PAE is where Boeing builds all dual isle aircraft(747-767-777-787),They have lots of test/shak down flights out of there before delivery to the buyer.
The first time I flew out of PAE I was preflighting and a 747-400 did a V1 abort to full stop then went right back to the other end and did it again in less then 5 min later, that had me going,I ask the tower controller what was going on and he said Boeing just doing testing.
Vso = stall dirty"gear out"(stall is when the Wing quits making lift nothing to do with engines)
NLW= Normal landing weight
VrefFlp30= the speed you would fly final approch with flaps @ 30deg gear out.“LandingConfig”
Vs =would be clean stall “Cruise Config”(no gear or flaps out)
Note It has a very large useful load can hold over 57000 gal(342000lbs) of fuel plus cargo. you dont land with less 5000gal (30000lbs)of fuel!
So if you get it light(no cargo and 60000-70000 lbs of fuel) stall could go way down 10-30% less???(would have to have the books for the exact numbers) so with a little wind(20-30) the 80 Kias could be real if he was out doing slow flight.
