Some custom SVG plane icons...
Probably a cache issue. CTRL+F5 typically solves it.
I have triangles floating around on mine for “unknown” planes. I have nice 74 & 75 planes tho :slight_smile:
I have been using dump1p90-mutability for a long time, but I am now seriously considering shifting to dump1090-fa. Reason: The plane icons on map of dump1090-mutability have been growing bigger since last some months, and by now some have grown ackwardly big.
The plane icons on dump1090-fa map are decently sized.
[quote=“usafpride”]
Yeah still work in progress, I have them so big so I notice them and add them to DB.
Might want to pick and choose what you use in that file at the moment!
It is easy to build your own up to date DB based on local stuff, I have done that here in Auckland New Zealand and now only get 1 or 2 triangles a day.
Not sure if that file will work with mutability, haven’t tested it. Was more an example of how stuff is coded rather than a drop and replace… Individual mileage may vary on that approach!
Looks to have the same file structure as Dump1090, but its not working
Bugger all, wish OBJ would drop by and tell me what I buggered :slight_smile:.
Fire it up in a new browser in private mode (incognito in Chrome, you might want to change the default icon though, I use a triangle as they stand out when something is missing from my DB. Just refreshed the link above with the new markers.js, more tweaks, and the new Airbuses that I will be posting here shortly.
Well I’ve lost all my icons. I have not used your new one, but refreshed and it’s all gone
Anyone out there have a copy I can use?
https://dl.dropboxusercontent.com/u/50785283/markers.js.bak
Here you go, remove the .bak from it though before uploading.
New Airbus O’clock, sorted some scale issues I had, figured out the A340 variants properly this time and got better images of plans to work off.
Here we go:
//A320 Series
//A320 - Scale 0.67 Meters/point
https://dl.dropboxusercontent.com/u/50785283/A320.png
var _a320 = {
key: “a320”,
scale: 0.67,
anchor: [32, 32],
path: “m 32,1.8 0.5,0.1 0.5,0.4 0.7,1.1 0.6,1.4 0.4,1.3 0.2,1.4 0.1,1.2 0,10.9 0.6,1.8 3.7,2 -0.2,-1.8 0,-1.4 0.1,-1.3 0.2,-0.3 2.8,0 0.2,0.3 0.1,1.3 0,1.4 -0.2,2.2 -0.5,0 -0.1,0.8 14.8,7.7 1,0.7 0.4,0.5 0.1,0.5 0.1,2.6 -0.2,-0.1 -0.1,-0.3 0,-0.9 -7,-2.2 -0.1,0.7 -0.2,0.6 -0.2,-0.6 -0.1,-0.9 -5.3,-1.7 -0.1,0.7 -0.2,0.6 -0.2,-0.6 -0.1,-0.9 -2.4,-0.7 -0.6,0 -0.1,0.6 -0.2,0.3 -0.2,-0.3 -0.1,-0.6 -0.8,0 -0.1,0.8 -0.2,0.5 -0.2,-0.5 -0.1,-0.8 -4.3,0 0,11.6 -0.2,2.9 -0.2,2 -0.2,1.7 -0.2,1.2 0.1,0.4 0.4,0.4 6.8,4.8 0.4,0.5 0.1,0.4 0,1.4 -8.9,-2 -0.4,2.4 -0.1,0.2 -0.2,0.2 -0.3,0.1 -0.2,0 -0.3,-0.1 -0.2,-0.2 -0.1,-0.2 -0.4,-2.4 -8.9,2 0,-1.4 0.1,-0.4 0.4,-0.5 6.8,-4.8 0.4,-0.4 0.1,-0.4 -0.2,-1.2 -0.2,-1.7 -0.2,-2 -0.2,-2.9 0,-11.6 -4.3,0 -0.1,0.8 -0.2,0.5 -0.2,-0.5 -0.1,-0.8 -0.8,0 -0.1,0.6 -0.2,0.3 -0.2,-0.3 -0.1,-0.6 -0.6,0 -2.4,0.7 -0.1,0.9 -0.2,0.6 -0.2,-0.6 -0.1,-0.7 -5.3,1.7 -0.1,0.9 -0.2,0.6 -0.2,-0.6 -0.1,-0.7 -7,2.2 0,0.9 L 6.1,36.5 5.9,36.6 6,34 6.1,33.5 6.5,33 l 1,-0.7 14.8,-7.7 -0.1,-0.8 -0.5,0 -0.2,-2.2 0,-1.4 0.1,-1.3 0.2,-0.3 2.8,0 0.2,0.3 0.1,1.3 0,1.4 -0.2,1.8 3.7,-2 L 29,19.6 29,8.7 29.1,7.5 29.3,6.1 29.7,4.8 30.3,3.4 31,2.3 31.5,1.9 z”
**//A330 Series
//A330-200 - Scale 1.16 Meters/point **
https://dl.dropboxusercontent.com/u/50785283/A330-200.png
var _a332 = {
key: “a332”,
scale: 1.16,
anchor: [32, 32],
path: “m 31.6,8.6 0.2,0 0.3,0.3 0.4,0.8 0.5,1.1 0.4,1.2 0.4,1.7 0.3,2.5 0,10.1 5.2,2.9 -0.4,-1.7 -0.3,0 -0.1,-1 0,-2 0.1,-1 0.1,-0.3 2.1,0 0.1,0.3 0.1,1 0,2 -0.1,1 -0.3,0 -0.6,2.1 16.8,10.3 0.1,0.2 0,0.5 0.7,1.7 0,0.5 -0.7,-0.5 -9.7,-4.1 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -2.2,-0.8 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -2.3,-0.8 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -1.8,-0.7 -0.6,0 -0.1,0.8 -0.2,0.4 -0.2,-0.4 -0.1,-0.8 -3.3,0 -0.2,0.9 -0.3,0.9 0,5.7 -0.2,2.9 -0.5,3.3 -0.6,4.1 6.6,4 0.5,0.5 0.1,0.8 0,1 -7.8,-2.2 -0.3,2.2 -0.4,0 -0.3,-2.2 -7.9,2.2 0,-1 0.1,-0.8 0.5,-0.5 6.7,-4 -0.6,-4.1 -0.5,-3.3 -0.2,-2.9 0,-5.7 -0.3,-0.8 -0.2,-1 -3.3,0 -0.1,0.8 -0.2,0.4 -0.2,-0.4 -0.1,-0.8 -0.6,0 -1.8,0.7 -0.1,0.9 -0.2,0.3 -0.2,-0.3 -0.1,-0.7 -2.3,0.8 -0.1,0.9 -0.2,0.4 -0.2,-0.4 -0.1,-0.7 -2.2,0.8 -0.1,0.9 -0.2,0.4 -0.2,-0.4 -0.1,-0.7 -9.7,4.1 -0.7,0.5 0,-0.5 0.7,-1.7 0,-0.5 0.1,-0.2 16.8,-10.3 -0.6,-2.1 -0.3,0 -0.1,-1 0,-2 0.1,-1 0.1,-0.3 2.1,0 0.1,0.3 0.1,1 0,2 -0.1,1 -0.3,0 -0.4,1.7 5.2,-3.2 0,-9.8 0.3,-2.5 0.4,-1.7 0.4,-1.2 0.5,-1.1 0.4,-0.8 z”
**//A330-300 - Scale 1.16 Meters/point **
https://dl.dropboxusercontent.com/u/50785283/A330-300.png
var _a333 = {
key: “a333”,
scale: 1.16,
anchor: [32, 32],
path: “m 31.6,5.6 0.2,0 0.3,0.3 0.4,0.8 0.5,1.1 0.4,1.2 0.4,1.7 0.3,2.5 0,13.080314 5.2,2.919686 -0.4,-1.7 -0.3,0 -0.1,-1 0,-2 0.1,-1 0.1,-0.3 2.1,0 0.1,0.3 0.1,1 0,2 -0.1,1 -0.3,0 -0.6,2.1 16.8,10.3 0.1,0.2 0,0.5 0.7,1.7 0,0.5 -0.7,-0.5 -9.7,-4.1 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -2.2,-0.8 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -2.3,-0.8 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -1.8,-0.7 -0.6,0 -0.1,0.8 -0.2,0.4 -0.2,-0.4 -0.1,-0.8 -3.3,0 -0.2,0.9 -0.3,0.9 0,6.8 -0.2,2.9 -0.5,3.3 -0.6,4.1 6.6,4 0.5,0.5 0.1,0.8 0,1 -7.8,-2.2 -0.3,2.2 -0.4,0 -0.3,-2.2 -7.9,2.2 0,-1 0.1,-0.8 0.5,-0.5 6.7,-4 -0.6,-4.1 -0.5,-3.3 -0.2,-2.9 0,-6.8 -0.3,-0.8 -0.2,-1 -3.3,0 -0.1,0.8 -0.2,0.4 -0.2,-0.4 -0.1,-0.8 -0.6,0 -1.8,0.7 -0.1,0.9 -0.2,0.3 -0.2,-0.3 -0.1,-0.7 -2.3,0.8 -0.1,0.9 -0.2,0.4 -0.2,-0.4 -0.1,-0.7 -2.2,0.8 -0.1,0.9 -0.2,0.4 -0.2,-0.4 -0.1,-0.7 -9.7,4.1 -0.7,0.5 0,-0.5 0.7,-1.7 0,-0.5 0.1,-0.2 16.8,-10.3 -0.6,-2.1 -0.3,0 -0.1,-1 0,-2 0.1,-1 0.1,-0.3 2.1,0 0.1,0.3 0.1,1 0,2 -0.1,1 -0.3,0 -0.4,1.7 5.2,-3.2 0,-12.8 0.3,-2.5 L 30,9 30.4,7.8 30.9,6.7 31.3,5.9 Z”
