There’s a few things. This will be more technical and involved than you are hoping!
- The Pro Stick Plus blue FA stick attempts to filter out everything except 1090MHz signals basically. It won’t work for UAT/978MHZ.
- Thus you’ll want 978MHz receiver like the orange FA Pro stick. See here: https://flightaware.com/adsb/prostick/
- Both sticks will need to be plugged into your Pi USB ports.
- Your post reads like you will use one antenna for both, or two antennas? Most of us use a different antenna for 1090MHz and 978MHz, but you might be fine using a splitter Y cable with that antenna to both of your FA sticks. Someone more knowledgeable than I will let you know if there’s a signal strength/loss issue with a splitter, but I assume it would work.
- You’ll need to serialize both FA sticks. → How-to Serialize Dongles for ES1090 + UAT978
If you are using the PiAware RPI image, just go to @abcd567 's post here.
If you installed PiAware (and dump1090-fa and dump978-fa) packages manually, this might help, after you serialize your dongles:
a. Update dump1090-fa and dump978-fa configs, e.g.
sudo nano /etc/default/dump1090-fa
Modify like: RECEIVER_OPTIONS="--device-index 00001090 --gain <your-gain-#-here> --ppm 0""
b. sudo nano /etc/default/dump978-fa
Modify → RECEIVER_OPTIONS="--sdr driver=rtlsdr,serial=00000978 --sdr-gain <your-gain-#-here> --format CS8"
With my package install, I have this in my piaware.conf anyway.
c. sudo nano /etc/piaware.conf
uat-receiver-type sdr # updated by fa_piaware_config
uat-sdr-device driver=rtlsdr,serial=00000978 # updated by fa_piaware_config
