Hi, Here is a simple python example using SOAPpy. A bit trick at first, til I figured out the HttpResponse stuff … Enjoy
import SOAPpy
class myHTTPTransport(SOAPpy.HTTPTransport):
username = None
passwd = None
@classmethod
def setAuthentication(cls,u,p):
cls.username = u
cls.passwd = p
def call(self, addr, data, namespace, soapaction=None, encoding=None,
http_proxy=None, config=SOAPpy.Config):
if not isinstance(addr, SOAPpy.SOAPAddress):
addr=SOAPAddress(addr, config)
if self.username != None:
addr.user = self.username+":"+self.passwd
return SOAPpy.HTTPTransport.call(self, addr, data, namespace, soapaction,
encoding, http_proxy, config)
wsdlFile = 'http://flightaware.com/commercial/directflight/data/wsdl1.xml'
myHTTPTransport.setAuthentication('USERNAME', 'CHANGE THIS TO YOUR API KEY')
server = SOAPpy.WSDL.Proxy(wsdlFile, transport=myHTTPTransport)
print server.FlightInfo(ident='AAL1684',howMany=1)
It’s not really that simple, is it?
Yep, works for me. Had to subclass the HTTPTransport in order to pass the credentials, but no problem after that. Looking through results like this
results = server.FlightInfo(ident='AAL121',howMany=1)
print results
for flight in results.flights:
print flight.ident + ' ' + str(time.strftime("%Y-%m-%dT%H:%M:%S", time.gmtime(flight.filed_departuretime))) + ' ' + str(flight.filed_ete) + ' ' + flight.origin + ' ' + flight.route + ' ' + flight.destination
Let me know if you have further questions.
