Timestamps
timestamps from API are not coming in UTC, why and how to fix?
Can you show an example of a server response that you are talking about?
Do mean the error message from databricks or the sample data with inconsistent timestamps?
Both, or anything you feel that is wrong. Your initial report is not actionable without more information.
Hi,
Problem 1)
We generate the report via the attached code, the results we get are 2 files flight track and flight schedule, both attached
We noticed the time in flight track do not match the NMS UTC timestamps, we then found out that there is 4 hours offset from UTC, I need to get the timestamps in plane UTC
Problem 2)
We found some missed data (data gaps) example of one is attached, book7 file has example of the data gaps
Problem 3) to automate the API we would run it on DataBricks, and we got this error message that we are not sure what it means
“HTTPSConnectionPool(host=‘aeroapi.flightaware.com’, port=443): Max retries exceeded with url: /aeroapi/flights/N733KA (Caused by SSLError(SSLEOFError(8, ‘EOF occurred in violation of protocol (_ssl.c:1131)’)))”
Please let me know if you need additional information
Thank you
(Attachment Python.7z is missing)
(Attachment flights_track 25 April 2022.csv is missing)
(Attachment flights_schedule 25 April 2022.csv is missing)
(Attachment Book7.xlsx is missing)
Hi bovineone,
looks like all the samples I sent you as requested got blocked, should I copy and past as content or do you have a site that I can put them there?
You can copy/paste the parts you think relevant. It’s generally unnecessary to include your entire program.
Additionally, all timestamps returned by AeroAPI should already be in ISO8601 format in UTC (timestamps ending in “Z”), so you’re likely doing some interpretation incorrectly. If you’re relying on the output in Excel, then it may be Excel that is mis-handling or mis-displaying it.
I’m not applying any transformation on the data pulled from the API, I use ipynb file
from aero_api import AeroAPI
aero = AeroAPI()
aero.get_flights_schedule()
aero.schedule_df.to_csv('flights_schedule.csv', index = False)
aero.get_flights_tracks()
aero.track_df.to_csv('flights_track.csv', index = False)
to call aero_api.py
from concurrent.futures import ThreadPoolExecutor
import pandas as pd
from tqdm.notebook import tqdm
import requests
class AeroAPI():
    def __init__(self):
        self.tails = ["N733KA","N415LT","9HILI","FHXRG","9HLXX","A6MVD","N604RC","9HILV","9HVJO","9HILZ","9HVFI","9HVJQ","N336EB","9HVJY","9HVJP","N999NB","N455KH","9HILA","A6CBO","9HILY","ANNAPLAB","9HVJS","9HVJR","9HVJT","9HILB","9HVJW","N811TD","9HVJU","9HVJJ","9HVJK","9HVJC","N357VJ","9HVFB","9HVFE","9HVJX","9HVJV","9KGAA","9HVJD","N503VJ","9HVJZ","9HVFC","9HVJG"]
        self.count = 0
        self.tails_idents = {}
        self.idents_flights = {}
        self.schedule_data = []
        self.track_data = []
        self.schedule_df = pd.DataFrame()
        self.track_df = pd.DataFrame()
        self.header = {"x-apikey" : "xxxxxxxxxxxxxxxxx"}
    def get_flight_schedule_of_tail(self, tail):
        self.response = requests.get(f"removedhhtps://aeroapi.flightaware.com/aeroapi/flights/{tail}", headers=self.header)
        df = pd.DataFrame()
        ident = None
        flight = None
        self.count += 1
        if len(self.response.json()["flights"]) > 0:
            ident = self.response.json()["flights"][0]["ident"]
            flight = [flight['fa_flight_id'] for flight in self.response.json()["flights"]]
            df = pd.json_normalize(self.response.json()["flights"])
            df["tail"] = [tail]*len(df)
        output = [tail,ident,flight,df]
