My PiAware unit is active but when I try to view the data the 192.168.1.xxx, everything is showing green with no issues present.
When i ssh into the pi, the status shows everything is working fine and sending data. I have checked my stats page and the unit is live. I also have a couple of other feeders running and they are also receiving/sending data normally.
Any advise is appreciated in resolving this issue.
I guess that your orange pi distro does not install lighttpd by default, or it is set up in a way that does not play nicely with the config fragments that dump1090-fa supplies.
Thanks obj.
Tried to install lighttpd, seems it is already installed.
Now will format the microSD card and will write the older version of Armbian which I have been using successfully, and report the outcome.
pi@orangepipc:~$ sudo apt-get install lighttpd
Reading package lists... Done
Building dependency tree
lighttpd is already the newest version.
lighttpd set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@orangepipc:~$
Edit: This is the current distro installed:
___ ____ _ ____ ____
/ _ \ _ __ __ _ _ __ __ _ ___ | _ \(_) | _ \ / ___|
| | | | '__/ _` | '_ \ / _` |/ _ \ | |_) | | | |_) | |
| |_| | | | (_| | | | | (_| | __/ | __/| | | __/| |___
\___/|_| \__,_|_| |_|\__, |\___| |_| |_| |_| \____|
|___/
Welcome to ARMBIAN 5.25 stable Debian GNU/Linux 8 (jessie) 3.4.113-sun8i
System load: 0.49 Up time: 10 hours
Memory usage: 7 % of 1000Mb IP: 192.168.0.23
CPU temp: 41°C
Usage of /: 16% of 7.2G
Last login: Mon May 1 13:54:41 2017 from 192.168.0.11
pi@orangepipc:~$ uname -a
Linux orangepipc 3.4.113-sun8i #10 SMP PREEMPT Thu Feb 23 19:55:00 CET 2017 armv7l GNU/Linux
pi@orangepipc:~$
May 01 15:42:42 orangepipc lighttpd[909]: Syntax OK
May 01 15:42:43 orangepipc systemd[1]: Started Lighttpd Daemon.
May 01 15:42:43 orangepipc lighttpd[917]: 2017-05-01 15:42:43: (log.c.118) opening errorlog ’ / var / log / lighttpd / error.log’ failed: No such file or directory
May 01 15:42:43 orangepipc systemd[1]: lighttpd.service: main process exited, code=exited, status=255 / n / a
May 01 15:42:43 orangepipc systemd[1]: Unit lighttpd.service entered failed state.
pi@orangepipc:~$
Tried this, no success.
Will now revert to older version which I have been using successfully (Armbian_5.20_Orangepipc_Debian_jessie_3.4.112_desktop)
UPDATE:
Wrote image of older, tested version (Armbian_5.20_Orangepipc_Debian_jessie_3.4.112_desktop)
The “192.168.0.23:8080” and “192.168.0.23/dump1090-fa” work OK.
The “192.168.0.23” and “192.168.0.23:80” bring lighttpd’s Placeholder page, instead of Piaware Radio Status page.
Tried changes shown in red below
After changes and reboot, the “192.168.0.23” and “192.168.0.23:80” started displaying Skyview page with yellow warning box: “Problem fetching data from dump1090”. The “192.168.0.23:8080” and “192.168.0.23/dump1090-fa” still working OK.
I think following will provide the required clarification:
(1) The configuration changes were made only when I reverted to older and tried version of Armbian (Armbian_5.20_Orangepipc_Debian_jessie_3.4.112_desktop).
(2) The reason I made changes to configuration file /etc/lighttpd/lighttpd.conf is that the Piaware Radio Status page was not shown on “192.168.0.23” or “192.168.0.23:80”. Instead lighttpd’s Placeholder page was shown. I was trying to bring the Piaware Radio Status page.
(3) The configuration changes did not affect the pages “192.168.0.23:8080” and “192.168.0.23/dump1090-fa” These worked OK and displayed Skyview page with aeroplanes, both before and after configuration changes.
(4) When I changed the configuration, the Piaware Radio Status page still did not show on “192.168.0.23” or “192.168.0.23:80”. I have therefore removed the configuration changes I made manually in file /etc/lighttpd/lighttpd.conf.
In the older version (Armbian_5.20_Orangepipc_Debian_jessie_3.4.112_desktop), the Skyview map is working OK.
The top-level status page is only present on piaware sdcard installs.
If you want to install it on something else, try installing the piaware-web package (but it will take over the top-level page, and it assumes it is running on a sdcard image, so YMMV)
I am having the same issues. I haven’t done anything custom and it was working on version 3.3. After the upgrade, I am no longer able to see my dump 1090 map. The error message on the browser is “connection refused”
Edit, so I tried updating the packages again. Nothing updated but I was suddenly able to see the map. However, my whole system stopped receiving messages (and the map had the old data warning and was frozen). The restarts from my ads-b page were not fixing this problem. I had to fully halt the device and after plugging everything back in, everything seems normal. So not a smooth update, but we are back in business!
