Found AirSpy board 1
Board ID Number: 0 (AIRSPY)
Firmware Version: AirSpy NOS v1.0.0-rc10-6-g4008185 2020-05-08
Part ID Number: 0x6906002B 0x00000030
Serial Number: 0x056C68DC2145A09F
Supported sample rates:
10.000000 MSPS
2.500000 MSPS
Close board 1
Is it possible that something is not configured properly for dump1090-fa?
dump1090-fa
Wed Aug 4 16:38:09 2021 CEST dump1090-fa unknown starting up.
Demod Default 2.4 MS/s demodulator:
âdemod-smoother-window: 1 samples
âdemod-preamble-threshold: 3.00db factor: 1.41
âdemod-preamble-strictness: 3
âdemod-preamble-window: 0 samples â 0 samples Width: 0
âdemod-demod-window: 0 samples â 0 samples Width: 0
âdemod-mark-limits: true
âdemod-drop-dup-msgs: false
rtlsdr: no supported devices found.
Yep. Thatâs the next thing to checkâŚ
$ sudo cat /etc/default/dump1090-fa
$ sudo piaware-config
dump1090-fa wonât automatically start unless ENABLED=yes
ENABLED=yes
RECEIVER_OPTIONS=" --airspy-linearity-gain 21
âsample-rate 12 --sample-format u16o12
âdevice-type airspy --airspy-enable-packing"
DECODER_OPTIONS=" --demod hirate --demod-preamble-threshold 0.9
âdemod-smoother-window 1 --demod-msg-window -4:4
âwisdom /etc/dump1090-fa/wisdom.local
âdemod-drop-dup-msgs --max-range 360 --fix"
NET_OPTIONS=" --net --net-heartbeat 60 --net-ro-size 1300
ânet-ro-interval 0.2 --net-ri-port 0
ânet-ro-port 30002 --net-sbs-port 30003
ânet-bi-port 30004,30104 --net-bo-port 30005"
JSON_OPTIONS=ââjson-location-accuracy 2â
PIAWARE_LAT=47.40709
PIAWARE_LON=19.25503
pi@raspberrypi:~ $ sudo piaware-config
allow-auto-updates yes # value set at /etc/piaware.conf:7
allow-manual-updates yes # value set at /etc/piaware.conf:8
manage-config no # value set at /etc/piaware.conf:9
pi@raspberrypi:~ $
That looks correct. One thing I noticed is that the version of dump1090 doesnât look rightâŚ
The version should be âv5.0.5-airspyâ instead of âunknownâ.
How exactly did you install dump1090-fa?
What file you download?
It should have been one of the dump1090-fa zip files from hereâŚ
I followed the description of v.5.0 - where I found something about the installation. Compiled from source.
I thought that it contains the latest version.
Is it enough to deal with dump1090 only (from the release) ?
Now, dump version is ok but still does not start.
pi@raspberrypi:~ $ dump1090-fa
Wed Aug 4 17:11:56 2021 CEST dump1090-fa-airspy v5.0.5-airspy starting up.
I have an extra (standalone) dump fork for SDRPlay - still installed but it is not configured to start at boot. It works through an api.
I hope that it is ok - since I would rather keep it as a spareâŚ
Letâs start by running dump1090-fa manually and see what happensâŚ
$ sudo systemctl stop dump1090-fa
$ /usr/bin/dump1090-fa --device airspy --airspy-linearity-gain 21 --quiet --stats --stats-every 10
Do a ctrl-c after it starts and paste the output.
ThenâŚ
In one Linux terminal, run
$ sudo journalctl -o cat -fu dump1090-fa
In another linux terminal run
$ sudo systemctl restart dump1090-fa
Paste the initial output of the journalctl command.
BTW, itâll be easier to read the pasted output if you use the </> format button at the top of the post message window. You can also enclose the output in three âbackticksâ like soâŚ
Attempt on starting from command line has failed with the same result.
At the end of the text, still ârtlsdr: no supported devices foundâ was shown.