**//A340 Series
//A340-200 - Scale 1.16 Meters/point **
https://dl.dropboxusercontent.com/u/50785283/A340-200.png
var _a342 = {
key: “a342”,
scale: 1.16,
anchor: [32, 32],
path: “m 31.6,8.6 0.2,0 0.3,0.3 0.4,0.8 0.5,1.1 0.4,1.2 0.4,1.7 0.3,2.5 0,9.8 4.6,2.9 -0.1,-0.8 0,-1.3 0.1,-0.9 0.1,-0.2 1.6,0 0.1,0.2 0.1,0.9 0,1.3 -0.2,1.8 6.9,4.3 -0.1,-0.8 0,-1.3 0.1,-0.9 0.1,-0.2 1.6,0 0.1,0.2 0.1,0.9 0,1.3 -0.2,1.8 7.8,4.7 0.1,0.2 0,0.5 0.7,1.7 0,0.5 -0.7,-0.5 -8.4,-3.6 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -0.7,-0.3 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -2.2,-0.8 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -2.3,-0.8 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -1.8,-0.7 -0.6,0 -0.1,0.8 -0.2,0.4 -0.2,-0.4 -0.1,-0.8 -3.3,0 -0.2,0.9 -0.3,0.9 0,5.7 -0.2,2.9 -0.5,3.3 -0.6,4.1 6.6,4 0.5,0.5 0.1,0.8 0,1 -7.8,-2.2 -0.3,2.2 -0.4,0 -0.3,-2.2 -7.9,2.2 0,-1 0.1,-0.8 0.5,-0.5 6.7,-4 -0.6,-4.1 -0.5,-3.3 -0.2,-2.9 0,-5.7 -0.3,-0.8 -0.2,-1 -3.3,0 -0.1,0.8 -0.2,0.4 -0.2,-0.4 -0.1,-0.8 -0.6,0 -1.8,0.7 -0.1,0.9 -0.2,0.3 -0.2,-0.3 -0.1,-0.7 -2.3,0.8 -0.1,0.9 -0.2,0.4 -0.2,-0.4 -0.1,-0.7 -2.2,0.8 -0.1,0.9 -0.2,0.4 -0.2,-0.4 -0.1,-0.7 -0.7,0.3 -0.1,0.9 -0.2,0.4 -0.2,-0.4 -0.1,-0.7 -8.4,3.6 -0.7,0.5 0,-0.5 0.7,-1.7 0,-0.5 0.1,-0.2 7.8,-4.7 -0.2,-1.8 0,-1.3 0.1,-0.9 0.1,-0.2 1.6,0 0.1,0.2 0.1,0.9 0,1.3 -0.1,0.8 6.9,-4.3 -0.2,-1.8 0,-1.3 0.1,-0.9 0.1,-0.2 1.6,0 0.1,0.2 0.1,0.9 0,1.3 -0.1,0.8 4.6,-2.9 0,-9.8 0.3,-2.5 0.4,-1.7 0.4,-1.2 0.5,-1.1 0.4,-0.8 z”
//A340-300 - Scale 1.16 Meters/point
https://dl.dropboxusercontent.com/u/50785283/A340-300.png
var _a343 = {
key: “a343”,
scale: 1.1,
anchor: [32, 32],
path: “m 31.6,5.6 0.2,0 0.3,0.3 0.4,0.8 0.5,1.1 0.4,1.2 0.4,1.7 0.3,2.5 0,12.8 4.6,2.9 -0.1,-0.8 0,-1.3 0.1,-0.9 0.1,-0.2 1.6,0 0.1,0.2 0.1,0.9 0,1.3 -0.2,1.8 6.9,4.3 -0.1,-0.8 0,-1.3 0.1,-0.9 0.1,-0.2 1.6,0 0.1,0.2 0.1,0.9 0,1.3 -0.2,1.8 7.8,4.7 0.1,0.2 0,0.5 0.7,1.7 0,0.5 -0.7,-0.5 -8.4,-3.6 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -0.7,-0.3 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -2.2,-0.8 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -2.3,-0.8 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -1.8,-0.7 -0.6,0 -0.1,0.8 -0.2,0.4 -0.2,-0.4 -0.1,-0.8 -3.3,0 -0.2,0.9 -0.3,0.9 0,6.8 -0.2,2.9 -0.5,3.3 -0.6,4.1 6.6,4 0.5,0.5 0.1,0.8 0,1 -7.8,-2.2 -0.3,2.2 -0.4,0 -0.3,-2.2 -7.9,2.2 0,-1 0.1,-0.8 0.5,-0.5 6.7,-4 -0.6,-4.1 -0.5,-3.3 -0.2,-2.9 0,-6.8 -0.3,-0.8 -0.2,-1 -3.3,0 -0.1,0.8 -0.2,0.4 -0.2,-0.4 -0.1,-0.8 -0.6,0 -1.8,0.7 -0.1,0.9 -0.2,0.3 -0.2,-0.3 -0.1,-0.7 -2.3,0.8 -0.1,0.9 -0.2,0.4 -0.2,-0.4 -0.1,-0.7 -2.2,0.8 -0.1,0.9 -0.2,0.4 -0.2,-0.4 -0.1,-0.7 -0.7,0.3 -0.1,0.9 -0.2,0.4 -0.2,-0.4 -0.1,-0.7 -8.4,3.6 -0.7,0.5 0,-0.5 0.7,-1.7 0,-0.5 0.1,-0.2 7.8,-4.7 -0.2,-1.8 0,-1.3 0.1,-0.9 0.1,-0.2 1.6,0 0.1,0.2 0.1,0.9 0,1.3 -0.1,0.8 6.9,-4.3 -0.2,-1.8 0,-1.3 0.1,-0.9 0.1,-0.2 1.6,0 0.1,0.2 0.1,0.9 0,1.3 -0.1,0.8 4.6,-2.9 0,-12.8 0.3,-2.5 L 30,9 30.4,7.8 30.9,6.7 31.3,5.9 z”
//A340-500 - Scale 1.18 Meters/point
https://dl.dropboxusercontent.com/u/50785283/A340-500.png
var _a345 = {
key: “a345”,
scale: 1.18,
anchor: [32, 32],
path: “m 31.6,5.6 0.2,0 0.3,0.3 0.4,0.8 0.5,1.1 0.4,1.2 0.4,1.7 0.3,2.5 0,13.4 4.7,3 -0.1,-1.1 0,-1.5 0.1,-0.9 0.2,-0.3 1.8,0 0.2,0.3 0.1,0.9 0,1.5 -0.2,1.7 -0.2,0 -0.1,0.4 7.1,4.4 -0.1,-1 0,-1.5 0.1,-0.9 0.2,-0.3 1.8,0 0.2,0.3 0.1,0.9 0,1.5 -0.2,1.7 -0.2,0 -0.1,0.5 8.3,5.1 0.1,0.2 0,0.5 0.7,1.7 0,0.5 -0.7,-0.5 -8.7,-3.7 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-1 -0.9,-0.3 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -2.3,-0.8 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -2.4,-0.9 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -2.1,-0.7 -0.5,0 -0.1,0.8 -0.2,0.4 -0.2,-0.4 -0.1,-0.8 -3.7,0 -0.1,1.7 -0.1,0.6 0,7.3 -0.2,2.6 -0.5,3.8 -0.7,4.2 6.6,3.9 0.5,0.5 0.1,0.7 0,1 -7.7,-2.1 -0.1,1 -0.2,1.2 -0.4,0 -0.2,-1.2 -0.1,-1 -7.7,2.1 0,-1 0.1,-0.7 0.5,-0.5 6.6,-3.9 -0.7,-4.2 -0.5,-3.8 -0.2,-2.6 0,-7.3 -0.1,-0.6 -0.1,-1.7 -3.7,0 -0.1,0.8 -0.2,0.4 -0.2,-0.4 -0.1,-0.8 -0.5,0 -2.1,0.7 -0.1,0.9 -0.2,0.3 -0.2,-0.3 -0.1,-0.7 -2.4,0.9 -0.1,0.9 -0.2,0.4 -0.2,-0.4 -0.1,-0.7 -2.3,0.8 -0.1,0.9 -0.2,0.4 -0.2,-0.4 -0.1,-0.7 -0.9,0.3 -0.1,1 -0.2,0.4 -0.2,-0.4 -0.1,-0.7 -8.7,3.7 -0.7,0.5 0,-0.5 0.7,-1.7 0,-0.5 0.1,-0.2 8.3,-5.1 -0.1,-0.5 -0.2,0 -0.2,-1.7 0,-1.5 0.1,-0.9 0.2,-0.3 1.8,0 0.2,0.3 0.1,0.9 0,1.5 -0.1,1 7.1,-4.4 -0.1,-0.4 -0.2,0 -0.2,-1.7 0,-1.5 0.1,-0.9 0.2,-0.3 1.8,0 0.2,0.3 0.1,0.9 0,1.5 -0.1,1.1 4.7,-3 0,-13.4 0.3,-2.5 L 30,9 30.4,7.8 30.9,6.7 31.3,5.9 z”
//A340-600 - Scale 1.18 Meters/point
https://dl.dropboxusercontent.com/u/50785283/A340-600.png
var _a346 = {
key: “a346”,
scale: 1.18,
anchor: [32, 32],
path: “m 31.6,0.2 0.2,0 0.3,0.3 0.4,0.8 0.5,1.1 0.4,1.2 0.4,1.7 0.3,2.5 0,18 4.7,3 -0.1,-1.1 0,-1.5 0.1,-0.9 0.2,-0.3 1.8,0 0.2,0.3 0.1,0.9 0,1.5 -0.2,1.7 -0.2,0 -0.1,0.4 7.1,4.4 -0.1,-1 0,-1.5 0.1,-0.9 0.2,-0.3 1.8,0 0.2,0.3 0.1,0.9 0,1.5 -0.2,1.7 -0.2,0 -0.1,0.5 8.3,5.1 0.1,0.2 0,0.5 0.7,1.7 0,0.5 -0.7,-0.5 -8.7,-3.7 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-1 -0.9,-0.3 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -2.3,-0.8 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -2.4,-0.9 -0.1,0.7 -0.2,0.4 -0.2,-0.4 -0.1,-0.9 -2.1,-0.7 -0.5,0 -0.1,0.8 -0.2,0.4 -0.2,-0.4 -0.1,-0.8 -3.7,0 -0.1,1.7 -0.1,0.6 0,8.8 -0.2,2.6 -0.5,3.8 -0.7,4.2 6.6,3.9 0.5,0.5 0.1,0.7 0,1 -7.7,-2.1 -0.1,1 -0.2,1.2 -0.4,0 -0.2,-1.2 -0.1,-1 -7.7,2.1 0,-1 0.1,-0.7 0.5,-0.5 6.6,-3.9 -0.7,-4.2 -0.5,-3.8 -0.2,-2.6 0,-8.8 -0.1,-0.6 -0.1,-1.7 -3.7,0 -0.1,0.8 -0.2,0.4 -0.2,-0.4 -0.1,-0.8 -0.5,0 -2.1,0.7 -0.1,0.9 -0.2,0.3 -0.2,-0.3 -0.1,-0.7 -2.4,0.9 -0.1,0.9 -0.2,0.4 -0.2,-0.4 -0.1,-0.7 -2.3,0.8 -0.1,0.9 -0.2,0.4 -0.2,-0.4 -0.1,-0.7 -0.9,0.3 -0.1,1 -0.2,0.4 -0.2,-0.4 -0.1,-0.7 -8.7,3.7 -0.7,0.5 0,-0.5 0.7,-1.7 0,-0.5 0.1,-0.2 8.3,-5.1 -0.1,-0.5 -0.2,0 -0.2,-1.7 0,-1.5 0.1,-0.9 0.2,-0.3 1.8,0 0.2,0.3 0.1,0.9 0,1.5 -0.1,1 7.1,-4.4 -0.1,-0.4 -0.2,0 -0.2,-1.7 0,-1.5 0.1,-0.9 0.2,-0.3 1.8,0 0.2,0.3 0.1,0.9 0,1.5 -0.1,1.1 4.7,-3 0,-18 0.3,-2.5 0.4,-1.7 0.4,-1.2 0.5,-1.1 0.4,-0.8 z”
//A380 Series
//A380-800 - Scale 1.24 Meters/point
https://dl.dropboxusercontent.com/u/50785283/A380.png
var _a388 = {
key: “a388”,
scale: 1.24,
anchor: [32, 33],
path: “m 31.6,1.6 0.4,0 0.4,0.4 0.6,0.7 0.8,2.1 0.5,2.6 0.3,2.1 0.1,2.2 0,4.9 0.9,1.3 6.7,5.5 -0.2,-0.9 0,-1.5 0.2,-1.2 0.2,-0.3 2.3,0 0.25,0.3 0.15,1.2 0,1.5 -0.1,1.3 -0.3,0.7 -0.4,0 -0.1,0.5 6.8,5 -0.1,-1.3 0,-1.5 0.2,-1.2 0.2,-0.3 2.3,0 0.2,0.3 0.2,1.2 0,1.5 -0.1,1.3 -0.3,0.8 -0.4,0 -0.2,0.7 9.5,7 0.6,0.8 0.4,1.2 0.1,2.8 -0.1,0 0,-0.9 -10.7,-4.6 0,0.7 -0.3,0.7 -0.2,-0.7 -0.1,-1 -2.8,-1.1 -0.1,1 -0.1,0.6 -0.4,-0.8 -0.1,-1.1 -2.7,-1 0,0.5 -0.2,1.4 -0.5,-2.2 -2.6,-1.1 -0.2,0.8 -0.2,-0.4 -0.1,-0.6 -1.3,-0.5 -1.4,-0.4 -0.1,0.4 -0.2,0.4 -0.3,-1 -3.8,-1 -0.2,2.4 -0.3,2.1 0,6.8 -0.5,4 -0.4,1.8 0.1,0.5 0.4,0.5 8.5,6.5 0.4,0.6 0.5,1.5 0.3,1.8 -10.2,-3.7 -1.3,0 -0.2,0.9 -0.3,0.8 -0.2,2.1 -0.2,-2.1 -0.3,-0.8 -0.2,-0.9 -1.3,0 -10.2,3.7 0.3,-1.8 0.5,-1.5 0.4,-0.6 8.5,-6.5 0.4,-0.5 0.1,-0.5 -0.4,-1.8 -0.5,-4 0,-6.8 -0.3,-2.1 -0.2,-2.4 -3.8,1 -0.3,1 -0.2,-0.4 -0.1,-0.4 -1.4,0.4 -1.3,0.5 -0.1,0.6 -0.2,0.4 -0.2,-0.8 -2.6,1.1 -0.5,2.2 -0.2,-1.4 0,-0.5 -2.7,1 -0.1,1.1 -0.4,0.8 -0.1,-0.6 -0.1,-1 -2.8,1.1 -0.1,1 -0.2,0.7 -0.2,-0.7 -0.1,-0.7 -10.7,4.6 0,0.9 -0.1,0 0.1,-2.8 0.4,-1.2 0.6,-0.8 9.5,-7 -0.2,-0.7 -0.4,0 -0.3,-0.8 -0.1,-1.3 0,-1.5 0.2,-1.2 0.2,-0.3 2.3,0 0.2,0.3 0.2,1.2 0,1.5 -0.1,1.3 6.8,-5 -0.1,-0.5 -0.4,0 -0.3,-0.7 -0.1,-1.3 0,-1.5 0.15,-1.2 0.25,-0.3 2.3,0 0.2,0.3 0.2,1.2 0,1.5 -0.2,0.9 6.7,-5.5 0.9,-1.3 0,-4.9 0.1,-2.2 0.3,-2.1 0.5,-2.6 0.8,-2.1 0.6,-0.7 z”
And some bonus random extras:
//Eurocopter EC135 - Scale 0.2 Meters/point - Too small to see detail, Have manually adjusted to larger scale of 0.6
https://dl.dropboxusercontent.com/u/50785283/EC135.png
var _e135 = {
key: “e135”,
scale: 0.6,
anchor: [32, 32],
