SDR RF Testing using signal generator
I have a failure at a remote site. Hostile environment for testing, so I brought the system home but have no RF from planes due location. I’m using Flightaware Pro-stick plus V1.0 and PiAware (SD Card) 10.0.1. I have some other SDR RXes as well and will replace the Pro stick if it is defective with one of them.
So I want to see if the SDR is receiving using a signal generator. Is there a pin I can hook to a scope? Or any way I can do a command line update of RSSI even if no packets being decoded? Being a ham I would normally hook up my RF generator and scope a level somewhere!
Whenever I search for RSSI on the SDR, even using AI(!) I just get results saying it can be output along with decoded packets, but I have no way of getting packets, just RF!
Any help really appreciated, other wise I’ll be back to balancing all my test gear at the top of a ladder!
73 de Nigel, ve3id
If you want to do this then use an SDR receiver program like SDR# or SDR Console under windows.
You can then tune to 1090MHz and look at the raw RF signal and see the RSSI on the display.
Windows does not run on my raspberry pi!
With a ‘scope and a RF signal generator, you could:
a) run rtl_sdr from the command line to stream samples and, more importantly, initialize the tuner (you can pass /dev/null as the output filename to discard the captured samples)
b) feed in a (low level!! maybe -50dBm) RF signal at your tuned frequency with a signal generator
c) probe the differential signal on pins 12/13 of the R860T to see if you have a good IF signal at around ~3.5MHz (this should be a frequency-downshifted copy of your RF input). I’m not sure how accessible those pins are. They’re the two pins on the opposite corner from the pin-1 marker.
Alternatively, you could do just (b) and run e.g. CubicSDR on the Pi to look at the digitized signal.
which option is easier depends a lot on what equipment you have, and whether you’re more comfortable with hardware or software
