I try to follow the 747-8F test flights with callsigns BOE501, 521 and 522.
During testing from KPAE,KBFI and KMWH almost all flights were normally tracked, except for the touch and go’s, that are difficult to track (why ?)
The flight from KPMD today with the call sign BOE521, however states destination “shots” and wrong aircraft type 747 i.s.o. 748, and the flight suddenly ended above the sea after 20 minutes.
Just a “shot” in the dark here, but any chance it is:
Information on fix SHOTS
Identifier: SHOTS
Navaid radial/DME: NUCr053.00/10
Fix use: Military reporting point
Published: yes
Charts: MILITARY IAP
Nearest city: Avalon (Los Angeles county), CA, USA
Nearest landing site: KNUC - San Clemente Island NALF (10.5 nm away)
It means that the aircraft filed a flight plan to a fix named SHOTS. From there the aircraft will probably be going VFR for a while then return on another flight plan originating at SHOTS or another fix.
BOE521 (second test 747-8 ) was stationed in KPMD. Last recorded flight ending in KPMD at May 18th.
On May 27th suddenly BOE521 has been tracked from KVCV to KVCV.
What happened ?
Also on May 27th and 28th BOE522 (third 747-8 ) was/is scheduled to depart from KVCV, while also being stationed in KPMD. Last flight ending in KPMD at May 26th
