OK, I think I can declare this experiment a success (running piaware running on Ubuntu 16 on VMware Player 6 on WIndows 10 (32-bit) on Asus Eee PC netbook circa 2010 with Atom CPU). Setting the VM’s memory size to the minimum (512 MB) and not running any other apps on the host laptop seems to help.
I plan to get piaware / dump1090-fa running on a RPi, as it would consume much less power than the Asus netbook. But this was an interesting experiment, and I learned a lot in the process. Thanks to all of you for your kind help and information throughout this process.
Active: active (running) since Thu 2019-03-07 03:55:32 PST; 42min ago
Main PID: 777 (piaware)
Mar 07 04:21:11 ubuntu piaware[777]: 145 msgs recv'd from dump1090-fa (57 in last 5m); 145 msgs sent to FlightAware
Mar 07 04:26:11 ubuntu piaware[777]: 204 msgs recv'd from dump1090-fa (59 in last 5m); 204 msgs sent to FlightAware
Mar 07 04:26:42 ubuntu piaware[777]: mlat-client(913): Receiver status: connected
Mar 07 04:26:42 ubuntu piaware[777]: mlat-client(913): Server status: clock unstable
Mar 07 04:26:42 ubuntu piaware[777]: mlat-client(913): Receiver: 3.1 msg/s received 1.7 msg/s processed (56%)
Mar 07 04:26:42 ubuntu piaware[777]: mlat-client(913): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
Mar 07 04:26:42 ubuntu piaware[777]: mlat-client(913): Aircraft: 0 of 0 Mode S, 1 of 1 ADS-B used
Mar 07 04:26:42 ubuntu piaware[777]: mlat-client(913): Out-of-order timestamps: 1
Mar 07 04:31:11 ubuntu piaware[777]: 212 msgs recv'd from dump1090-fa (8 in last 5m); 212 msgs sent to FlightAware
Mar 07 04:36:11 ubuntu piaware[777]: 238 msgs recv'd from dump1090-fa (26 in last 5m); 238 msgs sent to FlightAware
Active: active (running) since Thu 2019-03-07 03:55:32 PST; 46min ago
├─777 /usr/bin/piaware -p /run/piaware/piaware.pid -plainlog -statusfile /run/piaware/status.json
├─910 /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout
└─913 /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,loca
Mar 07 04:41:11 ubuntu piaware[777]: 313 msgs recv'd from dump1090-fa (75 in last 5m); 313 msgs sent to FlightAware
Mar 07 04:41:43 ubuntu piaware[777]: mlat-client(913): Receiver status: connected
Mar 07 04:41:43 ubuntu piaware[777]: mlat-client(913): Server status: clock unstable
Mar 07 04:41:43 ubuntu piaware[777]: mlat-client(913): Receiver: 4.6 msg/s received 2.7 msg/s processed (60%)
Mar 07 04:41:43 ubuntu piaware[777]: mlat-client(913): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
Mar 07 04:41:43 ubuntu piaware[777]: mlat-client(913): Aircraft: 1 of 1 Mode S, 2 of 2 ADS-B used
Mar 07 04:41:43 ubuntu piaware[777]: mlat-client(913): Out-of-order timestamps: 1
Active: active (running) since Thu 2019-03-07 03:55:32 PST; 1h 1min ago
Mar 07 04:46:11 ubuntu piaware[777]: 397 msgs recv'd from dump1090-fa (84 in last 5m); 397 msgs sent to FlightAware
Mar 07 04:51:11 ubuntu piaware[777]: 460 msgs recv'd from dump1090-fa (63 in last 5m); 460 msgs sent to FlightAware
Mar 07 04:56:11 ubuntu piaware[777]: 504 msgs recv'd from dump1090-fa (44 in last 5m); 504 msgs sent to FlightAware
Mar 07 04:56:43 ubuntu piaware[777]: mlat-client(913): Receiver status: connected
Mar 07 04:56:43 ubuntu piaware[777]: mlat-client(913): Server status: not synchronized with any nearby receivers
Mar 07 04:56:43 ubuntu piaware[777]: mlat-client(913): Receiver: 1.9 msg/s received 1.0 msg/s processed (54%)
