Applied “Sealwrap” self fusing tape on outdoor antenna in March without electrical tape, and it is showing signs of UV damage. Adding electrical tape now.
I use the Duck brand Wrap-Fix and I’ve never had it degrade over several years of direct sunlight.
They said UV resistant but there must not be a clear definition. Duck wrap has a lot higher temperature limit.
Sealwrap 1 x 15 x 30 mil tape "works from -55 to 176 F and is UV resistant
Duck® Wrap-Fix® UV, chemical and water-resistant for uses ranging from -80 to 500 degrees Fahrenheit
In the instructions of the self-fusing tape they recommend adding the PVC black tape on top of it. 3M gives even the part numbers.
