Hi,
Over the past few months, my PiAware seem to be stuck in a state where the different components stop talking to each other about once a week. Restarting the different services doesn’t fix it, but a reboot always does.
Here are my stats when in this state earlier today:
pi@piaware ~ $ piaware -v
3.5.3
pi@piaware ~ $ dump1090-fa --help
| dump1090 ModeS Receiver dump1090-fa v3.5.3~bpo8+1 |
build options: ENABLE_RTLSDR |
pi@piaware ~ $ sudo piaware-config
allow-auto-updates yes # value set at /boot/piaware-config.txt:5
allow-manual-updates yes # value set at /boot/piaware-config.txt:4
image-type piaware # value set at /boot/piaware-config.txt:6
mlat-results-format “beast,connect,localhost:30104 basestation,listen,12345” # value set at /boot/piaware-config.txt:7
pi@piaware ~ $ piaware-status
PiAware master process (piaware) is running with pid 2284.
PiAware ADS-B client (faup1090) is running with pid 12171.
PiAware mlat client (fa-mlat-client) is running with pid 15661.
Local ADS-B receiver (dump1090-fa) is running with pid 13084.
dump1090-fa (pid 13084) is listening for connections on port 30005.
Your feeder ID is ad723f66-e7fd-43e0-9828-a9aa1a4f2ae8 (from /var/cache/piaware/feeder_id)
I’ve uploaded the whole /var/log/piaware.log to here: Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
Here are some maybe relevant lines:
2017-12-30 01:55:19Z no new messages received in 3766 seconds, it might just be that there haven’t been any aircraft nearby but I’m going to try to restart everything, just in case…
2017-12-30 01:55:20Z faup1090 exited with SIG SIGHUP
2017-12-30 01:55:20Z attempting to restart dump1090…
2017-12-30 01:55:21Z attempting to restart dump1090-fa using ‘invoke-rc.d dump1090-fa restart < /dev/null &’…
2017-12-30 01:55:21Z dump1090 restart appears to have been successful
Stopping dump1090-fa server: dump1090-fa.
2017-12-30 01:55:21Z mlat-client(5702): Lost connection to localhost:30005
2017-12-30 01:55:21Z mlat-client(5702): Reconnecting in 30.0 seconds
2017-12-30 01:55:21Z mlat-client(5702): Beast-format results connection with 127.0.0.1:30104: connection lost
Starting dump1090-fa server: dump1090-fa02017-12-30 01:55:31Z ADS-B data program ‘dump1090-fa’ is listening on port 30005, so far so good
2017-12-30 01:55:31Z Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 47.494 --lon -122.464
2017-12-30 01:55:31Z Started faup1090 (pid 13237) to connect to dump1090-fa
2017-12-30 01:55:51Z 1227805 msgs recv’d from dump1090-fa (0 in last 5m); 1218880 msgs sent to FlightAware
2017-12-30 01:55:51Z mlat-client(5702): Beast-format results connection with ::1:30104: [Errno 97] Address family not supported by protocol
Is this a known problem?
Thanks,
David
PS: This new message board software seems to be a step backwards.