Mar 07 04:56:43 ubuntu piaware[777]: mlat-client(913): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
Mar 07 04:56:43 ubuntu piaware[777]: mlat-client(913): Aircraft: 1 of 1 Mode S, 0 of 0 ADS-B used
Active: active (running) since Thu 2019-03-07 03:55:32 PST; 1h 17min ago
Mar 07 05:01:11 ubuntu piaware[777]: 518 msgs recv'd from dump1090-fa (14 in last 5m); 518 msgs sent to FlightAware
Mar 07 05:06:11 ubuntu piaware[777]: 529 msgs recv'd from dump1090-fa (11 in last 5m); 529 msgs sent to FlightAware
Mar 07 05:11:11 ubuntu piaware[777]: 561 msgs recv'd from dump1090-fa (32 in last 5m); 561 msgs sent to FlightAware
Mar 07 05:11:43 ubuntu piaware[777]: mlat-client(913): Receiver status: connected
Mar 07 05:11:43 ubuntu piaware[777]: mlat-client(913): Server status: not synchronized with any nearby receivers
Mar 07 05:11:43 ubuntu piaware[777]: mlat-client(913): Receiver: 0.3 msg/s received 0.1 msg/s processed (34%)
Mar 07 05:11:43 ubuntu piaware[777]: mlat-client(913): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
Mar 07 05:11:43 ubuntu piaware[777]: mlat-client(913): Aircraft: 0 of 1 Mode S, 1 of 1 ADS-B used
Mar 07 05:11:43 ubuntu piaware[777]: mlat-client(913): Out-of-order timestamps: 1
Active: active (running) since Thu 2019-03-07 03:55:32 PST; 1h 31min ago
Mar 07 05:16:11 ubuntu piaware[777]: 635 msgs recv'd from dump1090-fa (74 in last 5m); 635 msgs sent to FlightAware
Mar 07 05:21:11 ubuntu piaware[777]: 793 msgs recv'd from dump1090-fa (158 in last 5m); 793 msgs sent to FlightAware
Mar 07 05:26:11 ubuntu piaware[777]: 945 msgs recv'd from dump1090-fa (152 in last 5m); 945 msgs sent to FlightAware
Mar 07 05:26:44 ubuntu piaware[777]: mlat-client(913): Receiver status: connected
Mar 07 05:26:44 ubuntu piaware[777]: mlat-client(913): Server status: synchronized with 120 nearby receivers
Mar 07 05:26:44 ubuntu piaware[777]: mlat-client(913): Receiver: 13.1 msg/s received 6.9 msg/s processed (52%)
Mar 07 05:26:44 ubuntu piaware[777]: mlat-client(913): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.1kB/s UDP to server
Mar 07 05:26:44 ubuntu piaware[777]: mlat-client(913): Results: 2.0 positions/minute
Mar 07 05:26:44 ubuntu piaware[777]: mlat-client(913): Aircraft: 1 of 1 Mode S, 1 of 1 ADS-B used
Active: active (running) since Thu 2019-03-07 03:55:32 PST; 1h 46min ago
Mar 07 05:31:11 ubuntu piaware[777]: 1023 msgs recv'd from dump1090-fa (78 in last 5m); 1023 msgs sent to FlightAware
Mar 07 05:36:11 ubuntu piaware[777]: 1123 msgs recv'd from dump1090-fa (100 in last 5m); 1123 msgs sent to FlightAware
Mar 07 05:41:11 ubuntu piaware[777]: 1329 msgs recv'd from dump1090-fa (206 in last 5m); 1329 msgs sent to FlightAware
Mar 07 05:41:44 ubuntu piaware[777]: mlat-client(913): Receiver status: connected
Mar 07 05:41:44 ubuntu piaware[777]: mlat-client(913): Server status: synchronized with 187 nearby receivers
Mar 07 05:41:44 ubuntu piaware[777]: mlat-client(913): Receiver: 11.4 msg/s received 5.5 msg/s processed (48%)
Mar 07 05:41:44 ubuntu piaware[777]: mlat-client(913): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.1kB/s UDP to server
Mar 07 05:41:44 ubuntu piaware[777]: mlat-client(913): Results: 2.2 positions/minute
Mar 07 05:41:44 ubuntu piaware[777]: mlat-client(913): Aircraft: 0 of 3 Mode S, 4 of 4 ADS-B used
Active: active (running) since Thu 2019-03-07 03:55:32 PST; 2h 3min ago
Mar 07 05:46:11 ubuntu piaware[777]: 1479 msgs recv'd from dump1090-fa (150 in last 5m); 1479 msgs sent to FlightAware
