this weekend lots of smaller aircrafts used the sunny weather here in bavaria/germany and thanks to flightaware mlat i got a huge number of them on my map.
in skyview the aircraft numbers then say e.g. 340 aircrafts - 250 with position. but when i scroll down the list of aircrafts there are mostly only about 40 shown without position not the delta which were 90. my first question is where are the missing 50 aircrafts - and what causes this behavior?
a second question i have is why those 40 (or even 90) do not have positions from mlat. when i look into the data i obviously got enough messages from them and the last message mostly is just 0-1 seconds old. in addition some of the aicrafts fly at high altitudes and that means they are seen of lots of other sites?
iām really happy how mlat works and helps me to see lots of aircrafts i never would see without. but to see again more would be nice
i add a screenshot and a aircraft.json file below
cheers
tom
p.s. post limit 32000 is a bit low - and it were great if there could be posted other formats beside pictures ā¦
{ "now" : 1508077871.8,
"messages" : 55901147,
"aircraft" : [
{"hex":"040062","altitude":31000,"mlat":[],"tisb":[],"messages":8,"seen":2.4,"rssi":-28.6},
{"hex":"3c4d67","mlat":[],"tisb":[],"messages":5,"seen":4.6,"rssi":-29.7},
{"hex":"3ff47a","altitude":2800,"mlat":[],"tisb":[],"messages":4,"seen":1.9,"rssi":-33.6},
{"hex":"8960ec","altitude":37000,"mlat":[],"tisb":[],"messages":2,"seen":14.3,"rssi":-25.7},
{"hex":"3c6641","lat":48.423843,"lon":11.870023,"nucp":7,"seen_pos":19.2,"altitude":4950,"vert_rate":1600,"track":302,"speed":268,"mlat":[],"tisb":[],"messages":14,"seen":2.7,"rssi":-22.4},
{"hex":"3cce19","squawk":"1000","altitude":40000,"vert_rate":-64,"track":59,"speed":465,"mlat":[],"tisb":[],"messages":38,"seen":5.7,"rssi":-28.1},
{"hex":"3c56ed","altitude":25575,"vert_rate":1536,"track":354,"speed":496,"mlat":[],"tisb":[],"messages":25,"seen":0.1,"rssi":-25.4},
{"hex":"3e79d1","mlat":[],"tisb":[],"messages":21,"seen":0.0,"rssi":-27.7},
{"hex":"3d0b30","squawk":"7000","flight":"DECMI ","mlat":[],"tisb":[],"messages":397,"seen":0.4,"rssi":-2.2},
{"hex":"4a1961","vert_rate":1920,"track":140,"speed":369,"mlat":[],"tisb":[],"messages":3,"seen":30.2,"rssi":-31.8},
{"hex":"3d12ff","squawk":"7000","altitude":4800,"mlat":[],"tisb":[],"messages":9,"seen":0.5,"rssi":-16.7},
{"hex":"3c664e","altitude":31000,"mlat":[],"tisb":[],"messages":12,"seen":5.5,"rssi":-23.7},
{"hex":"3c5cb2","altitude":30000,"mlat":[],"tisb":[],"messages":12,"seen":42.8,"rssi":-28.8},
{"hex":"3c6676","altitude":34000,"mlat":[],"tisb":[],"messages":4,"seen":24.0,"rssi":-27.7},
{"hex":"06a1e0","squawk":"5615","altitude":36025,"mlat":[],"tisb":[],"messages":39,"seen":1.0,"rssi":-27.8},
{"hex":"3d1e43","flight":"DEJSD ","altitude":3750,"category":"A1","mlat":[],"tisb":[],"messages":30,"seen":0.7,"rssi":-13.7},
{"hex":"3c49cb","squawk":"1014","altitude":31825,"mlat":[],"tisb":[],"messages":25,"seen":1.3,"rssi":-28.6},
{"hex":"471f4a","squawk":"0621","altitude":35000,"mlat":[],"tisb":[],"messages":44,"seen":4.7,"rssi":-29.0},
{"hex":"4d20a8","altitude":36000,"mlat":[],"tisb":[],"messages":35,"seen":44.2,"rssi":-28.3},
{"hex":"406c71","mlat":[],"tisb":[],"messages":4,"seen":59.3,"rssi":-21.8},
{"hex":"3452c8","squawk":"4544","altitude":35575,"mlat":[],"tisb":[],"messages":27,"seen":9.5,"rssi":-29.8},
{"hex":"4ca354","squawk":"7541","altitude":36000,"vert_rate":0,"track":296,"speed":456,"mlat":[],"tisb":[],"messages":57,"seen":0.5,"rssi":-25.8},
{"hex":"3d132d","squawk":"7000","lat":49.130021,"lon":10.925976,"nucp":0,"seen_pos":10.0,"altitude":-1000,"vert_rate":0,"track":219,"speed":47,"mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":128,"seen":1.0,"rssi":-19.9},
{"hex":"4ca6d1","altitude":38000,"vert_rate":-64,"track":302,"speed":445,"mlat":[],"tisb":[],"messages":30,"seen":20.2,"rssi":-28.9},
