both have again nearly the same output: 260 aircrafts/190 with position/1,300 messages per second
this time pi zero runs on fa sd-card image 3.5.1
terminal now says:
pi@piaware:~$ cat /proc/cpuinfo
processor : 0
model name : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 997.08
Features : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2708
Revision : 9000c1
Serial : 000000009015d1xx
pi@piaware:~$ uname -a
Linux piaware 4.4.50+ #970 Mon Feb 20 19:12:50 GMT 2017 armv6l GNU/Linux
I managed to do this while working. It’s running but I couldn’t get up into the loft easily to set it up there. However, I can tell straight away that it’s rubbish, exactly the same as before.
pi@test-adsb:~ $ uname -a
Linux test-adsb 4.9.35+ #1014 Fri Jun 30 14:34:49 BST 2017 armv6l GNU/Linux
pi@test-adsb:~ $ cat /proc/cpuinfo
processor : 0
BogoMIPS : 997.08
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2835
Revision : 9000c1
Serial : 00000000ea671848
pi@test-adsb:~ $
sorry - but i have no additional ideas - and all what i could test on my side i did and ever got the same result: no difference between zero and pi2 at least at my site …
I tried that previously and it made no difference (removing MLAT)
I don’t like being beaten, I’ll see if I can grab another Zero and test this. I have a dozen Pis dotted around the house so I’ll try and move them around to free one up but that won’t be happening for a couple of weeks as I have a lot going on at the moment.
@abcd567 Thanks but for a basic test, none of those are really needed. I still had the gain figure on record from my last testing so I just used that and all the other stuff there is just for making it look pretty.
Can those having problems try an unmodified piaware sdcard image on a spare sdcard and see if that helps?
I would like to rule out firmware / kernel problems.
this is what i did today - downloaded fa 3.5.1 image → setup wifi+ssh+feederid → swapped one of my two rp2 behind the splitter to a pi zero w with the fresh fa image. result anything was fine and i got the same numbers the pi2 delivers. i asked them to do ‘cat /proc/cpuinfo’ - and what i can see they have the exact pi zero w hardware i have. see above …
edit: wrong! they have BCM2835 while i have BCM2708
but seems to be the same soc - just different naming based on ram. strange - but could this be the reason for different behavior and does this different naming lead to install different kernel modules???
moreover - did you see - that mine - with raspbien stretch image gives different output than with fa-sdcard:
raspbian stretch:
pi@RaspPiZero:~ $ uname -a
Linux RaspPiZero 4.9.41+ #1023 Tue Aug 8 15:47:12 BST 2017 armv6l GNU/Linux
pi@RaspPiZero:~ $ cat /proc/cpuinfo
processor : 0
BogoMIPS : 697.95
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2835
Revision : 9000c1
versus
fa sd-card 3.5.1
processor : 0
BogoMIPS : 997.08
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2708
Revision : 9000c1
I did a quick test using the SD img method and the results seemed a bit better in terms of range (still not quite the same as the RPi3) and the msg rate was about half.
It was only a quick test after work and before I go out overnight. I didn’t even have ssh or xrdp set up.
So, it might be a bit better but still not quite the same it seems.
I really need 2 dongles and a splitter so I can just leave them both running.
second zero w arrived - slightly different soc naming - here is a picture - test within next 30 minutes edit: works again exactly as the pi2/3 - can’t see the slightest downside using zero w
the question was does the zero deliver less range/aircrafts/messages than pi2/3 - so adding these numbers would improve the message of your post instantly
