Hello,
This is my first time posting here. I’m trying to run through the sample code first before attempting my own project. I selected Python version that uses SOAPpy
from SOAPpy import Config, HTTPTransport, SOAPAddress, WSDL
username = 'myusername'
apiKey = '0axxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx'
wsdlFile = 'http://flightxml.flightaware.com/soap/FlightXML2'
# This is a custom HTTP transport that allows Basic Authentication.
class myHTTPTransport(HTTPTransport):
username = None
passwd = None
@classmethod
def setAuthentication(cls,u,p):
cls.username = u
cls.passwd = p
def call(self, addr, data, namespace, soapaction=None, encoding=None,
http_proxy=None, config=Config):
if not isinstance(addr, SOAPAddress):
addr=SOAPAddress(addr, config)
if self.username != None:
addr.user = self.username+":"+self.passwd
return HTTPTransport.call(self, addr, data, namespace, soapaction,
encoding, http_proxy, config)
# Make a FlightXML server request.
myHTTPTransport.setAuthentication(username, apiKey)
DF = WSDL.Proxy(wsdlFile, transport=myHTTPTransport)
enroute = DF.Enroute('KSMO',10,'',0)
flights = enroute'enroute']
print "Aircraft en route to KSMO:"
for flight in flights:
print "%s (%s) %s (%s)" % ( flight'ident'], flight'aircrafttype'],
flight'originName'], flight'origin'])
The code throws the exact same error for me using my username/apikey pair as it does for the sample stuff that was provided.
The error I get is as follows:
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "C:\XXXX\Anaconda\lib\site-packages\spyderlib\widgets\externalshell\sitecustomize.py", line 699, in runfile
execfile(filename, namespace)
File "C:\XXXX\Anaconda\lib\site-packages\spyderlib\widgets\externalshell\sitecustomize.py", line 74, in execfile
exec(compile(scripttext, filename, 'exec'), glob, loc)
File "FlightAwareSample.py", line 42, in <module>
File "C:\XXXX\Anaconda\lib\site-packages\SOAPpy\WSDL.py", line 85, in __init__
self.wsdl = reader.loadFromString(str(wsdlsource))
File "C:\XXXX\Anaconda\lib\site-packages\wstools\WSDLTools.py", line 52, in loadFromString
return self.loadFromStream(StringIO(data))
TypeError: initial_value must be unicode or None, not str
Note: I’ve redacted some of the file paths
When I spoke with support they said that my username/apikey pair was correct. I do get the following error when I try to go to http://flightxml.flightaware.com/soap/FlightXML2 which is the wsdlFile
Gone
The requested resource
/soap/FlightXML2
is no longer available on this server and there is no forwarding address. Please remove all references to this resource.
Any help you can offer would be much appreciated