{"hex":"3e6c12","flight":"DKGCW ","altitude":7250,"mlat":[],"tisb":[],"messages":39,"seen":0.1,"rssi":-17.1},
{"hex":"86e844","altitude":33975,"mlat":[],"tisb":[],"messages":33,"seen":2.6,"rssi":-27.6},
{"hex":"400a30","mlat":[],"tisb":[],"messages":6,"seen":71.4,"rssi":-31.7},
{"hex":"3feb5c","altitude":6000,"mlat":[],"tisb":[],"messages":7,"seen":23.7,"rssi":-28.6},
{"hex":"3c6701","squawk":"6666","flight":"DLH424 ","lat":48.235336,"lon":11.706989,"nucp":7,"seen_pos":0.1,"altitude":13350,"vert_rate":1920,"track":270,"speed":299,"category":"A5","mlat":[],"tisb":[],"messages":695,"seen":0.1,"rssi":-5.3},
{"hex":"3c65c8","altitude":18675,"mlat":[],"tisb":[],"messages":17,"seen":2.0,"rssi":-20.0},
{"hex":"896313","altitude":35000,"mlat":[],"tisb":[],"messages":20,"seen":21.5,"rssi":-29.5},
{"hex":"392900","lat":49.132721,"lon":11.104214,"nucp":0,"seen_pos":8.8,"altitude":7025,"vert_rate":1024,"track":335,"speed":83,"mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":131,"seen":0.2,"rssi":-20.5},
{"hex":"3c65c2","altitude":10775,"mlat":[],"tisb":[],"messages":60,"seen":0.4,"rssi":-20.7},
{"hex":"3dd4c7","squawk":"7000","mlat":[],"tisb":[],"messages":7,"seen":31.7,"rssi":-23.7},
{"hex":"3d6745","mlat":[],"tisb":[],"messages":7,"seen":87.7,"rssi":-27.1},
{"hex":"3d1d82","mlat":[],"tisb":[],"messages":14,"seen":83.4,"rssi":-19.3},
{"hex":"3d0ff4","mlat":[],"tisb":[],"messages":2,"seen":125.4,"rssi":-35.9},
{"hex":"398db3","mlat":[],"tisb":[],"messages":25,"seen":53.0,"rssi":-29.7},
{"hex":"4d00c9","squawk":"1430","lat":50.149096,"lon":13.060369,"nucp":0,"seen_pos":3.1,"altitude":19200,"vert_rate":1152,"track":277,"speed":277,"mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":185,"seen":0.3,"rssi":-25.1},
{"hex":"4400b2","vert_rate":64,"track":251,"speed":426,"mlat":[],"tisb":[],"messages":8,"seen":1.3,"rssi":-27.7},
{"hex":"4ca770","squawk":"2505","flight":"EIN359K ","lat":48.841398,"lon":8.927476,"nucp":6,"seen_pos":2.0,"altitude":11400,"vert_rate":2752,"track":313,"speed":342,"category":"A0","mlat":[],"tisb":[],"messages":267,"seen":0.0,"rssi":-12.8},
{"hex":"39cea0","squawk":"7274","altitude":38000,"mlat":[],"tisb":[],"messages":69,"seen":0.1,"rssi":-26.4},
{"hex":"3d0c47","squawk":"0025","altitude":9975,"mlat":[],"tisb":[],"messages":10,"seen":9.8,"rssi":-27.3},
{"hex":"4ba9c3","squawk":"4535","altitude":16600,"vert_rate":-2048,"track":294,"speed":383,"mlat":[],"tisb":[],"messages":46,"seen":0.6,"rssi":-28.4},
{"hex":"49d095","mlat":[],"tisb":[],"messages":42,"seen":1.2,"rssi":-24.8},
{"hex":"3ff31b","mlat":[],"tisb":[],"messages":30,"seen":91.6,"rssi":-23.7},
{"hex":"34530e","mlat":[],"tisb":[],"messages":18,"seen":78.1,"rssi":-30.3},
{"hex":"3d556c","mlat":[],"tisb":[],"messages":2,"seen":144.6,"rssi":-38.3},
{"hex":"3e7eb8","mlat":[],"tisb":[],"messages":2,"seen":147.4,"rssi":-37.1},
{"hex":"a2f74a","altitude":32000,"vert_rate":-64,"track":249,"speed":480,"mlat":[],"tisb":[],"messages":57,"seen":0.5,"rssi":-28.4},
{"hex":"4a08e8","squawk":"5443","altitude":40000,"vert_rate":0,"track":293,"speed":446,"mlat":[],"tisb":[],"messages":96,"seen":0.1,"rssi":-26.9},
{"hex":"43e943","squawk":"0435","altitude":40000,"vert_rate":0,"track":52,"speed":487,"mlat":[],"tisb":[],"messages":314,"seen":0.2,"rssi":-16.6},
{"hex":"3ec025","mlat":[],"tisb":[],"messages":18,"seen":93.2,"rssi":-27.1},
{"hex":"4d00d9","squawk":"4137","flight":"LGL9736 ","lat":48.487335,"lon":11.746216,"nucp":7,"seen_pos":0.7,"altitude":8625,"vert_rate":832,"track":312,"speed":236,"category":"A2","mlat":[],"tisb":[],"messages":773,"seen":0.0,"rssi":-5.2},
{"hex":"3c4906","altitude":38000,"mlat":[],"tisb":[],"messages":49,"seen":0.3,"rssi":-25.5},
{"hex":"3d12ae","squawk":"0025","lat":49.698191,"lon":10.584214,"nucp":0,"seen_pos":9.8,"altitude":9900,"vert_rate":704,"track":175,"speed":84,"mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":68,"seen":1.0,"rssi":-26.0},