Mar 07 05:51:11 ubuntu piaware[777]: 1599 msgs recv'd from dump1090-fa (120 in last 5m); 1599 msgs sent to FlightAware
Mar 07 05:56:11 ubuntu piaware[777]: 1747 msgs recv'd from dump1090-fa (148 in last 5m); 1747 msgs sent to FlightAware
Mar 07 05:56:45 ubuntu piaware[777]: mlat-client(913): Receiver status: connected
Mar 07 05:56:45 ubuntu piaware[777]: mlat-client(913): Server status: clock unstable
Mar 07 05:56:45 ubuntu piaware[777]: mlat-client(913): Receiver: 13.1 msg/s received 5.9 msg/s processed (45%)
Mar 07 05:56:45 ubuntu piaware[777]: mlat-client(913): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.1kB/s UDP to server
Mar 07 05:56:45 ubuntu piaware[777]: mlat-client(913): Results: 3.9 positions/minute
Mar 07 05:56:45 ubuntu piaware[777]: mlat-client(913): Aircraft: 0 of 0 Mode S, 3 of 3 ADS-B used
Active: active (running) since Thu 2019-03-07 03:55:32 PST; 2h 19min ago
Mar 07 06:01:11 ubuntu piaware[777]: 1855 msgs recv'd from dump1090-fa (108 in last 5m); 1855 msgs sent to FlightAware
Mar 07 06:06:11 ubuntu piaware[777]: 2041 msgs recv'd from dump1090-fa (186 in last 5m); 2041 msgs sent to FlightAware
Mar 07 06:11:11 ubuntu piaware[777]: 2193 msgs recv'd from dump1090-fa (152 in last 5m); 2193 msgs sent to FlightAware
Mar 07 06:11:45 ubuntu piaware[777]: mlat-client(913): Receiver status: connected
Mar 07 06:11:45 ubuntu piaware[777]: mlat-client(913): Server status: synchronized with 169 nearby receivers
Mar 07 06:11:45 ubuntu piaware[777]: mlat-client(913): Receiver: 13.0 msg/s received 4.9 msg/s processed (37%)
Mar 07 06:11:45 ubuntu piaware[777]: mlat-client(913): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.1kB/s UDP to server
Mar 07 06:11:45 ubuntu piaware[777]: mlat-client(913): Results: 1.3 positions/minute
Mar 07 06:11:45 ubuntu piaware[777]: mlat-client(913): Aircraft: 1 of 2 Mode S, 4 of 4 ADS-B used
Active: active (running) since Thu 2019-03-07 03:55:32 PST; 2h 31min ago
Mar 07 06:16:11 ubuntu piaware[777]: 2330 msgs recv'd from dump1090-fa (137 in last 5m); 2330 msgs sent to FlightAware
Mar 07 06:21:11 ubuntu piaware[777]: 2572 msgs recv'd from dump1090-fa (242 in last 5m); 2572 msgs sent to FlightAware
Mar 07 06:26:11 ubuntu piaware[777]: 2826 msgs recv'd from dump1090-fa (254 in last 5m); 2826 msgs sent to FlightAware
Mar 07 06:26:46 ubuntu piaware[777]: mlat-client(913): Receiver status: connected
Mar 07 06:26:46 ubuntu piaware[777]: mlat-client(913): Server status: clock unstable
Mar 07 06:26:46 ubuntu piaware[777]: mlat-client(913): Receiver: 35.5 msg/s received 11.5 msg/s processed (32%)
Mar 07 06:26:46 ubuntu piaware[777]: mlat-client(913): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.2kB/s UDP to server
Mar 07 06:26:46 ubuntu piaware[777]: mlat-client(913): Aircraft: 0 of 2 Mode S, 4 of 4 ADS-B used
Active: active (running) since Thu 2019-03-07 03:55:32 PST; 2h 46min ago
Mar 07 06:31:11 ubuntu piaware[777]: 3039 msgs recv'd from dump1090-fa (213 in last 5m); 3039 msgs sent to FlightAware
Mar 07 06:36:11 ubuntu piaware[777]: 3221 msgs recv'd from dump1090-fa (182 in last 5m); 3221 msgs sent to FlightAware
Mar 07 06:41:11 ubuntu piaware[777]: 3472 msgs recv'd from dump1090-fa (251 in last 5m); 3472 msgs sent to FlightAware
Mar 07 06:41:47 ubuntu piaware[777]: mlat-client(913): Receiver status: connected
Mar 07 06:41:47 ubuntu piaware[777]: mlat-client(913): Server status: synchronized with 224 nearby receivers