        return output
    def get_flights_schedule(self):
        with ThreadPoolExecutor() as executor:
            self.output  = list(tqdm(executor.map(self.get_flight_schedule_of_tail, self.tails), total = len(self.tails)))
        for tail, ident, flight, df in self.output:
            if ident is not None and flight is not None:
                self.tails_idents[tail] = ident
                self.idents_flights[ident] = flight
                self.schedule_data.append(df)
        self.schedule_df = pd.concat(list(self.schedule_data))
    def get_track_of_tail(self, ident_and_flight):
        ident, flight = ident_and_flight
        self.response = requests.get(f"removedhttps://aeroapi.flightaware.com/aeroapi/flights/{flight}/track", headers=self.header)
        df = pd.json_normalize(self.response.json()['positions'])
        df["fa_flight_id"] = [flight]*len(df)
        tail = list(self.tails_idents.keys())[list(self.tails_idents.values()).index(ident)]
        return df
    def get_flights_tracks(self):
        self.idents_and_flights = [(ident,flight) for ident in self.idents_flights for flight in self.idents_flights[ident]]
            self.track_data = list(tqdm(executor.map(self.get_track_of_tail, self.idents_and_flights), total=len(self.idents_and_flights)))
        self.track_df = pd.concat(self.track_data)
        self.track_df = self.track_df.drop_duplicates()
the output is 2 csv files for flight tracking and schedule, here is and example of data gaps we got
Tail fa_flight_id FT_timestamp FA_altitude latitude longitude
N733KA KAI99-1650135201-1-0-227 4/16/2022 18:45 4454.545455 19.74504545 -156.1240591
N733KA KAI99-1650135201-1-0-227 4/16/2022 18:50 15890.90909 20.02273545 -156.0981818
N733KA KAI99-1650135201-1-0-227 4/16/2022 18:55 25945.45455 20.43895273 -155.6439718
N733KA KAI99-1650135201-1-0-227 4/16/2022 19:00 33630 21.056892 -155.36452
N733KA KAI99-1650135201-1-0-227 4/16/2022 19:05 38290 21.619238 -154.966581
N733KA KAI99-1650135201-1-0-227 4/16/2022 19:10 39000 22.200908 -154.541818
N733KA KAI99-1650135201-1-0-227 4/16/2022 19:15 39000 22.76809556 -154.1233811
N733KA KAI99-1650135201-1-0-227 4/16/2022 19:20 39000 23.32852 -153.7059156
N733KA KAI99-1650135201-1-0-227 4/16/2022 19:25 39000 23.86056444 -153.21314
N733KA KAI99-1650135201-1-0-227 4/16/2022 19:30 39000 24.130165 -152.77964
N733KA 4/16/2022 19:35
N733KA 4/16/2022 19:40
N733KA 4/16/2022 19:45
N733KA 4/16/2022 19:50
N733KA 4/16/2022 19:55
N733KA 4/16/2022 20:00
N733KA 4/16/2022 20:05
N733KA 4/16/2022 20:10
N733KA KAI99-1650135201-1-0-227 4/16/2022 20:15 40000 27.23333 -147.21667
N733KA 4/16/2022 20:20
N733KA 4/16/2022 20:25
N733KA 4/16/2022 20:30
N733KA 4/16/2022 20:35
N733KA 4/16/2022 20:40
N733KA 4/16/2022 20:45
N733KA 4/16/2022 20:50
N733KA 4/16/2022 20:55
N733KA 4/16/2022 21:00
N733KA 4/16/2022 21:05
N733KA KAI99-1650135201-1-0-227 4/16/2022 21:10 40000 30.4 -140.7
N733KA 4/16/2022 21:15
N733KA 4/17/2022 21:20
N733KA 4/18/2022 21:25
N733KA 4/19/2022 21:30
N733KA 4/19/2022 21:35
N733KA 4/19/2022 21:40
N733KA 4/19/2022 21:45
N733KA KAI99-1650135201-1-0-227 4/16/2022 21:50 40000 33.28333 -133.61667
N733KA 4/19/2022 21:55
N733KA 4/20/2022 22:00
N733KA 4/20/2022 22:05
N733KA 4/20/2022 22:10
N733KA 4/20/2022 22:15
N733KA 4/20/2022 22:20
N733KA 4/20/2022 22:25
N733KA 4/20/2022 22:30
N733KA KAI99-1650135201-1-0-227 4/16/2022 22:35 40000 35.61496 -126.49993
N733KA KAI99-1650135201-1-0-227 4/16/2022 22:40 40000 35.88499857 -125.7683343
N733KA KAI99-1650135201-1-0-227 4/16/2022 22:45 39500 36.26235 -124.987817
N733KA KAI99-1650135201-1-0-227 4/16/2022 22:50 34130 36.641651 -124.19364
N733KA KAI99-1650135201-1-0-227 4/16/2022 22:55 20970 36.996925 -123.432442