path: “m 27.5,17.2 0,-0.2 -0.1,-0.3 0.2,-0.3 0,-0.5 0.1,-0.6 -0.4,-0.1 -0.2,-0.3 0.3,-1.1 0.2,0.1 -0.1,0.5 0.4,0.1 0.3,-0.7 0.5,-0.9 0.8,-0.7 0.9,-0.4 1,-0.1 1,0.1 0.9,0.4 0.8,0.7 0.5,0.9 0.3,0.7 0.4,-0.1 -0.1,-0.5 0.2,-0.1 0.3,1.1 -0.2,0.3 -0.4,0.1 0.1,0.6 0,0.5 0.2,0.3 -0.1,0.3 0,0.2 0.2,0.6 0,0.7 0.1,1 0.2,0 0,-1.2 0.1,-0.6 0.2,0 0.1,0.6 0.1,1.2 0,-2.4 0.1,-0.6 0.2,-0.1 0.2,0.1 0.1,0.6 -0.1,13.3 0.8,1 0,1.3 -2.2,-0.1 -0.1,1.7 -0.4,1.8 0.1,0.5 -0.1,0.4 -0.3,0.8 -0.4,0.7 -0.4,0.5 -0.1,0 -0.9,1.3 -0.2,0.9 -0.1,3.1 0.2,0.2 0.4,0 0.3,0.3 -0.1,1.7 -0.3,0.3 -0.4,0 -0.2,0.2 -0.1,2.6 5.7,0 0.4,0.4 0,0.3 -0.1,0.2 0,0.2 -0.1,0.3 0.3,2.4 -0.3,0 -0.2,-1.1 -5.7,0 0,0.7 3.1,-0.3 3.9,-0.9 4,-1.7 3.4,-2.1 3.1,-2.7 2.4,-2.9 2.1,-3.4 1.5,-3.5 1,-4.1 0.3,-4.1 -0.3,-4.1 -1,-3.9 -1.5,-3.7 -2.1,-3.3 -2.6,-3 -3,-2.7 -3.3,-2.1 -4,-1.7 -3.9,-0.9 -4,-0.3 -4,0.3 -3.9,0.9 -4,1.7 -3.3,2.1 -3,2.7 -2.6,3 -2,3.3 -1.6,3.7 -1,3.9 -0.2,4.1 0.2,4.1 1.1,3.9 1.4,3.6 2.1,3.5 2.6,2.9 3,2.7 3.4,2.1 3.9,1.7 3.9,0.9 3,0.3 1.9,0 0,0.2 -1.9,0 -3,-0.3 -3.9,-0.9 -4,-1.7 -3.4,-2.1 -3.1,-2.7 -2.6,-3 -2.1,-3.5 -1.5,-3.7 -1,-3.9 -0.3,-4.1 0.3,-4.1 1,-3.9 1.5,-3.7 2.1,-3.5 2.6,-3 3.1,-2.7 3.4,-2.1 4,-1.7 3.9,-0.9 4,-0.3 4,0.3 3.9,0.9 4,1.7 3.4,2.1 3.1,2.7 2.6,3 2.1,3.5 1.5,3.7 1,3.9 0.3,4.1 -0.3,4.1 -1,4.1 -1.5,3.5 -2.1,3.5 -2.6,3 -3.1,2.7 -3.4,2.1 -4,1.7 -3.9,0.9 -3.1,0.3 0,2.5 0.2,0.7 0,2.4 -0.2,0.2 0,1.8 -0.3,2.1 -1.2,0 -0.3,-2.1 0,-8.5 -5.7,-0.1 0.1,1.2 -0.3,0 -0.3,-2.5 -0.3,-0.3 0,-0.2 -0.1,-0.2 0,-0.3 0.3,-0.3 6.3,0 -0.1,-2.6 -0.2,-0.2 -0.4,0 -0.3,-0.3 -0.1,-1.7 0.3,-0.3 0.4,0 0.2,-0.2 L 30.2,41.2 30,40.3 29.1,39 29,39 28.6,38.5 28.2,37.8 27.9,37 l -0.1,-0.4 0.1,-0.5 -0.4,-1.8 -0.1,-1.7 -2.2,0.1 0,-1.3 0.8,-1 -0.1,-13.3 0.1,-0.6 0.2,-0.1 0.2,0.1 0.1,0.6 0,2.4 0.1,-1.2 0.1,-0.6 0.2,0 0.1,0.6 0,1.2 0.2,0 0.1,-1 0,-0.7 z”
**//MBB/Kawasaki BK 117 - Scale 0.21 Meters/point - Too small to see detail, Have manually adjusted to larger scale of 0.6 **
https://dl.dropboxusercontent.com/u/50785283/BK117.png
var _bk17 = {
key: “bk17”,
scale: 0.6,
anchor: [32, 32],
path: “m 27.7,17 0.4,-2.5 0.4,-1.5 0.4,-0.9 0.3,-0.5 0.4,-0.3 0.8,-0.3 1,-0.1 1,0.1 0.8,0.3 0.4,0.3 0.3,0.5 0.4,0.9 0.4,1.5 0.4,2.5 0.2,2.3 0.3,0 0,0.7 1.2,0 0,-2.9 0.1,-0.6 0.2,-0.1 0.2,0.1 0.1,0.6 0,14.7 -0.1,0.6 -0.2,0.1 -0.2,-0.1 -0.1,-0.6 0,-11.3 -1.2,0 0,2 -0.3,0 0,5.9 -0.3,0.5 0,0.3 1.8,0 0,0.6 -1.8,0 -0.1,1 0.2,1.4 0,1.5 -0.2,1.4 -0.1,0.2 -0.3,0.2 0.1,0.3 -0.1,0.2 -0.2,0.1 -0.9,2.2 -0.8,1.7 -0.2,0.2 -0.1,3.8 0.3,0.1 0.3,0.2 0.3,0.4 0.1,0.4 0,0.3 -0.1,0.4 -0.3,0.4 -0.3,0.2 -0.3,0.1 -0.1,4.1 4.9,0 0.1,-0.3 0.1,-0.1 0.1,0 0.1,0.1 0,0.4 0.2,0.2 0.1,0.5 0.1,0.2 0,0.3 -0.1,0.2 -0.3,3.6 -0.1,0 -0.3,-2.1 -0.1,-1.2 -4.8,0 0,0.6 3.2,-0.3 3.9,-0.9 4,-1.7 3.4,-2.1 3.1,-2.7 2.4,-2.9 2.1,-3.4 1.5,-3.5 1,-4.1 0.3,-4.1 -0.3,-4.1 -1,-3.9 -1.5,-3.7 -2.1,-3.3 -2.6,-3 -3,-2.7 -3.3,-2.1 -4,-1.7 -3.9,-0.9 -4,-0.3 -4,0.3 -3.9,0.9 -4,1.7 -3.3,2.1 -3,2.7 -2.6,3 -2,3.3 -1.6,3.7 -1,3.9 -0.2,4.1 0.2,4.1 1.1,3.9 1.4,3.6 2.1,3.5 2.6,2.9 3,2.7 3.4,2.1 