Smoke forces Calif.-bound 757 to land at Yeager airport .
CHARLESTON, W.Va. – Passengers aboard a San Diego-bound United Airlines flight from Washington’s Dulles International Airport spent an unexpected four-hour layover at Charleston’s Yeager Airport on Tuesday, after smoke was detected in their westbound Boeing 757.
Emergency crews were on hand, and the access road to the airport was temporarily closed to accommodate emergency vehicles, as the aircraft made a routine landing at about 9:15 a.m.
None of the 178 passengers and crew members aboard the flight was injured in the incident.
wvgazette.com/News/201007270253
UAL 229’s normal IAD-SAN nonstop appears to have actually made 2 stops.
IAD-CRW Smoke diversion
CRW-ORD Plane change?
ORD-SAN Final destination, 6 hrs late
The ORD stop was due to a short runway at KCRW - 6,302 ft available on R5/R23.
that should have been long enough. may have been to swap crew instead.
At 90 degrees with fuel to get to SAN and (presumably) a full pax load. Maybe not.
at standard day plus 28 (87 degrees), airport altitude of ~1000, no winds, gross weight 220,000 the 757 can get airborne in less than 6,000 feet.
i’m saying they swapped crews in ord because the crew would have ran out of duty hours. otherwise, they could have gone to denver which is more direct if they couldn’t fly nonstop from yeager.
