I was just wondering if it was ok just put an adapter to the bottom of an AF antenna and then add the bias tee right before the NooElec USB stick. I’ve got both a 3.5v and 5v transformers to try.
Some thing like this. Pls ignore the morning dew on the antenna base. The connection is dry and this is just to show how I’d like to install it.
That’s a good way to install it if you manage to weatherproof the LNA.
Especially with your problems i would try and get it running indoors first.
As i wrote earlier it should be at least as good as before.
There have been defective units shipped, usually it’s not a problem to get a replacement.
I didn’t have another small sma2sma(like between the bias tee and the nooelrc) so I just used the ones I had at the antenna to connect the LNA and bias tee for testing.
I remembered there was some discussion about 50 ohm and 75 ohm connectors. The centre pin is a different size so you can’t mix them. Maybe your problem?
There’s a small green LED on the pcb that should be brightly lit when there’s 5V present.
I’ve modified mine so it has a USB cable soldered directly to the pcb, that way there’s no need for a bias-T circuit.
I’m actually starting to doubt the bias tee now too. It may in fact just be a wide band amplifier. Trusting in my google search might have been a bad idea. I have since ordered a bias tee that you had linked to. Should be here in a month from China.
So you didn’t get born with all this knowledge, like the rest of us? LOL
This is why this is a hobby, we all lean from each other here.
For now you can take out the preamp that has no power connected to it, see what results you get.
Alternately you can solder a wire between the positive pads of the preamps (just one because the negative is already connected between them with the shielded cables), but my hunch is that is not needed.