Failed to read wisdom file /etc/dump1090-fa/wisdom.local: Permission denied
dump1090-fa.service: Main process exited, code=exited, status=1/FAILURE
dump1090-fa.service: Failed with result 'exit-code'.
dump1090-fa.service: Service RestartSec=30s expired, scheduling restart.
dump1090-fa.service: Scheduled restart job, restart counter is at 83.
Stopped dump1090 ADS-B receiver (FlightAware customization).
Started dump1090 ADS-B receiver (FlightAware customization).
dump1090-fa.service: Scheduled restart job, restart counter is at 84.
I really appreciate your effort, thank you!
âŚshall I set the privileges to read enabled for everyone for wisdom.local ? If yes, pls help with a command line.
update:
sudo chmod a+r wisdom.local
After restarting dump1090-fa
pi@raspberrypi:~ $ sudo journalctl -o cat -fu dump1090-fa
sample-format : u16o12
lna_gain : -1 (not set)
mixer_gain : -1 (not set)
vga_gain : -1 (not set)
linearity_gain : 21
sensitivity_gain : -1 (not set)
lna_agc : off
mixer_agc : off
packing : on
rf_bias : off
Thank you!!!
Now, another problemâŚ
`AirSpy: FIFO FULL! Dropped 98304 samples. Current Dropped: 98304
I play with "âdemod-smoother-window " to solve itâŚ
Thanks again, have a nice day!
Hello guys,
I noted that a âreniceâ may help if you are at the edge of dropping packets. Instead of changing a performance-sensitive value like ââdemod-smoother-windowâ or another one, you can try to elevate the priority of the process (dump). Not much, just a bit.
sudo renice --5 <PID>
Iâm not sure youâre in the correct thread, if you just want to use your airspy for ADS-B, use airspy_adsb as the decoder and just feed it into the original dump1090-fa.
This effort here is nice but itâs not the most effective way to use your airspy for ADS-B.
These links will get you going with airspy_adsb, the ADS-B decoder written by one of the airspy creators.
GitHub - wiedehopf/airspy-conf: Configure airspy_adsb for use with readsb or piaware.
HOWTO: Airspy mini and Airspy R2: Piaware / dump1090-fa configuration
Thanks for the info.
Update:
You are really right. Airspy_adsb gives an outstanding result.
Thankyou for info
but i'm still getting long piles of info and not the correct info list
I have no idea what this means or what help youâd like.
ive still got wrong info after using
im only getting a very long file
OK but youâve given me absolutely no information other than âitâs brokeâ.
You know the routine.
- Whatâs your current contents of /etc/default/dump1090-fa?
- Whatâs in the very long file?
- What makes you think itâs wrong?
- What were you expecting?
Reply
suffolk3000
9m
ENABLED=yes
#RECEIVER_GAIN=" --airspy-lna-gain 15 --airspy-mixer-gain 15 --airspy-vga-gain 15"
#RECEIVER_GAIN=" --airspy-sensitivity-gain 21"
RECEIVER_GAIN=" --airspy-linearity-gain 21"
#RECEIVER_FORMAT="âsample-rate 10 --sample-format sc16"
RECEIVER_FORMAT="âsample-rate 20 --sample-format u16o12"
RECEIVER_OPTIONS="âdevice-type airspy --airspy-enable-packing ${RECEIVER_GAIN} ${RECEIVER_FORMAT} --stats --stats-every 10"
DEMOD_OPTIONS=" --demod hirate --demod-preamble-threshold 0 --demod-smoother-window 4 --demod-msg-window -7:7 --demod-preamble-strictness 3"
NET_OPTIONS=" --max-range 720 --net --net-heartbeat 60 --net-ro-size 1300
PIAWARE_LAT=52.2475
PIAWARE_LON=0.7103
CPU load: 26.0%
1301 ms for demodulation
933 ms for reading from USB
363 ms for network input and background tasks
Thu Aug 5 23:16:47 2021 BST Caught SIGTERM, shutting downâŚ
Stopping dump1090 ADS-B receiver (FlightAware customization)âŚ