{"hex":"3cc2bc","squawk":"2766","lat":47.653384,"lon":9.945867,"nucp":0,"seen_pos":6.1,"altitude":17975,"vert_rate":3584,"track":75,"speed":380,"mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":218,"seen":0.1,"rssi":-22.0},
{"hex":"3d1047","squawk":"7000","flight":"DEEKL ","altitude":3100,"category":"A1","mlat":[],"tisb":[],"messages":535,"seen":0.3,"rssi":-11.0},
{"hex":"3e77d9","squawk":"7000","lat":47.792130,"lon":10.415451,"nucp":0,"seen_pos":52.4,"altitude":4500,"track":30,"speed":101,"mlat":[],"tisb":[],"messages":141,"seen":0.7,"rssi":-24.1},
{"hex":"3c1489","squawk":"4166","flight":"AFR12AE ","lat":49.474508,"lon":10.924196,"nucp":0,"seen_pos":4.1,"altitude":11800,"vert_rate":1472,"track":323,"speed":302,"mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":656,"seen":0.4,"rssi":-17.9},
{"hex":"3ff569","lat":47.558212,"lon":10.620758,"nucp":0,"seen_pos":13.9,"altitude":6375,"mlat":[],"tisb":[],"messages":44,"seen":13.9,"rssi":-23.6},
{"hex":"3d2ac8","squawk":"7000","altitude":5500,"mlat":[],"tisb":[],"messages":66,"seen":16.3,"rssi":-20.3},
{"hex":"3c4d65","squawk":"1000","altitude":37000,"mlat":[],"tisb":[],"messages":77,"seen":0.1,"rssi":-19.9},
{"hex":"3e61fc","altitude":39000,"mlat":[],"tisb":[],"messages":17,"seen":8.5,"rssi":-26.4},
{"hex":"3c66b7","squawk":"6414","altitude":32000,"vert_rate":0,"track":185,"speed":442,"mlat":[],"tisb":[],"messages":179,"seen":2.1,"rssi":-23.8},
{"hex":"3d2b88","mlat":[],"tisb":[],"messages":2,"seen":243.0,"rssi":-35.3},
{"hex":"4b3900","squawk":"1000","flight":"PJS701 ","lat":47.386268,"lon":10.717797,"nucp":9,"seen_pos":1.3,"altitude":24000,"vert_rate":-64,"track":334,"speed":428,"category":"A0","mlat":[],"tisb":[],"messages":1420,"seen":0.1,"rssi":-8.3},
{"hex":"485303","squawk":"1000","flight":"TRA76B ","lat":49.979370,"lon":13.650730,"nucp":7,"seen_pos":16.0,"altitude":38000,"vert_rate":0,"track":292,"speed":449,"mlat":[],"tisb":[],"messages":229,"seen":0.5,"rssi":-22.4},
{"hex":"3ecc2f","squawk":"7000","flight":"DKSHB ","lat":48.034694,"lon":11.370990,"nucp":0,"seen_pos":4.0,"altitude":6350,"vert_rate":320,"track":218,"speed":53,"category":"A0","mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":461,"seen":0.1,"rssi":-4.1},
{"hex":"8963e1","squawk":"2171","flight":"UAE40 ","lat":50.243866,"lon":8.457593,"nucp":7,"seen_pos":4.0,"altitude":31000,"vert_rate":0,"track":100,"speed":501,"category":"A5","mlat":[],"tisb":[],"messages":651,"seen":0.0,"rssi":-20.2},
{"hex":"3d07e1","squawk":"7000","flight":"DEBFT ","altitude":3775,"mlat":[],"tisb":[],"messages":81,"seen":0.1,"rssi":-18.1},
{"hex":"3c6448","squawk":"2541","lat":49.269306,"lon":8.646240,"nucp":7,"seen_pos":52.3,"altitude":20900,"vert_rate":64,"track":164,"speed":371,"mlat":[],"tisb":[],"messages":818,"seen":0.6,"rssi":-22.0},
{"hex":"3e7f19","squawk":"7000","flight":"DKNIF ","lat":48.232401,"lon":11.439225,"nucp":0,"seen_pos":3.2,"altitude":23050,"vert_rate":-1664,"track":335,"speed":71,"category":"A0","mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":510,"seen":0.1,"rssi":-9.8},
{"hex":"3ff4be","altitude":4700,"mlat":[],"tisb":[],"messages":58,"seen":5.0,"rssi":-23.7},
{"hex":"3d2080","mlat":[],"tisb":[],"messages":18,"seen":178.5,"rssi":-25.2},
{"hex":"3c6307","squawk":"1000","altitude":38000,"vert_rate":0,"track":4,"speed":480,"mlat":[],"tisb":[],"messages":225,"seen":9.6,"rssi":-25.4},
{"hex":"8960e9","squawk":"2164","flight":"UAE2 ","altitude":37000,"vert_rate":0,"track":97,"speed":492,"category":"A5","mlat":[],"tisb":[],"messages":564,"seen":0.1,"rssi":-25.0},
{"hex":"3e1760","mlat":[],"tisb":[],"messages":22,"seen":286.7,"rssi":-24.5},
{"hex":"40726f","squawk":"6612","flight":"TCX431 ","lat":48.934982,"lon":12.410396,"nucp":5,"seen_pos":1.2,"altitude":34000,"vert_rate":0,"track":297,"speed":458,"category":"A0","mlat":[],"tisb":[],"messages":1464,"seen":0.1,"rssi":-13.9},
