I sucessfully ran an upgrade of my Raspberry 3B by changing the sources list from buster to bullseye, followed by apt update and apt upgrade
On that device the additional feeders for Radarbox and Planefinder are running, data is coming from readsb installed on the same Pi3 which catches the stream from my Jetvision device
In addition the WeeWX weather station is running on it.
All went fine, still working after reboot.
I only needed to manually start the weewx service it was flagged as “dead”.
As neither dump1090 nor piaware is running on it (this is going to FA directly from the Jetvision device) i cannot answer if this would work as well.
Update was done in approx 15-20 Minutes (did not check stop watch)
The Raspberry Imager with the (hidden) option to set the parameters for WiFi, hostname etc which can be opened by STRG-SHIFT-X seem to have an issue with the new image, even if it can be selected for installation.
After writing the image to the device, it shows an error that config.txt does not exist.
But it’s there.
Overclocking seem to be working. I used one of my spare Pi4 with 2Gig and the flag in config.txt
If you switch from buster to bullseye in the sources.list, the first command is obviously sufficient, that’s what i was using.
The main difference is the automatic resolution of dependency issues from what i found in other discussions.
But for me it was working flawless
I only needed to answer a couple of times if the existing config should be overwritten with a new default one.
I always selected “no” to keep my config files.
That can be a problem if the config structure changes, but it was not the case during my install/upgrade
quick correction after checking my history on the 3B. I needed to use a --fix-missing in between and utilized the update/upgrade again. But i did neither use dist nor full
Did somebody do something to server configuration this morning? I upgraded to bullseye a couple days ago. Without updating any of adsb software, everything was working fine. But this morning both dump1090-fa and dump978-fa quit working…
(1) Pi #1 with Piaware SD card image Buster on RPi model 4.
I upgraded it to Bullseye by adding bullseye repo to file /etc/apt/sources.list and then sudo apt-get update followed by sudo apt-get full-upgrade . It is 2 days now and is working ok. You can check it here: https://flightaware.com/adsb/stats/user/abcd567#stats-5252
(2) Pi #2 with Armbian Bullseye image on OrangePiPC.
The image was originally Bullseye, and no upgraging done by me. Working ok since one week. You can check it here:
(3) Pi #3 with Raspberry Pi OS Bullseye on RPi model 4.
The image was originally Bullseye, and no upgraging done by me. Working ok since two days You can check it here:
apt-listchanges: News
apt (2.1.16) unstable; urgency=medium
Automatically remove unused kernels on apt {dist,full}-upgrade. To revert
to previous behavior, set APT::Get::AutomaticRemove::Kernels to false or
pass --no-auto-remove to the command. apt-get remains unchanged.
Packages files can now set the Phased-Update-Percentage field to restrict
update rollout to a specified percentage of machines. Previously, this has
only been available to users of Ubuntu's update-manager tool. See
apt_preferences(5) for details and how to configure multiple systems to get
the same updates. Phased updates are disabled in chroots for now to not
break buildd-style setups.
-- Julian Andres Klode <jak@debian.org> Fri, 08 Jan 2021 22:01:50 +0100
apt (1.9.11) experimental; urgency=medium
apt(8) now waits for the lock indefinitely if connected to a tty, or
for 120 seconds if not.
I have 2 Piaware SD Card Buster installs, both with graphs & many other feeders. I have upgraded both to Bullseye, and both are working very smoothly, without any issues, during upgrade process, as well as during normal operation.
By the way I used:
sudo apt update
sudo apt full-upgrade
Each microSD card took about 30~35 minutes to upgrade.
Ah, that is interesting. The new names are not so easy to remember as the classic names but apparently were aimed at desktop type computers where adaptors can be added therefore names may change.
Understand you can be changed to old legacy names if required.
