If there’s any interest, I’m sharing my experience with moving to an f2fs filesystem for my Piaware setup.
Goal: Install and test f2fs filesystem on SD card used with Raspberry PI. Based on write-ups in several places, but the one article that was the most useful to me for a Pi running Raspbian 9 (i.e. Debian Stretch version 9) is linked here: f2fs article A How-To f2fs was written up in the RaspberryPi forums back in 2013, link here. I look forward to the day when the Raspbian Team feels confident enough to distribute the Raspbian image on f2fs instead of ext4 - it “seems” stable.
There are many ways to create and copy successfully the root filesystem, I used the linked articles as a basis for doing it the way I wrote up here. If you have only one SD card and no way to attach a second to your Pi or a separate computer running Raspbian, then this exercise is probably not going to work for you. One way to improvise and adapt to that is to shrink the existing partition, create another partition, format that partition to a f2fs filesystem, copy the ext4 filesystem to the new one, and modify the boot to use the newly-created filesystem - all well beyond the scope of this writeup and only recommended for those of you that play in *nix every day.
Reason
The primary reason is the a concern for wear on the SD card in the Raspberry Pi. Writing logs is more than I had expected, I have better things to do than play “whack-a-mole” suppressing things I don’t want to see in the logs, and I do want to keep logs around that survive a reboot (planned or unplanned). I don’t want a hard-drive (SSD or spinning platters), I don’t want or expect my Pi to be a shop-floor level ruggedized process control system, but want to have reasonable levels of protection to supplement regular backups and to prolong the life of the Pi as long as possible.
Internet discussions on the robustness of SD cards range from “running my Pi from the attic located in Death Valley for years with no problems” to “OMG my Pi SD card died after a few days of running my smarthouse functions stuck in a refrigerator”. One of the biggest ‘wearpoints’ on a Pi is logging and temporary filesystems. There is enough written about how to put temporary and logging filesystems into memory instead of the SD card, or how to use utilities to buffer writes to these filesystems to happen in bigger chunks. Since f2fs has been around many years, and is baked into the Linux kernel since major release 3.something (Raspbian kernel is 4.9.something as of this document), and is used frequently in smartphones, I liked the idea of set f2fs up once and move on with other fun stuff.
It’s been running a few weeks so far, no issues that I can see. Your mileage (and my future experience) may vary.
Inventory
This is what I used
- Pi2
- Raspbian “stretch” for Pi installation
Linux pi2 4.9.59+ #1047 Sun Oct 29 11:47:10 GMT 2017 armv6l GNU/Linux
- Spare SD card onto which the existing card has already been cloned using
rpi-clone
utility, made available on the Pi using a USB SD card adapter
Steps
Pre-pend commands below with ‘sudo’ if not running as root. I tend to run as root when doing several tasks in a row, not necessarily a recommended best practice, be forewarned.
Install the f2fs toolsets
apt install f2fs-tools
Add the module to /etc/initramfs-tools/modules:
echo f2fs >> /etc/initramfs-tools/modules
update-initramfs -u
Re-format
Re-format the spare SD card’s Linux partition (this wipes out existing format on partition 2):
root@pi2:~# mkfs.f2fs /dev/sdb2
F2FS-tools: mkfs.f2fs Ver: 1.7.0 (2016-07-28)
Info: Debug level = 0
Info: Label =
Info: Trim is enabled
Info: Segments per section = 1
Info: Sections per zone = 1
Info: sector size = 512
Info: total sectors = 61769728 (30161 MB)
Info: zone aligned segment0 blkaddr: 512
Info: format version with
"Linux version 4.9.59+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1047 Sun Oct 29 11:47:10 GMT 2017"
Info: Discarding device
Info: This device doesn't support BLKSECDISCARD
Info: This device doesn't support BLKDISCARD
Info: Overprovision ratio = 1.160%
Info: Overprovision segments = 351 (GC reserved = 180)
Info: format successful
This takes a few seconds, informational messages are printed as shown.