Mar 07 06:41:47 ubuntu piaware[777]: mlat-client(913): Receiver: 32.5 msg/s received 11.2 msg/s processed (34%)
Mar 07 06:41:47 ubuntu piaware[777]: mlat-client(913): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.1kB/s UDP to server
Mar 07 06:41:47 ubuntu piaware[777]: mlat-client(913): Results: 0.9 positions/minute
Mar 07 06:41:47 ubuntu piaware[777]: mlat-client(913): Aircraft: 4 of 5 Mode S, 4 of 4 ADS-B used
Active: active (running) since Thu 2019-03-07 03:55:32 PST; 3h 6min ago
Mar 07 06:46:11 ubuntu piaware[777]: 3715 msgs recv'd from dump1090-fa (243 in last 5m); 3715 msgs sent to FlightAware
Mar 07 06:51:11 ubuntu piaware[777]: 3994 msgs recv'd from dump1090-fa (279 in last 5m); 3994 msgs sent to FlightAware
Mar 07 06:56:11 ubuntu piaware[777]: 4356 msgs recv'd from dump1090-fa (362 in last 5m); 4356 msgs sent to FlightAware
Mar 07 06:56:47 ubuntu piaware[777]: mlat-client(913): Receiver status: connected
Mar 07 06:56:47 ubuntu piaware[777]: mlat-client(913): Server status: clock unstable
Mar 07 06:56:47 ubuntu piaware[777]: mlat-client(913): Receiver: 37.8 msg/s received 11.4 msg/s processed (30%)
Mar 07 06:56:47 ubuntu piaware[777]: mlat-client(913): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.1kB/s UDP to server
Mar 07 06:56:47 ubuntu piaware[777]: mlat-client(913): Results: 5.7 positions/minute
Mar 07 06:56:47 ubuntu piaware[777]: mlat-client(913): Aircraft: 2 of 2 Mode S, 7 of 8 ADS-B used
Mar 07 07:01:11 ubuntu piaware[777]: 4636 msgs recv'd from dump1090-fa (280 in last 5m); 4636 msgs sent to FlightAware
Active: active (running) since Thu 2019-03-07 03:55:32 PST; 3h 16min ago
Mar 07 07:06:11 ubuntu piaware[777]: 4950 msgs recv'd from dump1090-fa (314 in last 5m); 4950 msgs sent to FlightAware
Mar 07 07:11:11 ubuntu piaware[777]: 5318 msgs recv'd from dump1090-fa (368 in last 5m); 5318 msgs sent to FlightAware
Mar 07 07:11:47 ubuntu piaware[777]: mlat-client(913): Receiver status: connected
Mar 07 07:11:47 ubuntu piaware[777]: mlat-client(913): Server status: synchronized with 254 nearby receivers
Mar 07 07:11:47 ubuntu piaware[777]: mlat-client(913): Receiver: 47.8 msg/s received 17.1 msg/s processed (36%)
Mar 07 07:11:47 ubuntu piaware[777]: mlat-client(913): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.2kB/s UDP to server
Mar 07 07:11:48 ubuntu piaware[777]: mlat-client(913): Results: 1.9 positions/minute
Mar 07 07:11:48 ubuntu piaware[777]: mlat-client(913): Aircraft: 2 of 4 Mode S, 7 of 7 ADS-B used
Active: active (running) since Thu 2019-03-07 03:55:32 PST; 3h 32min ago
Mar 07 07:16:11 ubuntu piaware[777]: 5604 msgs recv'd from dump1090-fa (286 in last 5m); 5604 msgs sent to FlightAware
Mar 07 07:21:11 ubuntu piaware[777]: 5958 msgs recv'd from dump1090-fa (354 in last 5m); 5958 msgs sent to FlightAware
Mar 07 07:26:11 ubuntu piaware[777]: 6431 msgs recv'd from dump1090-fa (473 in last 5m); 6431 msgs sent to FlightAware
Mar 07 07:26:48 ubuntu piaware[777]: mlat-client(913): Receiver status: connected
Mar 07 07:26:48 ubuntu piaware[777]: mlat-client(913): Server status: synchronized with 223 nearby receivers
Mar 07 07:26:48 ubuntu piaware[777]: mlat-client(913): Receiver: 58.0 msg/s received 15.7 msg/s processed (27%)
Mar 07 07:26:48 ubuntu piaware[777]: mlat-client(913): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.2kB/s UDP to server
Mar 07 07:26:48 ubuntu piaware[777]: mlat-client(913): Results: 6.0 positions/minute
Mar 07 07:26:48 ubuntu piaware[777]: mlat-client(913): Aircraft: 3 of 7 Mode S, 5 of 6 ADS-B used