3.9,1.7 3.9,0.9 3,0.3 1.8,0 0,0.2 -1.8,0 -3,-0.3 -3.9,-0.9 -4,-1.7 -3.4,-2.1 -3.1,-2.7 -2.6,-3 -2.1,-3.5 -1.5,-3.7 -1,-3.9 -0.3,-4.1 0.3,-4.1 1,-3.9 1.5,-3.7 2.1,-3.5 2.6,-3 3.1,-2.7 3.4,-2.1 4,-1.7 3.9,-0.9 4,-0.3 4,0.3 3.9,0.9 4,1.7 3.4,2.1 3.1,2.7 2.6,3 2.1,3.5 1.5,3.7 1,3.9 0.3,4.1 -0.3,4.1 -1,4.1 -1.5,3.5 -2.1,3.5 -2.6,3 -3.1,2.7 -3.4,2.1 -4,1.7 -3.9,0.9 -3.2,0.3 0,1.2 0.1,0.6 0,0.6 -0.4,1.7 -0.2,0.5 -0.2,0.2 0,0.1 0.2,0.2 0.7,0 0.1,0.1 0.2,0 0.1,-0.2 0.5,0 0.1,-1 0.1,0 0.3,-3 0.1,-0.1 0.1,0.1 -0.3,3 0.1,0.1 -0.1,0.8 -0.1,0.1 -0.1,0.7 0.1,0.1 -0.1,0.8 -0.1,0.1 -0.3,3 -0.1,0.1 -0.1,-0.1 0.3,-3 -0.1,0 0.1,-1 -0.4,-0.1 -0.1,-0.2 -0.2,0 -0.1,0.1 -0.7,0 -0.2,0.2 -0.3,0 -0.3,-0.2 0,-0.4 0.3,-0.2 -0.2,-0.4 -0.1,-0.4 -0.3,-1.6 0,-3.3 -4.8,0 -0.1,1.2 -0.3,2.1 -0.1,0 -0.3,-3.6 -0.1,-0.2 0,-0.3 0.1,-0.2 0.1,-0.5 0.2,-0.2 0,-0.4 0.1,-0.1 0.1,0 0.1,0.1 0.1,0.3 4.9,0 -0.1,-4.1 -0.3,-0.1 -0.3,-0.2 -0.3,-0.4 -0.1,-0.4 0,-0.3 0.1,-0.4 0.3,-0.4 0.3,-0.2 L 30.5,44 30.4,40.2 30.2,40 29.4,38.3 28.5,36.1 28.3,36 28.2,35.8 28.3,35.5 28,35.3 l -0.1,-0.2 -0.2,-1.4 0,-1.5 0.2,-1.4 -0.1,-1 -1.8,0 0,-0.6 1.8,0 0,-0.3 -0.3,-0.5 0,-5.9 -0.3,0 0,-2 -1.2,0 0,11.3 -0.1,0.6 -0.2,0.1 -0.2,-0.1 -0.1,-0.6 0,-14.7 0.1,-0.6 0.2,-0.1 0.2,0.1 0.1,0.6 0,2.9 1.2,0 0,-0.7 0.3,0 z”
//Bombardier Global Express - Scale 0.5 Meters/point
https://dl.dropboxusercontent.com/u/50785283/GLEX.png
var _glex = {
key: “glex”,
scale: 0.5,
anchor: [32, 32],
path: “m 32.2,0.7 0.3,-0.1 0.3,0.1 0.7,0.8 0.5,0.8 0.9,2.3 0.3,2.3 0,12.6 24.5,18.9 1,3 0,1.4 -0.8,-1.7 -0.1,0.3 -0.1,0 -0.1,-0.2 0,-0.4 -6.7,-3.3 0,0.2 -0.1,0.4 -0.1,0.1 -0.1,-0.1 -0.1,-0.4 0,-0.4 -5.5,-2.8 0,0.2 -0.1,0.4 -0.1,0.1 -0.1,-0.1 -0.1,-0.4 0,-0.4 -5.1,-1.5 0,0.2 -0.1,0.4 -0.1,0.1 -0.1,-0.1 -0.1,-0.4 0,-0.3 -5.9,-0.5 0,1.1 -0.2,1.4 -0.3,1.3 0.5,0 0.1,-0.3 0.2,-0.2 2.8,0 0.2,0.2 0.2,0.4 0.2,0.7 0.1,1.1 0,1.8 -0.2,1.6 -0.3,1.6 -0.3,1.4 -0.4,1.5 -2.1,0 -0.1,-0.2 -1.4,0.7 -0.3,1.3 -0.4,1.1 7.8,7 0.4,0.5 0.2,0.5 0,2.6 -9,-4.7 -0.1,0.6 -0.1,0.4 -0.1,0.2 -0.1,0.1 -0.1,-0.1 -0.1,-0.2 -0.1,-0.4 -0.1,-0.6 -9,4.7 0,-2.6 0.2,-0.5 0.4,-0.5 7.8,-7 -0.4,-1.1 -0.3,-1.3 -1.4,-0.7 -0.1,0.2 -2.1,0 -0.4,-1.5 -0.3,-1.4 -0.3,-1.6 -0.2,-1.6 0,-1.8 0.1,-1.1 0.2,-0.7 0.2,-0.4 0.2,-0.2 2.8,0 0.2,0.2 0.1,0.3 0.5,0 -0.3,-1.3 -0.2,-1.4 0,-1.1 -5.9,0.5 0,0.3 -0.1,0.4 -0.1,0.1 -0.1,-0.1 -0.1,-0.4 0,-0.2 -5.1,1.5 0,0.4 -0.1,0.4 -0.1,0.1 -0.1,-0.1 -0.1,-0.4 0,-0.2 -5.5,2.8 0,0.4 -0.1,0.4 -0.1,0.1 -0.1,-0.1 -0.1,-0.4 0,-0.2 -6.7,3.3 0,0.4 -0.1,0.2 -0.1,0 -0.1,-0.3 -0.8,1.7 0,-1.4 1,-3 24.5,-18.9 0,-12.6 0.3,-2.3 0.9,-2.3 0.5,-0.8 z”
Updated to the latest file and all looks good (I edited the file to keep the default icon). When I have time, I’ll switch back to the triangle and help pickup missing types as I am on a couple major airways.
