What does your setup look like?
i could use some education here, i had thought that the GDT should be outside the building and go to ground prior to the cable entering the building???
Honestly these gas discharge tubes won’t stop lightning really.
They are meant to protect the electronics from static electricity connected to lightning in the area.
I’d expect everything to be fried from a direct lightning strike hit.
Thanks. Hadn’t spotted them until you mentioned the earth cable.
The SDR’s have input protection diodes that will clamp a modest voltage.
GDT’s are great, but also have some drawbacks.
They are (relatively) slow to respond and the “kick in” voltage depends on the gas used. The down side of this is the voltage front may peak to several hundred volts before the arc lights up and clamps the voltage. Even then, the clamp voltage will be 20V which may be enough to blow the protections diodes if they’d survived the original spike.
I thought about the same saying how can this tiny thing protect the devices from a strike.
Now i have my device outside connected to a lightning strike protector to avoid that a strike goes further into the house electricity.
I might loose the Raspberry, but fine with it.
Is evident that those suppressors are only to protect from induced voltage effects of a strike, not a direct hit. Like a strike on the HVAC units close on that roof or a near-by strike.
A direct hit won’t make it fully inside the building, the cable ground itself would be “jumped” trough the insulation to the nearest ground point (like building beams under the roof membrane). Roof membrane can catch fire. Metallic parts thinner than 3-5 mm would be melted (that’s why any HVAC unit needs strike devices).
Residual voltage on the cable would still be in KV range and damage everything downstream. That’s why building lightning protection strike devices and building ground conductors to ground are essential. In US, by code (NFPA780), every building with installed lightning protection has to be provided with SPD’s on power panels and comm cables entering the building. Induced voltages from 25-100 kA strike currents are significant.
The peak values of currents which can be exceeded with 50% probability are: 31 kA for negative lightning (first stroke) and 35 kA for positive lightning. The peak values which can be exceeded with only 5% probability are: 69 kA for negative lightning and 250 kA for positive ones. Generally, as higher object is, the higher the lightning’s current value is.
:+1: :+1: :+1:
A gas discharge device or even a disconnect switch or physical disconnection will not guarantee protection against a direct or close strike. A small air gap of few inches or even few feet, will not stop a lightning bolt that has already jumped across miles of air between cloud and ground.
Thanks for the explanation.
:+1: :+1: :+1:
I experimented with different setups and finalized one in my attic. When I tried to cleanup everything by coiling the coaxial cable, etc. (see attached picture) my positions reported numbers dropped off by about 50%. The number of aircraft reported beyond 50 miles dropped to close to zero. I have since uncoiled the cable and separated things more and then numbers are back up.
Does this make sense to those of you that understand these things?
My guess: Something is not right with the cable connectors or even cable itself. When coiled, you put stress on them and they probably separated, hence the reduction in numbers.
Also, that antenna is supposed to be oriented the other way around, with ground lower than the rest.
You’re putting all the noise generated by the electronics back into the natenna.
You have some coax, just use it to get the power supply / RPi / SDR below / further away from the antenna.
Suspending the antenna by it’s top part and having it just hang down will likely provide better results but that’s not as critical as the other thing.
The cable you are using is RG58.
Ok at lower frequencies, but too lossy for microwaves.
Either replace it entirely or cut it short and re-terminate.
Sharp vision :+1: :slightly_smiling_face:
RG58
I’d say it’s short enough.
Not great, not terrible.
I get what you are saying, but the performance changes if the cable is moved - maybe connectors or perhaps the assemble was poor.
Either way, it needs to be repaired or replaced. If it is to be replaced, I’d go for something better than RG58.
You’re right, but for (very) short lengths it should not be a major issue.
What is very short depends on your installation. I run 1.5m (4.5ft) and it only brings a minimal attenuation (quickly 1dB at worst case, as it is given for 18dB @ 1GHz per 100ft).
Thanks for the reply. I’ll get a new, shorter cable and try that. I knew the antenna needed to be mounted vertically, but didn’t read anywhere that there was a top/bottom issue in the orientation.
I’ll try those suggestions. Thanks.
Thanks. I’ll get something better than RG58; and shorter.
My FA Antenna Indoors, near a window. Suspended by a string tied to top of antenna. Performs very well.
