Had my IP reset last night and now Maps will not load. I went through the stuff saying how to get a API Key. Put it in VRS setup map still does not load.
TypeError: a.getNorthEast(…) is undefined
[Learn More]bundle-93e7ea8d-9bea-4fcb-8fad-f1a7dac50623.js%20line%202%20%3E%20eval:1:13665
Use of getPreventDefault() is deprecated. Use defaultPrevented instead.jquery-1.8.3.min.js:2:40351
"Google Maps API warning: NoApiKeys developers.google.com/maps/docu … o-api-keys"util.js:221:12
Any ideas? IS VRS now pretty much useless to me or am I doing something wrong? I listed the web address as the referr on the setup page, and have tried it with no restriction same response.
The issue with that is that forum compared to this one is dead. They have information posted about how to do it which I’ve followed and done several times to no avail.
I was kinda hoping some one here had same issue and had magic idea.
I had the same issue because I used the custom aviation charts by ProHill. The method by Virtual Radar Server to include the API key only works if you do not have a custom map. You have to add the key directly to the custom-map.js file. To do so, the first line of the code must be modified. The original line is