N733KA KAI99-1650135201-1-0-227 4/16/2022 23:00 10109.09091 37.27439364 -122.8249509
N733KA KAI99-1650135201-1-0-227 4/16/2022 23:05 5941.666667 37.49089 -122.39157
N733KA KAI99-1650135201-1-0-227 4/16/2022 23:10 3492.857143 37.62640429 -122.087585
N733KA KAI99-1650135201-1-0-227 4/16/2022 23:15 811.1111111 37.67333333 -122.1719389
notice that Take off 12:46PM HST should be 22:46UTC Landing 8:18PM PDT should be 3:18 UTC
another example is
Tail fa_flight_id FT_timestamp FA FA_altitude latitude longitude
9HILA VJT602-1650071601-ed-0001 4/16/2022 8:30 4330 45.523827 12.439617
9HILA VJT602-1650071601-ed-0001 4/16/2022 8:35 14125 45.46195917 12.28361417
9HILA VJT602-1650071601-ed-0001 4/16/2022 8:40 23600 45.492916 11.605315
9HILA VJT602-1650071601-ed-0001 4/16/2022 8:45 28960 45.713791 10.939166
9HILA VJT602-1650071601-ed-0001 4/16/2022 8:50 31940 45.898973 10.220898
9HILA VJT602-1650071601-ed-0001 4/16/2022 8:55 35672.72727 45.96999364 9.432490909
9HILA VJT602-1650071601-ed-0001 4/16/2022 9:00 36000 46.02909273 8.697575455
9HILA VJT602-1650071601-ed-0001 4/16/2022 9:05 36000 46.146369 7.980882
9HILA VJT602-1650071601-ed-0001 4/16/2022 9:10 36000 46.361198 7.276578
9HILA VJT602-1650071601-ed-0001 4/16/2022 9:15 36000 46.58866818 6.511283636
9HILA VJT602-1650071601-ed-0001 4/16/2022 9:20 36000 46.841586 5.847811
9HILA VJT602-1650071601-ed-0001 4/16/2022 9:25 34991.66667 47.25110083 5.29463
9HILA VJT602-1650071601-ed-0001 4/16/2022 9:30 28910 47.66604 4.736654
9HILA VJT602-1650071601-ed-0001 4/16/2022 9:35 18470 48.061813 4.192474
9HILA VJT602-1650071601-ed-0001 4/16/2022 9:40 10090 48.404715 3.709238
9HILA VJT602-1650071601-ed-0001 4/16/2022 9:45 7000 48.67882091 3.282829091
9HILA VJT602-1650071601-ed-0001 4/16/2022 9:50 5046.153846 48.82995231 2.762904615
9HILA VJT602-1650071601-ed-0001 4/16/2022 9:55 3886.666667 48.850822 2.253849333
9HILA VJT602-1650071601-ed-0001 4/16/2022 10:00 862.5 48.946305 2.35551
that is a flight between Paris and Venice, the difference from UTC take of at 02:32PM and landing at 04:04PM, there is 6 hours difference noted
Hello,
I wanted to inform you that we’ve decided to revoke the AeroAPI api key that you mistakenly included in your code snippet. This is to ensure that there is no unauthorized access to your account. As for the issue you’re experiencing with timestamps: we may be able to provide better support to you via email. You can use the “Contact Us” button at AeroAPI Developer Portal - FlightAware.
-Chris
Hi nasageek,
I actually used the chat and opened a ticket, but they directed me to the discussion board as shown in the email, thank you for catching my error in providing the key on the discussion board, truly appreciated
The reason I provided the code I’m using is the response I got from bovineone, I extract csv not excel files via the API and wanted to make sure that I understand if we are doing anything wrong, or the code needs to be adjusted to provide the correct timestamp values
Thank you
I apologize, I think there was a misunderstanding of the level of support available to you. Email or chat should be an appropriate way to seek support.
Unfortunately, we are unable to support code we didn’t provide to you. To diagnose issues with AeroAPI, we would need to see a JSON response directly from the API. You should be able to gather such a response from the interactive documentation at AeroAPI Developer Portal - FlightAware.
Hello there
Did you fix the Problem 1?
I have the same problem with timestamp
No, still have 4 hours difference, I added manually to my reports until we figure it out
Thank you for your reply. If we come up with something, I’ll ping it here.