{"hex":"3e729e","mlat":[],"tisb":[],"messages":32,"seen":163.0,"rssi":-25.8},
{"hex":"3fec70","squawk":"7000","flight":"DMIFI ","lat":48.336306,"lon":10.108795,"nucp":0,"seen_pos":2.5,"altitude":4750,"vert_rate":-128,"track":357,"speed":103,"category":"B4","mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":385,"seen":2.4,"rssi":-22.4},
{"hex":"484339","squawk":"5137","flight":"KZR223 ","lat":50.506760,"lon":13.793841,"nucp":7,"seen_pos":11.9,"altitude":38000,"vert_rate":0,"track":245,"speed":432,"category":"A0","mlat":[],"tisb":[],"messages":835,"seen":0.4,"rssi":-23.2},
{"hex":"3d3812","squawk":"7000","flight":"DETMG ","lat":48.302582,"lon":9.997629,"nucp":7,"seen_pos":1.1,"altitude":4125,"vert_rate":192,"track":355,"speed":151,"category":"A1","mlat":[],"tisb":[],"messages":776,"seen":0.1,"rssi":-16.3},
{"hex":"3d182c","squawk":"7000","flight":"DEHKE ","lat":48.455433,"lon":10.619876,"nucp":2,"seen_pos":21.1,"altitude":3075,"track":296,"speed":99,"category":"A1","mlat":[],"tisb":[],"messages":173,"seen":0.2,"rssi":-22.9},
{"hex":"3d04fe","mlat":[],"tisb":[],"messages":10,"seen":286.0,"rssi":-19.9},
{"hex":"501d1d","mlat":[],"tisb":[],"messages":41,"seen":269.1,"rssi":-25.9},
{"hex":"3fed6d","mlat":[],"tisb":[],"messages":36,"seen":10.6,"rssi":-29.4},
{"hex":"3d0980","lat":48.031202,"lon":8.574125,"nucp":0,"seen_pos":8.3,"altitude":8475,"vert_rate":-1984,"track":174,"speed":72,"mlat":["lat","lon","altitude","track","speed","vert_rate"],"tisb":[],"messages":229,"seen":8.3,"rssi":-20.4},
{"hex":"3d31cb","lat":48.971418,"lon":10.187506,"nucp":0,"seen_pos":40.1,"altitude":4200,"vert_rate":-256,"track":336,"speed":116,"mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":90,"seen":40.1,"rssi":-26.3},
{"hex":"3c660c","squawk":"7707","flight":"DLH8LC ","lat":47.563934,"lon":12.609695,"nucp":0,"seen_pos":0.9,"altitude":24875,"vert_rate":1664,"track":143,"speed":438,"category":"A0","mlat":[],"tisb":[],"messages":2458,"seen":0.1,"rssi":-16.6},
{"hex":"44d078","squawk":"6401","altitude":35000,"vert_rate":0,"track":132,"speed":449,"mlat":[],"tisb":[],"messages":591,"seen":0.8,"rssi":-18.4},
{"hex":"3d3027","mlat":[],"tisb":[],"messages":72,"seen":136.8,"rssi":-25.8},
{"hex":"4057f2","squawk":"2221","flight":"STK9NK ","lat":48.996603,"lon":12.217592,"nucp":0,"seen_pos":6.4,"altitude":32000,"vert_rate":0,"track":297,"speed":443,"mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":1250,"seen":0.0,"rssi":-13.6},
{"hex":"4a09aa","squawk":"1000","flight":"BMS6RA ","lat":48.886734,"lon":12.571529,"nucp":6,"seen_pos":0.7,"altitude":36000,"vert_rate":0,"track":297,"speed":457,"category":"A0","mlat":[],"tisb":[],"messages":714,"seen":0.0,"rssi":-9.3},
{"hex":"3d1bc3","squawk":"7000","mlat":[],"tisb":[],"messages":280,"seen":2.0,"rssi":-24.6},
{"hex":"4cabbd","squawk":"2707","flight":"RYR9502 ","lat":46.827530,"lon":11.346398,"nucp":6,"seen_pos":2.8,"altitude":36000,"vert_rate":0,"track":322,"speed":459,"category":"A0","mlat":[],"tisb":[],"messages":304,"seen":0.2,"rssi":-20.3},
{"hex":"4951eb","squawk":"1000","flight":"TAP1274 ","lat":47.101822,"lon":9.625534,"nucp":7,"seen_pos":5.0,"altitude":41000,"vert_rate":0,"track":67,"speed":462,"mlat":[],"tisb":[],"messages":493,"seen":0.0,"rssi":-16.9},
{"hex":"3c5442","squawk":"6473","flight":"DLH1PP ","lat":48.576515,"lon":11.026732,"nucp":6,"seen_pos":0.5,"altitude":18000,"vert_rate":-64,"track":282,"speed":342,"category":"A3","mlat":[],"tisb":[],"messages":6060,"seen":0.0,"rssi":-6.3},
{"hex":"4b1f1e","squawk":"6660","lat":49.266606,"lon":10.754965,"nucp":0,"seen_pos":12.6,"altitude":9900,"vert_rate":0,"track":251,"speed":126,"mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":488,"seen":0.1,"rssi":-20.6},
