pi@piaware:~ $ sudo raspi-config
Welcome to fdisk (util-linux 2.33.1).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Command (m for help): Disk /dev/mmcblk0: 7.4 GiB, 7948206080 bytes, 15523840 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xeda531dc
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 8192 334116 325925 159.1M c W95 FAT32 (LBA)
/dev/mmcblk0p2 335872 15523839 15187968 7.2G 83 Linux
Command (m for help): Partition number (1,2, default 2):
Partition 2 has been deleted.
Command (m for help): Partition type
p primary (1 primary, 0 extended, 3 free)
e extended (container for logical partitions)
Select (default p): Partition number (2-4, default 2): First sector (2048-15523839, default 2048): Last sector, +/-sectors or +/-size{K,M,G,T,P} (335872-15523839, default 15523839):
Created a new partition 2 of type ‘Linux’ and of size 7.2 GiB.
Partition #2 contains a ext4 signature.
Disklabel type: dos
Command (m for help): The partition table has been altered.
Syncing disks.
I tried and it didn’t change unfortunately, but thanks for the answer! I’m trying here Rs.
this happened with 5.0 when it was 4.0 the SD was normal.
