I read many posts, but can’t find the answer to my question.
Figuring out how to connect the “spider” to the FlightAware Pro Stick Plus USB ADS-B Receiver.
I’m going to use the setup in-house.
Is the following correct?
SO-239, with UHF female to connect to
Adapter with UHF Male and SMA Female (showmecables.com/product/SMA … ?link=YMAL)
SMA Cable male/male (1 m)
Pro Stick (has female SMA)
Okay Aldoir, so I’ll change my setup to:
Your N-Connector Female
Adapter N Male - SMA Female
SMA Cable, 2 m, loss 0.59 dB/m, Male - Male
FlightAware Pro Stick Plus (Female SMA)
Yes, it is a good plan.
The 1.2 dB loss in 2 meter coax shows it is a lossy cable, but because of high gain (19 dB) of Pro Stick’s integral rf amplifier, it is ok.
Another option, which requires one adapter less, is:
N Connector panel mount type, female (the one suggested by Aldoir)
Cable 2 meters, N male at Spider end, SMA male at ProStick end.
ProStick (SMA female).
EDIT: Image was not showing, wrong url. Corrected image url.
Yes, looks a good plan. 2M cable is ideal for .66 velocity factor cables (RG58 for example), as it is a perfect multiple of half wave length (275/2*.66*22 = 199,6cm). For different lengths always take this formula into account.
How much cable wavelength affect performance? It can raise a well matched SWR antenna from 1.3:1 to ~3:1, that would mean 25 to 30% of signal loss
Remember you might also need a filter, depending on your region, strong RF signals can saturate your dongle and not allowing it to receive a single aircraft
I have made (tested and compared) several homemade antenna and I find it very helpful, to put a small pigtail on either the cantenna or the spider. It makes switching them around much easier. Cold fingers once messed up a soldered spider. With a pigtail you are connecting a ways from the soldered parts. Good Luck!
