… hmmm - where to config dump1090-fa manually (piaware sd-card 3.5.0) - any ideas welcome
In Piaware 3.5.0 SD Card image, dont edit the file " / etc / default / dump1090-fa", as it will be overwritten on reboot by piaware-config, and all changes will be lost.
Method (1): Edit file “piaware-config.txt”:
sudo /boot/piaware-config.txt
#After edit, restart dump1090-fa
sudo systemctl restart dump1090-fa
Method (2): Use following command:
sudo piaware-config [property] [value]
Example below:
sudo piaware-config rtlsdr-gain 30
Please see details in “Advanced Cobfiguration” page
http://flightaware.com/adsb/piaware/advanced_configuration
To set location (latitude, longitude), go to settings on your stats page:
http://flightaware.com/adsb/stats/user/TomMuc
thanx abcd,
these files were the first i tried - now tried again on your advice - but it still does not work
/etc/default/dump1090-fa gets overwritten even if i disable piaware in systemd
and i found no way to set dump1090-fa to --net-only mode via piaware-config.txt
found the piaware sd image handy - and want to run dump in net-only mode as aggregator for my home network without running piaware …
any new ideas welcome
tom
p.s. what are the exact differences between dump1090-fa and dump1090-mutability on github at the moment?
Raspbian Jessie Lite image + dump1090-mutability will give you full control on dump1090.
If you like the GUI SkyView, you can change skin only, keeping dump1090-mutability v 1.15~dev. See the Tweak #2 (a) in the thread TWEAKS
hi abcd,
i gave up trying to config dump1090-fa without running piaware in piaware sd-card-image
instead i built a new jessie from scratch with mutability and followed your advice just to copy the dump-fa skyview map.
along your tweak #2 instruction this was done within 2 minutes.
thanks for sharing!
kind regards
tom
If you have installed dump1090-mutability using JProchazka’s automated installed script from “Adsb Receiver Project Scripts”, it will have a small bug, which will display on map, the data and range circles in metric units, even if you have set units as Imperial.
If you want to use Metric units, this bug will not bother you, but if you want nautical miles, you will have to remove this bug.
The method to remove this bug is given as NOTE in item “Tweek-1 (1) INCREASING NUMBER OF RANGE CIRCLES” of thread TWEAKS.
haha - thanx - no - i prefer to install just what i want/need - that’s why i installed it fresh from github on my own
Appreciate this reply is pretty late but searches for problems often bring up old threads.
Running htop I fouund dump1090-fa seemed to be ignoring settings in piaware-config
I found /etc/default/dump1090-fa and altering here worked for me.
Geffers
This thread is for the piaware sd-card, where doing that will not work at all.
The fun of Linux.
Geoff