{"hex":"3c6dcc","squawk":"5036","flight":"GWI7NU ","lat":49.163492,"lon":9.884009,"nucp":7,"seen_pos":0.9,"altitude":20975,"vert_rate":1984,"track":51,"speed":415,"category":"A0","mlat":[],"tisb":[],"messages":2210,"seen":0.1,"rssi":-15.8},
{"hex":"3d3250","mlat":[],"tisb":[],"messages":79,"seen":193.4,"rssi":-28.9},
{"hex":"3fee37","altitude":3275,"mlat":[],"tisb":[],"messages":87,"seen":0.4,"rssi":-24.8},
{"hex":"4ca8d4","squawk":"0454","flight":"RYR4675 ","altitude":38000,"vert_rate":0,"track":55,"speed":447,"category":"A0","mlat":[],"tisb":[],"messages":439,"seen":0.5,"rssi":-25.3},
{"hex":"3c4aad","squawk":"0612","flight":"CFG314 ","lat":49.212296,"lon":9.855370,"nucp":6,"seen_pos":1.1,"altitude":24900,"vert_rate":1472,"track":134,"speed":458,"category":"A0","mlat":[],"tisb":[],"messages":1968,"seen":0.3,"rssi":-14.2},
{"hex":"3c5463","vert_rate":-192,"track":246,"speed":415,"mlat":[],"tisb":[],"messages":236,"seen":19.3,"rssi":-30.2},
{"hex":"345041","squawk":"6653","flight":"VLG51XP ","lat":47.394836,"lon":11.932526,"nucp":7,"seen_pos":0.3,"altitude":26225,"vert_rate":1984,"track":189,"speed":393,"category":"A3","mlat":[],"tisb":[],"messages":4138,"seen":0.0,"rssi":-9.8},
{"hex":"406696","squawk":"3461","flight":"TOM90C ","lat":50.240246,"lon":8.590344,"nucp":7,"seen_pos":11.2,"altitude":41000,"vert_rate":0,"track":134,"speed":445,"category":"A0","mlat":[],"tisb":[],"messages":1496,"seen":0.1,"rssi":-22.0},
{"hex":"4855bf","altitude":37000,"mlat":[],"tisb":[],"messages":462,"seen":5.0,"rssi":-27.1},
{"hex":"440958","squawk":"3676","flight":"EWG6RD ","lat":47.495544,"lon":11.542099,"nucp":7,"seen_pos":0.3,"altitude":36000,"vert_rate":0,"track":19,"speed":483,"category":"A3","mlat":[],"tisb":[],"messages":2835,"seen":0.0,"rssi":-5.9},
{"hex":"3e5c42","mlat":[],"tisb":[],"messages":85,"seen":104.5,"rssi":-21.8},
{"hex":"4ba915","squawk":"4655","flight":"THY5AK ","lat":47.504288,"lon":12.478615,"nucp":7,"seen_pos":1.8,"altitude":36000,"vert_rate":0,"track":281,"speed":445,"category":"A0","mlat":[],"tisb":[],"messages":2533,"seen":0.0,"rssi":-14.7},
{"hex":"49d2fc","squawk":"1000","flight":"TVS4346 ","lat":50.067123,"lon":12.248744,"nucp":7,"seen_pos":8.1,"altitude":30000,"vert_rate":1216,"track":272,"speed":404,"category":"A0","mlat":[],"tisb":[],"messages":1547,"seen":0.3,"rssi":-16.4},
{"hex":"3c56f7","squawk":"6471","lat":50.179216,"lon":11.282959,"nucp":7,"seen_pos":69.6,"altitude":23600,"mlat":[],"tisb":[],"messages":427,"seen":8.5,"rssi":-30.0},
{"hex":"3c667a","squawk":"1000","flight":"DLH5EL ","lat":50.167465,"lon":12.487118,"nucp":7,"seen_pos":2.9,"altitude":34000,"vert_rate":0,"track":285,"speed":452,"category":"A0","mlat":[],"tisb":[],"messages":1243,"seen":0.1,"rssi":-19.6},
{"hex":"4cabb7","squawk":"2717","flight":"RYR9452 ","lat":49.527717,"lon":6.798087,"nucp":6,"seen_pos":3.4,"altitude":37000,"vert_rate":0,"track":129,"speed":414,"category":"A0","mlat":[],"tisb":[],"messages":1019,"seen":0.0,"rssi":-17.0},
{"hex":"4b984f","squawk":"0103","flight":"FHY7362 ","lat":50.072937,"lon":9.032280,"nucp":7,"seen_pos":2.0,"altitude":33500,"vert_rate":576,"track":106,"speed":470,"mlat":[],"tisb":[],"messages":1503,"seen":0.0,"rssi":-20.2},
{"hex":"484135","altitude":37000,"mlat":[],"tisb":[],"messages":381,"seen":0.0,"rssi":-29.5},
{"hex":"4070e9","squawk":"2161","flight":"EXS71L ","lat":50.098774,"lon":8.570969,"nucp":7,"seen_pos":1.2,"altitude":35000,"vert_rate":0,"track":110,"speed":443,"category":"A3","mlat":[],"tisb":[],"messages":1386,"seen":0.3,"rssi":-20.9},
{"hex":"010144","squawk":"0110","flight":"MSR726 ","lat":49.485580,"lon":7.632896,"nucp":6,"seen_pos":24.5,"altitude":37000,"vert_rate":0,"track":121,"speed":432,"category":"A0","mlat":[],"tisb":[],"messages":1477,"seen":1.3,"rssi":-24.8},
{"hex":"3d2992","altitude":2000,"mlat":[],"tisb":[],"messages":1031,"seen":5.0,"rssi":-26.7},
