I was able to get the new version to work on my B+ using the same card from my B Pi. However I am not able to find the piaware-config.txt file to play with my gain. I am a newbie with linux.
I did a get-apt update and upgrade and updated my dump1090.
if it is a piaware SD card image, cat /boot/piaware-config.txt will confirm location and file contents.
you can change gain with this command sudo piaware-config rtlsdr-gain nn.n.
HTH
evangel
ED1 correction
Use the following commands to set gain and restart dump1090-fa (no need to reboot):
sudo piaware-config rtlsdr-gain 30
sudo systemctl restart dump1090-fa
Basic Info required:
Is it a
- Piaware SD Card Image
OR - Raspbain image with Piaware package install
EDIT:
OK, found from your Flaightaware Stats page:
PiAware (SD Card) 3.6.3
Please follow advises by @evangelyul and @wiedehopf
this is what I got when I tried your suggestion.
sudo piaware-config rtlsdr-gain=49.0
warning: /boot/piaware-config.txt:89: feeder-id overrides a value previously set on line 67
warning: cannot set option ‘rtlsdr-gain=49.0’, it is not a known config option
remember I am a newbie
The = is bogus. Use a space like i wrote it down in the my post above.
apologies the ‘=’ not required !
Thanks that worked. How do I change the freq from 700 to 800?
