa_7.2~bpo9+1_armhf.deb ...
Unpacking dump978-fa (7.2~bpo9+1) ...
Selecting previously unselected package skyaware978.
Preparing to unpack .../30-skyaware978_7.2~bpo9+1_armhf.deb ...
Unpacking skyaware978 (7.2~bpo9+1) ...
Setting up libairspy0:armhf (1.0.9-1) ...
Setting up libboost-thread1.61.0:armhf (1.61.0+dfsg-3) ...
Setting up libboost-regex1.61.0:armhf (1.61.0+dfsg-3) ...
Setting up libboost-program-options1.61.0:armhf (1.61.0+dfsg-3) ...
Setting up libhamlib2 (3.0.1-1+b1) ...
Setting up libboost-atomic1.61.0:armhf (1.61.0+dfsg-3) ...
Processing triggers for libc-bin (2.24-11+deb9u4) ...
Setting up skyaware978 (7.2~bpo9+1) ...
Enabling lighttpd integration..
Enabling skyaware978: ok
Run "service lighttpd force-reload" to enable changes
Enabling lighttpd integration (stat cache)..
Enabling skyaware978-statcache: ok
Restarting lighttpd..
Created symlink /etc/systemd/system/dump978-fa.service.wants/skyaware978.service ? /lib/systemd/system/skyaware978.service.
Setting up librtaudio5a:armhf (4.1.2~ds0-4) ...
Setting up libboost-atomic1.62.0:armhf (1.62.0+dfsg-4) ...
Setting up libboost-chrono1.61.0:armhf (1.61.0+dfsg-3) ...
Setting up libsoapysdr0.5-2:armhf (0.5.4-1) ...
Setting up libboost-serialization1.61.0:armhf (1.61.0+dfsg-3) ...
Setting up liblimesuite16.12-1:armhf (16.12.0+dfsg-1) ...
Setting up soapysdr0.5-2-module-airspy:armhf (0.1.0-1) ...
Setting up libboost-chrono1.62.0:armhf (1.62.0+dfsg-4) ...
Setting up limesuite-udev (16.12.0+dfsg-1) ...
Setting up libhackrf0:armhf (2015.07.2-11) ...
rmmod: ERROR: Module hackrf is not currently loaded
Setting up soapysdr0.5-2-module-lms7:armhf (16.12.0+dfsg-1) ...
Setting up dump978-fa (7.2~bpo9+1) ...