{"hex":"3c496d","squawk":"5545","flight":"NLY75GA ","lat":47.771805,"lon":8.912109,"nucp":7,"seen_pos":5.2,"altitude":20650,"vert_rate":-2688,"track":26,"speed":454,"category":"A0","mlat":[],"tisb":[],"messages":836,"seen":0.5,"rssi":-24.5},
{"hex":"3c65c1","squawk":"1000","flight":"DLH111 ","lat":49.066943,"lon":10.917591,"nucp":7,"seen_pos":1.5,"altitude":21400,"vert_rate":1024,"track":317,"speed":470,"category":"A0","mlat":[],"tisb":[],"messages":4831,"seen":0.3,"rssi":-15.8},
{"hex":"3964f0","altitude":41000,"mlat":[],"tisb":[],"messages":438,"seen":65.9,"rssi":-28.1},
{"hex":"3d3579","squawk":"7000","lat":48.523213,"lon":10.137128,"nucp":0,"seen_pos":2.3,"altitude":3850,"vert_rate":-256,"track":336,"speed":113,"mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":283,"seen":2.3,"rssi":-24.2},
{"hex":"3d212e","lat":49.598290,"lon":10.063996,"nucp":0,"seen_pos":8.5,"altitude":3700,"vert_rate":0,"track":328,"speed":133,"mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":549,"seen":8.5,"rssi":-16.5},
{"hex":"471f61","squawk":"1000","lat":50.878523,"lon":13.026657,"nucp":7,"seen_pos":2.1,"altitude":36775,"vert_rate":960,"track":140,"speed":444,"mlat":[],"tisb":[],"messages":404,"seen":0.9,"rssi":-22.2},
{"hex":"3d1b95","squawk":"7000","flight":"DEIRT ","altitude":3000,"category":"A0","mlat":[],"tisb":[],"messages":839,"seen":0.1,"rssi":-3.0},
{"hex":"3fed8b","mlat":[],"tisb":[],"messages":19,"seen":118.4,"rssi":-28.0},
{"hex":"3d05fe","squawk":"7000","flight":"DEANE ","lat":48.459017,"lon":10.351723,"nucp":0,"seen_pos":2.9,"altitude":4600,"vert_rate":0,"track":163,"speed":97,"category":"A0","mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":1696,"seen":0.0,"rssi":-10.5},
{"hex":"4b17de","squawk":"4617","flight":"SWR1337 ","lat":50.301041,"lon":13.138492,"nucp":7,"seen_pos":1.4,"altitude":39975,"vert_rate":0,"track":245,"speed":446,"category":"A3","mlat":[],"tisb":[],"messages":2242,"seen":0.0,"rssi":-19.7},
{"hex":"3d413b","squawk":"7000","flight":"DEWYL ","lat":47.904999,"lon":9.934880,"nucp":0,"seen_pos":2.9,"altitude":6500,"vert_rate":0,"track":300,"speed":143,"mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":838,"seen":0.2,"rssi":-11.2},
{"hex":"3e60b2","squawk":"7000","flight":"DKBUW ","lat":48.303114,"lon":11.456066,"nucp":0,"seen_pos":0.4,"altitude":2600,"category":"A1","mlat":[],"tisb":[],"messages":2508,"seen":0.1,"rssi":-7.4},
{"hex":"3ff579","squawk":"7000","flight":"DMYBH ","lat":48.611150,"lon":11.308184,"nucp":0,"seen_pos":1.8,"altitude":3050,"vert_rate":-64,"track":284,"speed":102,"category":"B4","mlat":[],"tisb":[],"messages":293,"seen":0.7,"rssi":-16.4},
{"hex":"3c6594","squawk":"6664","flight":"DLH4UA ","lat":49.333827,"lon":10.859696,"nucp":9,"seen_pos":0.8,"altitude":28275,"vert_rate":1408,"track":311,"speed":472,"category":"A0","mlat":[],"tisb":[],"messages":4449,"seen":0.1,"rssi":-18.9},
{"hex":"503db5","squawk":"3423","flight":"TCX68GM ","lat":50.140019,"lon":9.667820,"nucp":7,"seen_pos":1.9,"altitude":33025,"vert_rate":0,"track":120,"speed":451,"category":"A0","mlat":[],"tisb":[],"messages":1494,"seen":0.2,"rssi":-17.2},
{"hex":"3944f2","mlat":[],"tisb":[],"messages":41,"seen":289.8,"rssi":-29.6},
{"hex":"3c49d9","squawk":"4353","flight":"BER8790 ","lat":47.209030,"lon":12.881676,"nucp":7,"seen_pos":1.0,"altitude":28925,"vert_rate":1024,"track":151,"speed":461,"category":"A3","mlat":[],"tisb":[],"messages":4858,"seen":0.2,"rssi":-26.1},
{"hex":"3c56e9","squawk":"4111","altitude":36150,"mlat":[],"tisb":[],"messages":1838,"seen":2.0,"rssi":-28.5},
{"hex":"400b84","squawk":"0312","altitude":39000,"vert_rate":0,"track":127,"speed":434,"mlat":[],"tisb":[],"messages":865,"seen":0.9,"rssi":-22.5},
{"hex":"3e7c1a","altitude":3650,"mlat":[],"tisb":[],"messages":143,"seen":67.7,"rssi":-19.8},