I add these here so when OBJ shows adds them, we have a complete solution
LJ45 (reports as a LR45 in dump1090)
CRJ-100ER → CRJ1
Falcon 2000EX ->F2TH
didnt work
Bugger all. Im still tracking fine, I just dont have icons on my map. Ive touched no other file.
Let me start by saying that these are awesome and thanks to IAUCKLAN63 and everyone else for all of the work on them.
Here are a few missing types that are common to see in the southeast due to Delta and FedEx. I’ve grouped them into types that could probably share common icons.
DC-9/MD-80/MD-90/B717 family ICAO types
  • DC91
  • DC92
  • DC93
  • DC94
  • DC95
  • MD81
  • MD82
  • MD83
  • MD87
  • MD88
  • MD90
  • B712
DC-10/MD-11 family ICAO types
  • DC10
  • MD11
Occasionally I’ll see a member of the B727 family (usually a freighter conversion):
  • B721
  • B722
On a somewhat related note, I’ve been working on a mapping of the FAA registry to ICAO types that I hope to share in the next few weeks.
Note that dump1090-fa already has something like this.
Thanks for the heads up, although it looks like I’ve got some aircraft that the FA export in dump1090-fa doesn’t. Do you have plans to port that to dump1090-mutability at some point?
MD11 is on my to do list already, Fedex has them down this way too.
I am using the JSON DB for ICAO mapping here, it’s the DB file under HTML, there is s script you can use to add to this DB or rebuild from scratch csv-to-json.py. There is also a sample CSV file there you can add to if you want all the entries, I started with that as a base but removed most of the stuff I figure will never show up down here.
Usage on PiAware 3.1.0 is
sudo python csv-to-json.py vrs.csv db
Where vrs.csv is the source file and db is the directory location for the DB.
Here is a link to the python script and the sample CSV as they don’t seem to be included with 3.1.0:
https://dl.dropboxusercontent.com/u/50785283/csv-to-json.py
https://dl.dropboxusercontent.com/u/50785283/vrs.csv
I have an Excel spreadsheet I am recording tail numbers, types and ICAO’s I use this to generate the CSV:
https://dl.dropboxusercontent.com/u/50785283/JSON.JPG
I copy the output row and paste it into a text file, works fine as long as the first line is: icao24,r,t
The DB is pretty sticky though from a browser cache perspective, when testing a new DB I run up a new session in Incognito in Chrome to make sure nothing is cached.
Have a play and see what you think!
Great news on the MD-11. That vrs.csv file is the same that’s included in dump1090-mutability, and I’m using it as a base that I’m adding to using the csv-to-json.py script. Looking at github.com/flightaware/dump1090 … ic_html/db, it appears that dump1090-fa has a mass export from FlightAware’s database that isn’t reflected in vrs.csv.
To avoid hijacking this thread too much, I’ve spun off my FAA registry approach into a new thread.
The scripts are part of the github repository, but not packaged with the binary packages since most users don’t need the tools, just the output.
github.com/flightaware/dump1090 … ster/tools
The A300/A310 used by UPS, FedEx, & others could also use an icon. Here are the ICAO types for them:
  • A30B
  • A306
  • A310
The A350 will also need an icon as it becomes more prevalent. ICAO types:
  • A358
  • A359
  • A35K
MD-11 Path:
“m 32,0.7 0.3,0.1 0.4,0.4 0.5,0.8 0.6,1.4 0.4,1.7 0.7,4.2 0.2,4.1 0,11.8 4.1,3.2 -0.2,-1.1 0,-1.2 0.1,-1.1 0.2,-0.4 2.5,0 0.2,0.4 0.1,1.1 0,1.2 -0.3,1.3 -0.3,0 -0.3,1.5 16.6,13.4 0,0.6 0.4,2.2 0,1.2 -0.4,-0.9 0,0.3 -9.6,-4.6 -0.1,0.6 -0.1,0.3 -0.1,0 -0.1,-0.3 -0.1,-0.8 -4.5,-2.3 -0.1,0.7 -0.1,0.4 -0.1,0 -0.1,-0.4 -0.1,-0.9 -1.1,-0.6 -6.5,-1.4 0,4.4 -0.1,4.2 -0.5,3.7 -0.6,3.3 6.6,5.5 0,3.2 -7,-2.6 -0.1,0.8 -0.2,0.7 -0.3,0 -0.5,2.1 -0.2,0 -0.2,0.6 -0.2,-0.6 -0.2,0 -0.5,-2.1 -0.3,0 -0.2,-0.7 -0.1,-0.8 -7,2.5 0,-3.1 6.6,-5.5 -0.6,-3.3 -0.5,-3.7 -0.1,-4.2 0,-4.4 -6.5,1.4 -1.1,0.6 -0.1,0.9 -0.1,0.3 -0.1,0 -0.1,-0.3 -0.1,-0.7 -4.5,2.3 -0.1,0.8 -0.1,0.3 -0.1,0 -0.1,-0.3 -0.1,-0.6 -9.6,4.6 0,-0.3 -0.4,0.9 0,-1.2 0.4,-2.2 0,-0.6 16.6,-13.4 -0.3,-1.5 -0.3,0 -0.3,-1.3 0,-1.2 0.1,-1.1 0.2,-0.4 2.5,0 0.2,0.4 0.1,1.1 0,1.2 -0.2,1.1 4.1,-3.3 0,-11.7 0.2,-4.1 0.7,-4.2 0.4,-1.7 0.6,-1.4 0.5,-0.8 0.4,-0.4 z”
Scale is 0.98 meters per point, will sort others later :slight_smile:
Haven’t got right PC to do the pic just yet.