Thu Aug 5 23:16:47 2021 BST Waiting for receive thread termination
Statistics: Thu Aug 5 21:48:15 2021 BST - Thu Aug 5 23:16:47 2021 BST
Local receiver:
106225336320 samples processed
0 samples dropped
0 Mode A/C messages received
29566227 Mode-S message preambles received
19321277 with bad message format or invalid CRC
6378470 with unrecognized ICAO address
152409 suspected duplicate messages
3866480 accepted with correct CRC
-32.3 dBFS noise power
-18.3 dBFS mean signal power
-9.7 dBFS peak signal power
0 messages with signal power above -3dBFS
Messages from network clients:
5001 Mode S messages received
0 with bad message format or invalid CRC
0 duplicate messages
5001 accepted with correct CRC
Decoder:
3871481 total usable messages
169831 DF0 messages
559024 DF4 messages
153846 DF5 messages
1348780 DF11 messages
23756 DF16 messages
619054 DF17 messages
5001 DF18 messages
731828 DF20 messages
260361 DF21 messages
0 surface position messages received
227278 airborne position messages received
223787 global CPR attempts with valid positions
19 global CPR attempts with bad data
9 global CPR attempts that failed the range check
1 global CPR attempts that failed the speed check
275 global CPR attempts with insufficient data
2754 local CPR attempts with valid positions
0 aircraft-relative positions
0 receiver-relative positions
718 local CPR attempts that did not produce useful positions
0 local CPR attempts that failed the range check
29 local CPR attempts that failed the speed check
0 CPR messages that look like transponder failures filtered
0 non-ES altitude messages from ES-equipped aircraft ignored
202 unique aircraft tracks
5 aircraft tracks where only one message was seen
6 aircraft tracks which were not marked reliable
lines above not right but ?? should be this below eg
Demod HiRate:
Successful Message Demod Offsets
Demod window width: 15
Offset Count
-7: 0
-6: 0
-5: 0
-4: 11
-3: 48
-2: 393
-1: 7457
0: 17648
1: 3939
2: 787
3: 217
4: 32
5: 0
6: 0
7: 0
You need to place RECEIVER_OPTIONS after DEMOD_OPTIONS and add ${DEMOD_OPTIONS} to RECEIVER_OPTIONS just before âstats`.
Right now DEMOD_OPTIONS is being ignored because you donât reference it anywhere.
Sorted i would not have spotted that
thankyou GTO
Statistics: Fri Aug 6 00:00:16 2021 BST - Fri Aug 6 00:00:26 2021 BST
Local receiver:
199950336 samples processed
0 samples dropped
459809 Mode-S message preambles received
366861 with bad message format or invalid CRC
86553 with unrecognized ICAO address
263 suspected duplicate messages
6395 accepted with correct CRC
-32.4 dBFS noise power
-17.9 dBFS mean signal power
-10.4 dBFS peak signal power
0 Mode S messages received
Decoder:
6395 total usable messages
264 DF0 messages
1008 DF4 messages
275 DF5 messages
2361 DF11 messages
4 DF16 messages
939 DF17 messages
1141 DF20 messages
403 DF21 messages
344 airborne position messages received
340 global CPR attempts with valid positions
0 global CPR attempts with bad data
0 global CPR attempts that failed the range check
0 global CPR attempts that failed the speed check
0 global CPR attempts with insufficient data
0 local CPR attempts that did not produce useful positions
0 local CPR attempts that failed the speed check
0 unique aircraft tracks
0 aircraft tracks where only one message was seen
0 aircraft tracks which were not marked reliable
Offset Count
-7: 5
-6: 4
-5: 11
-4: 12
-3: 26
-2: 143
-1: 1006
0: 2993
1: 1380
2: 347
3: 182
4: 123
5: 96
6: 52
7: 15
latest list