{"hex":"4ca850","squawk":"2250","flight":"RYR6345 ","lat":49.613466,"lon":12.055120,"nucp":6,"seen_pos":3.5,"altitude":36000,"vert_rate":64,"track":308,"speed":443,"category":"A0","mlat":[],"tisb":[],"messages":3044,"seen":0.1,"rssi":-11.5},
{"hex":"40093f","squawk":"7531","altitude":37950,"mlat":[],"tisb":[],"messages":224,"seen":0.4,"rssi":-27.6},
{"hex":"3ff1fb","squawk":"7000","flight":"DMKIZ ","lat":48.902660,"lon":10.813149,"nucp":0,"seen_pos":2.1,"altitude":6475,"category":"B4","mlat":[],"tisb":[],"messages":644,"seen":0.0,"rssi":-16.7},
{"hex":"3e797e","squawk":"7000","flight":"DKLFA ","lat":47.864918,"lon":9.993404,"nucp":0,"seen_pos":6.0,"altitude":5825,"vert_rate":64,"track":136,"speed":91,"category":"A0","mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":915,"seen":0.4,"rssi":-13.3},
{"hex":"3fe9f2","squawk":"7000","flight":"DMEIC ","lat":48.054199,"lon":11.341130,"nucp":0,"seen_pos":10.0,"altitude":4050,"vert_rate":0,"track":306,"speed":114,"category":"B4","mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":1050,"seen":0.4,"rssi":-2.4},
{"hex":"3d257d","mlat":[],"tisb":[],"messages":302,"seen":11.2,"rssi":-21.7},
{"hex":"473410","squawk":"5645","flight":"WZZ4EP ","lat":49.713501,"lon":8.622388,"nucp":6,"seen_pos":16.5,"altitude":35025,"vert_rate":0,"track":89,"speed":471,"category":"A0","mlat":[],"tisb":[],"messages":1751,"seen":0.2,"rssi":-22.1},
{"hex":"4cabc1","squawk":"0113","flight":"RYR390U ","lat":49.956836,"lon":8.905829,"nucp":7,"seen_pos":1.9,"altitude":37000,"vert_rate":0,"track":103,"speed":438,"category":"A0","mlat":[],"tisb":[],"messages":1935,"seen":0.0,"rssi":-21.1},
{"hex":"3c66ae","squawk":"2567","flight":"DLH2RV ","lat":48.792425,"lon":10.478138,"nucp":7,"seen_pos":0.3,"altitude":33450,"vert_rate":1792,"track":133,"speed":440,"category":"A0","mlat":[],"tisb":[],"messages":5253,"seen":0.0,"rssi":-10.8},
{"hex":"3c6502","squawk":"1000","altitude":28100,"vert_rate":-1792,"track":217,"speed":392,"mlat":[],"tisb":[],"messages":508,"seen":0.1,"rssi":-21.8},
{"hex":"3c4895","squawk":"1000","flight":"BER67WR ","lat":49.488986,"lon":10.754650,"nucp":7,"seen_pos":3.6,"altitude":28525,"vert_rate":1728,"track":313,"speed":454,"category":"A0","mlat":[],"tisb":[],"messages":5973,"seen":0.0,"rssi":-16.1},
{"hex":"3d1942","lat":48.679210,"lon":11.171000,"nucp":0,"seen_pos":54.1,"vert_rate":-640,"track":89,"speed":84,"mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":433,"seen":54.1,"rssi":-28.3},
{"hex":"8960e8","squawk":"5635","flight":"UAE74 ","lat":50.015762,"lon":8.552495,"nucp":7,"seen_pos":8.4,"altitude":37000,"vert_rate":0,"track":76,"speed":506,"category":"A5","mlat":[],"tisb":[],"messages":1694,"seen":0.3,"rssi":-18.3},
{"hex":"3d2ad2","squawk":"7000","lat":49.270702,"lon":12.006177,"nucp":0,"seen_pos":3.4,"altitude":8600,"vert_rate":0,"track":314,"speed":132,"mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":804,"seen":1.0,"rssi":-27.7},
{"hex":"3c5eee","squawk":"1000","flight":"GWI3865 ","lat":48.136688,"lon":9.207161,"nucp":7,"seen_pos":1.2,"altitude":34000,"vert_rate":0,"track":5,"speed":517,"category":"A3","mlat":[],"tisb":[],"messages":3806,"seen":0.1,"rssi":-14.2},
{"hex":"44b994","squawk":"0117","flight":"OONLT ","altitude":27000,"vert_rate":0,"track":152,"speed":242,"category":"A1","mlat":[],"tisb":[],"messages":401,"seen":0.1,"rssi":-24.6},
{"hex":"3d20e4","mlat":[],"tisb":[],"messages":23,"seen":159.4,"rssi":-17.4},
{"hex":"3c48f3","squawk":"5536","flight":"EWG1WN ","lat":48.305328,"lon":8.953294,"nucp":7,"seen_pos":0.2,"altitude":36000,"vert_rate":-64,"track":13,"speed":493,"category":"A0","mlat":[],"tisb":[],"messages":3942,"seen":0.0,"rssi":-15.3},
{"hex":"4ca994","squawk":"1000","flight":"AZA6BF ","lat":48.282538,"lon":11.309268,"nucp":6,"seen_pos":0.1,"altitude":34275,"vert_rate":-1024,"track":355,"speed":483,"category":"A3","mlat":[],"tisb":[],"messages":8784,"seen":0.1,"rssi":-5.4},