Active: active (running) since Thu 2019-03-07 03:55:32 PST; 3h 46min ago
Mar 07 07:31:11 ubuntu piaware[777]: 6905 msgs recv'd from dump1090-fa (474 in last 5m); 6905 msgs sent to FlightAware
Mar 07 07:36:11 ubuntu piaware[777]: 7415 msgs recv'd from dump1090-fa (510 in last 5m); 7415 msgs sent to FlightAware
Mar 07 07:41:11 ubuntu piaware[777]: 7793 msgs recv'd from dump1090-fa (378 in last 5m); 7793 msgs sent to FlightAware
Mar 07 07:41:48 ubuntu piaware[777]: mlat-client(913): Receiver status: connected
Mar 07 07:41:48 ubuntu piaware[777]: mlat-client(913): Server status: synchronized with 16 nearby receivers
Mar 07 07:41:48 ubuntu piaware[777]: mlat-client(913): Receiver: 78.2 msg/s received 21.3 msg/s processed (27%)
Mar 07 07:41:48 ubuntu piaware[777]: mlat-client(913): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.3kB/s UDP to server
Mar 07 07:41:48 ubuntu piaware[777]: mlat-client(913): Results: 7.9 positions/minute
Mar 07 07:41:48 ubuntu piaware[777]: mlat-client(913): Aircraft: 3 of 8 Mode S, 7 of 7 ADS-B used
Active: active (running) since Thu 2019-03-07 03:55:32 PST; 4h 1min ago
Mar 07 07:46:11 ubuntu piaware[777]: 8231 msgs recv'd from dump1090-fa (438 in last 5m); 8231 msgs sent to FlightAware
Mar 07 07:51:11 ubuntu piaware[777]: 8650 msgs recv'd from dump1090-fa (419 in last 5m); 8650 msgs sent to FlightAware
Mar 07 07:56:11 ubuntu piaware[777]: 9117 msgs recv'd from dump1090-fa (467 in last 5m); 9117 msgs sent to FlightAware
Mar 07 07:56:48 ubuntu piaware[777]: mlat-client(913): Receiver status: connected
Mar 07 07:56:48 ubuntu piaware[777]: mlat-client(913): Server status: synchronized with 279 nearby receivers
Mar 07 07:56:49 ubuntu piaware[777]: mlat-client(913): Receiver: 72.6 msg/s received 21.8 msg/s processed (30%)
Mar 07 07:56:49 ubuntu piaware[777]: mlat-client(913): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.3kB/s UDP to server
Mar 07 07:56:49 ubuntu piaware[777]: mlat-client(913): Results: 7.0 positions/minute
Mar 07 07:56:49 ubuntu piaware[777]: mlat-client(913): Aircraft: 4 of 13 Mode S, 10 of 10 ADS-B used
Active: active (running) since Thu 2019-03-07 03:55:32 PST; 4h 16min ago
Mar 07 08:01:11 ubuntu piaware[777]: 9649 msgs recv'd from dump1090-fa (532 in last 5m); 9649 msgs sent to FlightAware
Mar 07 08:06:11 ubuntu piaware[777]: 10238 msgs recv'd from dump1090-fa (589 in last 5m); 10238 msgs sent to FlightAware
Mar 07 08:11:11 ubuntu piaware[777]: 10687 msgs recv'd from dump1090-fa (449 in last 5m); 10687 msgs sent to FlightAware
Mar 07 08:11:49 ubuntu piaware[777]: mlat-client(913): Receiver status: connected
Mar 07 08:11:49 ubuntu piaware[777]: mlat-client(913): Server status: synchronized with 211 nearby receivers
Mar 07 08:11:49 ubuntu piaware[777]: mlat-client(913): Receiver: 83.1 msg/s received 21.4 msg/s processed (26%)
Mar 07 08:11:49 ubuntu piaware[777]: mlat-client(913): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.3kB/s UDP to server
Mar 07 08:11:49 ubuntu piaware[777]: mlat-client(913): Results: 5.5 positions/minute
Mar 07 08:11:49 ubuntu piaware[777]: mlat-client(913): Aircraft: 5 of 10 Mode S, 7 of 7 ADS-B used
cpk@ubuntu:~$ journalctl -u piaware | grep 'Receiver status\|Server status'
Mar 07 04:11:42 ubuntu piaware[777]: mlat-client(913): Receiver status: connected
Mar 07 04:11:42 ubuntu piaware[777]: mlat-client(913): Server status: not synchronized with any nearby receivers
