The GET /airports/{id}/flights/arrivals operator is limited by 10 days in the past. Are there alternatives to retrieve more than 10 days of arrival flight history for a specific airport?
The GET /history/flights/{ident} method allows for longer history retrieval, but you must know the ident of the aircraft.
If you require longer term history by airport, then you will need to request a custom data report from our data team. Depending on your needs, a rapid report by airport may also give you a less expensive report.
Thanks @bovineone! I will give it a try. Hopefully in the future the history accessible with the GET /airports/{id}/flights/ will be extended to 1 month.