{"hex":"4841db","squawk":"3103","flight":"TRA494J ","lat":47.886378,"lon":9.966501,"nucp":5,"seen_pos":1.0,"altitude":38000,"vert_rate":0,"track":317,"speed":459,"category":"A0","mlat":[],"tisb":[],"messages":10189,"seen":0.1,"rssi":-11.4},
{"hex":"3c6678","squawk":"0223","flight":"DLH327 ","lat":48.543686,"lon":11.051964,"nucp":7,"seen_pos":1.8,"altitude":27975,"vert_rate":-320,"track":343,"speed":468,"category":"A0","mlat":[],"tisb":[],"messages":7484,"seen":0.1,"rssi":-4.1},
{"hex":"3ff1df","mlat":[],"tisb":[],"messages":74,"seen":271.6,"rssi":-24.4},
{"hex":"3c4909","squawk":"0611","flight":"BER874X ","lat":49.214840,"lon":8.853246,"nucp":7,"seen_pos":2.4,"altitude":37000,"vert_rate":0,"track":156,"speed":419,"category":"A3","mlat":[],"tisb":[],"messages":2960,"seen":0.1,"rssi":-15.5},
{"hex":"3c6754","squawk":"1000","flight":"EWG2CA ","lat":49.724726,"lon":11.471137,"nucp":7,"seen_pos":1.3,"altitude":35975,"vert_rate":0,"track":306,"speed":448,"category":"A0","mlat":[],"tisb":[],"messages":4531,"seen":0.1,"rssi":-12.9},
{"hex":"3d0f87","squawk":"5577","lat":47.618982,"lon":10.146578,"nucp":0,"seen_pos":8.3,"altitude":7125,"vert_rate":0,"track":151,"speed":145,"mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":1000,"seen":2.6,"rssi":-25.0},
{"hex":"471f89","squawk":"0636","lat":51.502929,"lon":11.778717,"nucp":7,"seen_pos":15.9,"altitude":37050,"vert_rate":0,"track":98,"speed":452,"mlat":[],"tisb":[],"messages":578,"seen":0.9,"rssi":-24.5},
{"hex":"4ca8ed","squawk":"7651","lat":47.331429,"lon":7.750854,"nucp":6,"seen_pos":18.1,"altitude":35000,"vert_rate":128,"track":153,"speed":424,"mlat":[],"tisb":[],"messages":3334,"seen":0.7,"rssi":-23.7},
{"hex":"3003ad","squawk":"6456","flight":"DLH1CN ","lat":49.822815,"lon":11.286212,"nucp":6,"seen_pos":9.4,"altitude":31300,"vert_rate":960,"track":357,"speed":472,"category":"A3","mlat":[],"tisb":[],"messages":8112,"seen":0.5,"rssi":-21.2},
{"hex":"3ff203","squawk":"7000","lat":47.776154,"lon":10.568367,"nucp":0,"seen_pos":12.1,"altitude":5525,"track":191,"speed":84,"mlat":[],"tisb":[],"messages":1975,"seen":1.2,"rssi":-23.3},
{"hex":"471f8c","squawk":"4726","flight":"WZZ4592 ","lat":49.087463,"lon":8.081994,"nucp":6,"seen_pos":10.9,"altitude":35000,"vert_rate":0,"track":123,"speed":443,"category":"A0","mlat":[],"tisb":[],"messages":1990,"seen":0.0,"rssi":-19.2},
{"hex":"3c6dd4","squawk":"0271","flight":"GWI5407 ","lat":48.648951,"lon":9.497825,"nucp":7,"seen_pos":0.7,"altitude":33150,"vert_rate":-1536,"track":331,"speed":490,"category":"A0","mlat":[],"tisb":[],"messages":12269,"seen":0.1,"rssi":-10.6},
{"hex":"3d3282","squawk":"7000","flight":"DERJM ","lat":48.489882,"lon":11.185817,"nucp":0,"seen_pos":2.3,"altitude":4000,"vert_rate":64,"track":270,"speed":114,"category":"A0","mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":1919,"seen":0.1,"rssi":-10.5},
{"hex":"3c6445","mlat":[],"tisb":[],"messages":2806,"seen":59.9,"rssi":-26.4},
{"hex":"3c4586","altitude":22900,"mlat":[],"tisb":[],"messages":1948,"seen":56.1,"rssi":-24.1},
{"hex":"49124c","squawk":"3174","lat":48.723295,"lon":7.821832,"nucp":0,"seen_pos":8.3,"altitude":37000,"vert_rate":64,"track":159,"speed":388,"mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":2192,"seen":0.0,"rssi":-24.4},
{"hex":"3d3d35","squawk":"7000","altitude":2800,"mlat":[],"tisb":[],"messages":387,"seen":0.4,"rssi":-8.5},
{"hex":"39b160","squawk":"1000","flight":"HOP4416 ","lat":48.116905,"lon":12.335815,"nucp":0,"seen_pos":6.1,"altitude":34700,"vert_rate":-1344,"track":52,"speed":481,"mlat":["lat","lon","track","speed","vert_rate"],"tisb":[],"messages":10839,"seen":0.0,"rssi":-11.8},
{"hex":"4b160e","squawk":"1000","flight":"SWR1247 ","lat":49.933141,"lon":10.833410,"nucp":7,"seen_pos":2.8,"altitude":39025,"vert_rate":0,"track":207,"speed":424,"category":"A0","mlat":[],"tisb":[],"messages":3137,"seen":0.1,"rssi":-17.3},
