I plan to run the 1090 and 768 SDR dongles from 1 RaspPi3 and packed in an outdoor weatherproof box - can I use a 1/4 DIY antenna to feed both dongles? I know one of the dongles won’t have the ideal antenna length but if I’m okay with the reduced range, will it work?
I’m guessing there will be too much signal loss going through a splitter but if not, what kind of antenna splitter is recommended?
If it is a DIY 1/4 wavelength, then why not 2 separate antenns? This will simplify install, and give optimum performance. No splitter losses and no mismatched antenna.
Looking at your stats page it appears that other stations nearby are seeing significantly more aircraft and significantly more position reports over much, much longer range.
At present, it appears you have insufficient signal for one system. I would suggest fixing this before contemplating how to feed two systems with one antenna.
If you can tolerate that, you’ll need a splitter/combiner with reasonable isolation (a $5 tee splitter is not going to be sufficient). Look for a splitter which actually quotes an isolation figure; anything more than 15dB should be fine. You can often find suitable Minicircuits splitters secondhand (new, they run to $80+)
Thanks for all the quick replies. My current setup is using the included SDR antennas that have been clipped for 1090 / 978 and they are sitting on small food cans (indoors) - I was using this setup to see if I could get the software running. I’m not interested in a pricey splitter so I’ll just drill another hole and add another DIY antenna.
Once I get the outdoor enclosure tested/working, I’ll move it to a small town airport on the Texas coast.
Using a splitter - yes.
As we know, a splitter ‘splits’ the signal and put half on each output port - hence the 3dB attenuation (in a perfect world).
This is fine if you want the same signal to input to two receivers.
In this case the OP wants to run the receivers on different frequencies, so a diplexer would be a better choice than a splitter.
I am of course ignoring the practicality of building it. ‘Normal’ components don’t behave predictably at GHz freqs.
Why? That’s pretty normal for good quality RF components that have predictable, documented, performance at GHz frequencies. It’s not just a simple tee.
(take a look at the prices for high-power splitters if you want a real shock)
Instead of spending $80 to split one antenna to two dongles (1090 & 978), I will rather purchase 2 x Flightaware antennas in this price, one for 1090 other for 978
Yes, that’s why I’m not using the Pro Stick Plus. I don’t need the filter in the dongle. This is a lot cleaner setup then the 2 RTL-SDR v3 I was using with a RTL-SDR ADSB LNA/filter - so I was getting double dinged by the filters in both the splitter and the LNA. I did som calculations using heywhatsthat.com and appear to be getting the theoretical range I should on 1090 and close to that on 978 (not nearly the number of targets so harder to evaluate.
I’m finding a surprising number of small jets and turboprops broadcasting both systems.
Day before yestrrday I landed to this diplixer on amazon, and it looked very promising so I decided to ask if any one is using it, but I chose wrong thread
The ProStickPlus has the filter directly after the LNA in the signal path.
It is beneficial for receiving 1090 MHz if only to suppress noise coming from the LNA.
It does not reduce your SNR, rather probably improves it.
Getting rid of attenuation before the LNA is much more important.
But not overloading the LNA with mobile signals is also important, which i’m sure this diplexer takes care of.
6 dB is still a rather big hit to take, when you could have only 2 dB attenuation with just a SAW filter in front of the LNA.
If that reduced performance is worth receiving UAT, then the diplexer works for you.
If you really have to work with a single antenna plus diplexer, i could imagine using a rtl-sdr blog (or other brand) wideband amplfiier near the antenna.
Just to reiterate, that’s not really how signal quality works, once you are past the LNA a saw filter most likely improves signal quality because it cleans up the noise from the LNA.
