So I’m reading about the upgrade to 6.0, and the grey gear icon, and I see the recent logs (yeah I’m a set it and forget it mostly on these things), and I notice there are several entries of
Started faup978 (pid 21936) to connect to unknown process and
0 msgs recv’d from unknown process; 0 msgs sent to FlightAware and
[2021-09-04 04:35 EDT] ADS-B data program ‘unknown process’ is listening on port 30978, so far so good
[2021-09-04 04:35 EDT] Starting faup978: /usr/lib/piaware/helpers/faup978 --connect localhost:30978
[2021-09-04 04:35 EDT] 1 msgs recv’d from unknown process (0 in last 5m); 0 msgs sent to FlightAware
[2021-09-04 04:35 EDT] 6514783 msgs recv’d from dump1090-fa (86 in last 5m); 6514145 msgs sent to FlightAware
[2021-09-04 04:37 EDT] faup978(20451): connection to [::1]:30978 failed: Connection timed out
[2021-09-04 04:39 EDT] faup978(20451): connection to 127.0.0.1:30978 failed: Connection timed out
[2021-09-04 04:39 EDT] faup978 exited normally
[2021-09-04 04:39 EDT] lost connection to unknown process via faup978
[2021-09-04 04:39 EDT] reconnecting to unknown process
[2021-09-04 04:39 EDT] faup978(20451): Connection failed: Connection timed out
[2021-09-04 04:39 EDT] Starting faup978: /usr/lib/piaware/helpers/faup978 --connect localhost:30978
[2021-09-04 04:39 EDT] faup978(20498): Connecting to localhost:30978
[2021-09-04 04:39 EDT] Started faup978 (pid 20498) to connect to unknown process
[2021-09-04 04:39 EDT] ADS-B data program ‘unknown process’ is listening on port 30978, so far so good
which are all before updating, and then the following afterwards…
[2021-09-04 04:58 EDT] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 206.253.84.195:10234:1122709680
[2021-09-04 04:58 EDT] adept reported location: 35.74998, -80.52060, 880ft AMSL
[2021-09-04 04:58 EDT] mlat-client(21926): Listening for Extended Basestation-format results connection on port 30106
[2021-09-04 04:58 EDT] ADS-B data program ‘unknown process’ is listening on port 30978, so far so good
[2021-09-04 04:58 EDT] mlat-client(21926): Listening for Beast-format results connection on port 30105
[2021-09-04 04:58 EDT] mlat-client(21926): fa-mlat-client 0.2.11 starting up
[2021-09-04 04:58 EDT] Started faup1090 (pid 21933) to connect to dump1090-fa
[2021-09-04 04:58 EDT] mlat-client(21926): Input format changed to BEAST, 12MHz clock
[2021-09-04 04:58 EDT] ADS-B data program ‘dump1090-fa’ is listening on port 30005, so far so good
[2021-09-04 04:58 EDT] mlat-client(21926): Route MTU changed to 1500
[2021-09-04 04:58 EDT] Starting faup978: /usr/lib/piaware/helpers/faup978 --connect localhost:30978
[2021-09-04 04:58 EDT] mlat-client(21926): Using UDP transport to 206.253.84.195 port 10234
[2021-09-04 04:58 EDT] Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 35.750 --lon -80.521
[2021-09-04 04:58 EDT] Started faup978 (pid 21936) to connect to unknown process
[2021-09-04 04:58 EDT] faup978(21936): Connecting to localhost:30978
[2021-09-04 04:58 EDT] mlat-client(21926): Input connected to localhost:30005
[2021-09-04 04:58 EDT] mlat-client(21926): Beast-format results connection with ::1:30104: connection established
[2021-09-04 04:59 EDT] 0 msgs recv’d from unknown process; 0 msgs sent to FlightAware
[2021-09-04 04:59 EDT] 21 msgs recv’d from dump1090-fa; 21 msgs sent to FlightAware
Have two dongles connected, powered by a 12vdc to 5vdc converter off a 10 amp power supply, two antenna’s, and apparently I’ve botched SOMETHING in the config somewhere (as usual)
Any idea (looking at you ABCD567 haha) what/where/how I’ve done wrong?
Thanks for any ideas, I’ll try to reply with whatever info you ask for as quick as I can
Gary
