Why does TIS-B flare up sometimes? (UAT/978)
I’m in the USA near a municipal airport. Been toying with UAT reception with a dedicated antenna and SDR. Seeing similar to many other comments here / even with a good filter+LNA, on a good day my feeder will supply 20-30 ADS-B UAT planes to Flight Aware. They tend to be close in, probable due to the lower altitude of GA planes and the terrain around me.
But sometimes, it seems like someone throws a switch and my dump978 screen goes from tracking 0-2 planes to 25 or more.
In that case, many or all are TIS-B … Traffic Information Service, I guess rebroadcasting positions?
Why does it turn on and off like that? It’s rarely present, but then a burst will occur. It is a tower that is only sometimes staffed? FAA uplink that’s used for special circumstances?
It flares up when an aircraft with UAT 978 nears a tower. The tower broadcasts ADS-R traffic information so that the aircraft can “see” them on ADS-B in(if they have it installed).
This site states that traffic information ±5000ft and 15NM radius is provided.
Hi,
Just some additional info you might enjoy.
Those FAA 978 and 1090 rebroadcast towers are sometimes but not always at airports. The one near me about 3 miles away broadcasts on both 1090 and 978. It looks like the typical cell/mobile phone communications tower, and I’m sure they are just leasing space on the tower.
Here is an older, and possibly slightly outdated site with a good list of those sites.
http://towers.stratux.me/
Based on your location near KFDK, Frederick Muni, MD, this is the likely one you are receiving.
Google Maps link to site at KFDK: (Use sat view and StreetView)
39.41148, -77.37093
http://maps.google.com/?q=39.41148,-77.37093
If you use Google Streetview, you can see a great view of the site including:
-Electric transformer outside the fence.
-Electrical boxes inside for AC and backup power.
-Big box at back for electronics and network connections.
-Propane tank in front and backup generator further back.
-Multiple 978 and 1090, and probably others on the tower.
These towers are not especially tall, because they are designed to receive and transmit to aircraft, and not especially ground sites like us. I just barely receive the site 3 miles from my home.
TIS-B and ADS-R is rebroadcast on both 978 and 1090.
The 978 broadcasts can include 1090 traffic, and also 1090 traffic that is mode-a/c only. These aircraft will be identified with a pseudo hex code. Locally, mine start with 290xxx, but that varies by area.
The 1090 broadcasts can include 978 traffic, and also the 1090 mode-a/c only aircraft.
Both can include military 1090 mode-s and even 1090 ads-b that might otherwise be blocked. Some of those “real” military aircraft with real, valid mode-s codes will sometimes be identified with those pseudo hex codes like 2990xxx in my area.
The positions broadcast for the mode-a/c only aircraft are based on FAA radar tracks.
978 broadcasts also include weather and test data like notams which can be decoded. The towers also broadcast their ID and location, which can also be decoded with special software.
Occasionally, you will even see a “double track” when an aircraft is received locally by ads-b, and then you also see a TIS-B FAA radar track for the same aircraft. That sometimes happens when the two tracks have not yet been correlated by the FAA system. The ADS-B track will be perfect, and the FAA radar track will wander a bit since it is based on radar, not GPS.
I did not see any pseudo hex codes in your image, so those are all aircraft with valid mode-s codes.
Regards,
-Dan
Thank you both for those explanations, cool stuff!
And yeah, it’s interesting to see the other stuff on UAT. When I first set it up and wasn’t seeing planes yet I tried uat2text and was happily surprised but the firehose of info dumped :sweat_smile:
I may get back to looking at that again but for now dump978 has dibs on that SDR, haha.
Cool find on Google Street View!
