Hi All:
I upgraded from the standard SDR USB dongle to the FA SDR USB dongle back early in August. Overnight, the piaware stopped reporting seeing aircraft, and a quick lsusb on the system no longer showed the FA SDR installed. Rebooted, cold and warm, to no avail. Had another Rpi3 so I swapped it; the system came up, albeit briefly, then also didn’t report. lsusb that had previously shown the SDR no longer showed it. Rebooted, and it worked for about 45 seconds, then this ended up in the logs:
48.657905] usb 1-1.3: USB disconnect, device number 4
48.891946] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
48.971958] usb 1-1.3: device descriptor read/64, error -32
49.161949] usb 1-1.3: device descriptor read/64, error -32
49.351948] usb 1-1.3: new full-speed USB device number 6 using dwc_otg
49.431940] usb 1-1.3: device descriptor read/64, error -32
49.621958] usb 1-1.3: device descriptor read/64, error -32
49.811955] usb 1-1.3: new full-speed USB device number 7 using dwc_otg
50.231955] usb 1-1.3: device not accepting address 7, error -32
50.311950] usb 1-1.3: new full-speed USB device number 8 using dwc_otg
50.731961] usb 1-1.3: device not accepting address 8, error -32
50.732067] usb 1-1-port3: unable to enumerate USB device
After than I couldn’t get the radio working again, but i tried the old SDR dongle and it works fine… swapped back to the original Rpi3 and the old dongle works there too.
What could be wrong? Is this a hardware failure? If so, is it still under warranty? It’s only been running for a few months; the older dongle has been running much longer.
Please help!
Best,
jm