Make a copy
Feel free to use whatever tool you are comfortable with for making complete copies. I use and swear by rsync
Make sure the source is as quiet as possible -
systemctl stop piware dump1090 pfclient fr24feed
Mount the freshly-formatted f2fs partition (I also display the currently mounted filesystems)-
mount /dev/sdb2 /mnt/clone
df -hPT
Filesystem Type Size Used Avail Use% Mounted on
/dev/root ext4 15G 1.2G 13G 8% /
devtmpfs devtmpfs 213M 0 213M 0% /dev
tmpfs tmpfs 218M 0 218M 0% /dev/shm
tmpfs tmpfs 218M 5.8M 212M 3% /run
tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs tmpfs 218M 0 218M 0% /sys/fs/cgroup
/dev/mmcblk0p1 vfat 42M 21M 21M 51% /boot
tmpfs tmpfs 44M 0 44M 0% /run/user/0
/dev/sdb2 f2fs 30G 206M 29G 1% /mnt/clone
and sync the local root partition to the new filesystem -
root@pi2:~# rsync -aWxh --stats / /mnt/clone/
Number of files: 44,019 (reg: 34,183, dir: 3,830, link: 6,005, special: 1)
Number of created files: 44,018 (reg: 34,183, dir: 3,829, link: 6,005, special: 1)
Number of deleted files: 0
Number of regular files transferred: 34,183
Total file size: 1.10G bytes
Total transferred file size: 1.10G bytes
Literal data: 1.10G bytes
Matched data: 0 bytes
File list size: 1.31M
File list generation time: 0.001 seconds
File list transfer time: 0.000 seconds
Total bytes sent: 1.10G
Total bytes received: 693.79K
sent 1.10G bytes received 693.79K bytes 4.48M bytes/sec
total size is 1.10G speedup is 1.00
The meaning of the rsync options:
- a: use the archive mode (several options rolled into one)
- x: sync only the filesystem specified, do not cross boundaries
- W: copy whole files only
- h: print statistics in human-readable form
- –stats: print statistics for the operation
Looks like the overhead for f2fs might be a little higher than for ext4 (the SD card I am using for the clone is 32GB, source is only 16GB).
/dev/sdb2 f2fs 30G 1.4G 28G 5% /mnt/clone
Make it bootable
Edit the cloned device’s /etc/fstab and change the mountpoints. First, identify the mountpoints:
root@pi2:/mnt/clone# blkid
/dev/mmcblk0p1: LABEL="boot" UUID="B60A-B262" TYPE="vfat" PARTUUID="cbe5fa9a-01"
/dev/mmcblk0p2: UUID="9a7608bd-5bff-4dfc-ac1d-63a956744162" TYPE="ext4" PARTUUID="cbe5fa9a-02"
/dev/mmcblk0: PTUUID="cbe5fa9a" PTTYPE="dos"
/dev/sdb1: LABEL="boot" UUID="B60A-B262" TYPE="vfat" PARTUUID="8c3d168f-01"
/dev/sdb2: UUID="6b5744b5-0bd5-47bc-ba38-318c2f4a3ba9" TYPE="f2fs" PARTUUID="8c3d168f-02"
Need to change the cloned device to use the PARTUUID information from lines 5 and 6 above, and the Linux root partition to use f2fs format:
Before:
root@pi2:/mnt/clone/etc# cat fstab
proc /proc proc defaults 0 0
PARTUUID=cbe5fa9a-01 /boot vfat defaults 0 2
PARTUUID=cbe5fa9a-02 / ext4 defaults,noatime 0 1
After:
PARTUUID=8c3d168f-01 /boot vfat defaults 0 2
PARTUUID=8c3d168f-02 / f2fs defaults,noatime 0 1
Mount and update the cloned /boot partition:
mount /dev/sdb1 /mnt/clone/boot
vi /mnt/clone/boot/cmdline.txt
Before:
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=8c3d168f-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
After:
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=8c3d168f-02 rootfstype=f2fs elevator=deadline fsck.repair=yes rootwait
Shutdown and Use New Card
Shutdown the Pi, replace the existing SD card with the one you just created, and boot. Might be a good idea to have a monitor hooked up to see if anything goes wrong.
