I appreciate the “if it’s not broke…” logic but we do not plan to build new packages for jessie forever (PiAware 6 might be the last ones) so you’ll be on an old version.
(Plus, if it’s on the network – even if not directly exposed to the world – you really do want security updates, and they’re no longer available for jessie)
I have stopped disturbing commissioned/running install for upgrade. Now I have started using a spare microSD Card and a spare Pi.
I write latest image to spare microSD card, slip it into spare Pi, install and configure feeders, graphs and any other required software, let it run for a while, and if all is ok, replace old card of main Pi with freshly prepared spare microSD card.
I wasn’t specifically referring to Pis running ADS-B, they are definitely external facing. A couple that spring to mind are ones that run little Christmas trees with flashing LEDs
This was just an experiment. It has no advantage as Buster is still supported. Although after running for 18 hrs, I did not notice any issues, but there are no warranties, and if you want to try it, do it on your own risk.
(1) Edited file /etc/apt/sources.list
1.1 - Added following line to add raspberrypi’s Bullseye repo: deb http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
1.2 - Commented out following line to comment out Flightaware’s Buster repo: #deb http://flightaware.com/mirror/raspbian/raspbian/ buster main contrib non-free rpi
I sucessfully ran an upgrade of my Raspberry 3B by changing the sources list from buster to bullseye, followed by apt update and apt upgrade
On that device the additional feeders for Radarbox and Planefinder are running, data is coming from readsb installed on the same Pi3 which catches the stream from my Jetvision device
In addition the WeeWX weather station is running on it.
All went fine, still working after reboot.
I only needed to manually start the weewx service it was flagged as “dead”.
As neither dump1090 nor piaware is running on it (this is going to FA directly from the Jetvision device) i cannot answer if this would work as well.
Update was done in approx 15-20 Minutes (did not check stop watch)
The Raspberry Imager with the (hidden) option to set the parameters for WiFi, hostname etc which can be opened by STRG-SHIFT-X seem to have an issue with the new image, even if it can be selected for installation.
After writing the image to the device, it shows an error that config.txt does not exist.
But it’s there.
Overclocking seem to be working. I used one of my spare Pi4 with 2Gig and the flag in config.txt
If you switch from buster to bullseye in the sources.list, the first command is obviously sufficient, that’s what i was using.
The main difference is the automatic resolution of dependency issues from what i found in other discussions.
But for me it was working flawless
I only needed to answer a couple of times if the existing config should be overwritten with a new default one.
I always selected “no” to keep my config files.
That can be a problem if the config structure changes, but it was not the case during my install/upgrade
quick correction after checking my history on the 3B. I needed to use a --fix-missing in between and utilized the update/upgrade again. But i did neither use dist nor full
Did somebody do something to server configuration this morning? I upgraded to bullseye a couple days ago. Without updating any of adsb software, everything was working fine. But this morning both dump1090-fa and dump978-fa quit working…
(1) Pi #1 with Piaware SD card image Buster on RPi model 4.
I upgraded it to Bullseye by adding bullseye repo to file /etc/apt/sources.list and then sudo apt-get update followed by sudo apt-get full-upgrade . It is 2 days now and is working ok. You can check it here: https://flightaware.com/adsb/stats/user/abcd567#stats-5252
(2) Pi #2 with Armbian Bullseye image on OrangePiPC.
The image was originally Bullseye, and no upgraging done by me. Working ok since one week. You can check it here:
(3) Pi #3 with Raspberry Pi OS Bullseye on RPi model 4.
The image was originally Bullseye, and no upgraging done by me. Working ok since two days You can check it here:
