Problem with Piaware-Web
The link I followed last time was this one: Howto Install Piaware 3.8.1 on Ubuntu Server 20.04 arm64 / Pi4
I couldn’t complete all the steps because Piaware was already installed, but I overwrote everything I could, following the steps in both Dump1090-fa and Piaware one by one. It’s possible that some dependency was present here but wasn’t installed in the other repository. I don’t know what caused the problem, but this process resolved everything. I hope it helped you too. Best regards.
@jhosua1
Actually during building of piaware for ubuntu22 jammy, a dependency tcl-tls is build using source code tcltls-rebuild. This one gives lot of error messages, but in-spite of these it builds package tcl-tls successfully. Even in the manual method you linked, it has the step “3.2 - Build & Install dependency tcl-tls from source code”… You must have seen same error messages during this step.
I dont understand why you failed to build piaware using following bash script. I have just now successfully build and installed piaware ver 10.0 using this script on Armbian Jammy.
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/piaware-ubuntu-debian-amd64/master/install-piaware.sh)"
After building ver 10 packages, I have replaced ver 9.0 packages by ver 10 packages on my following repository at Github:
ubuntu22/README.md at master · abcd567a/ubuntu22 · GitHub
Hello again. Suddenly and for no apparent reason, Piaware has stopped working again. I’ve rebooted the system and we’re back to square one. I haven’t touched anything or installed anything new, and when I queried my data uploaded to the Piaware server, I saw that it’s disconnected from dupm1090-fa as before. This is a rather strange issue. I’ve looked for causes, and I don’t know if the problem mentioned about tcl-tls at GitHub - flightaware/piaware_builder: Debian package builder for piaware could be what’s affecting me and causing the system to crash at certain times. However, this is only happening in the Piaware cloud, as it continues to work fine locally. The comment about tcl-tls refers to configuring tcltls with --enable-ssl-fastpath. I don’t know if this is a solution or the cause, but I wouldn’t lose anything by trying. Any suggestions?
Maybe using the same unique FA station id on two systems or something?
Just check dump1090-fa and piaware log locally as described before.
Makes sense, everyone has different set ups. Was just checking in case. I see that you resolved it. Good on ya.
luis@armbian:~$ sudo journalctl -u piaware -e
[sudo] contraseña para luis:
mar 15 20:18:16 armbian piaware[1784]: no ADS-B data program is serving on port>
mar 15 20:18:36 armbian sudo[7857]: piaware : PWD=/ ; USER=root ; COMMAND=/bin>
mar 15 20:18:36 armbian sudo[7857]: pam_unix(sudo:session): session opened for >
mar 15 20:18:36 armbian sudo[7857]: pam_unix(sudo:session): session closed for >
mar 15 20:18:36 armbian piaware[1784]: no ADS-B data program seen listening on >
mar 15 20:18:36 armbian piaware[1784]: attempting to start dump1090…
mar 15 20:18:36 armbian sudo[7860]: piaware : PWD=/ ; USER=root ; COMMAND=/usr>
mar 15 20:18:36 armbian sudo[7860]: pam_unix(sudo:session): session opened for >
mar 15 20:18:36 armbian sudo[7860]: pam_unix(sudo:session): session closed for >
mar 15 20:18:36 armbian piaware[1784]: attempting to start dump1090-fa using 's>
mar 15 20:18:36 armbian sudo[7864]: piaware : PWD=/ ; USER=root ; COMMAND=/bin>
mar 15 20:18:36 armbian sudo[7864]: pam_unix(sudo:session): session opened for >
mar 15 20:18:16 armbian piaware[1784]: no ADS-B data program is serving on port 30005, not starting multilateration client yetmar 15 20:18:36 armbian sudo[7857]: piaware : PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp --wide --all --numericmar 15 20:18:16 armbian piaware[1784]: no ADS-B data program is serving on port 30005, not starting multilateration client yetmar 15 20:18:36 armbian sudo[7857]: piaware : PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp --wide --all --numericmar 15 20:18:36 armbian sudo[7857]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=998)
mar 15 20:18:16 armbian piaware[1784]: no ADS-B data program is serving on port 30005, not starting multilateration client yetmar 15 20:18:36 armbian sudo[7857]: piaware : PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp --wide --all --numericmar 15 20:18:16 armbian piaware[1784]: no ADS-B data program is serving on port 30005, not starting multilateration client yetmar 15 20:18:16 armbian piaware[1784]: no ADS-B data program is serving on port 30005, not starting multilateration client yetmar 15 20:18:36 armbian sudo[7857]: piaware : PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp --wide --all --numericmar 15 20:18:36 armbian sudo[7857]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=998)
mar 15 20:18:36 armbian sudo[7857]: pam_unix(sudo:session): session closed for user root
mar 15 20:18:36 armbian piaware[1784]: no ADS-B data program seen listening on port 30005 for 371 seconds, trying to start it>mar 15 20:18:16 armbian piaware[1784]: no ADS-B data program is serving on port 30005, not starting multilateration cl>
mar 15 20:18:36 armbian sudo[7857]: piaware : PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp --wide --all →
mar 15 20:18:16 armbian piaware[1784]: no ADS-B data program is serving on port 30005, not starting multilaterat>
mar 15 20:18:36 armbian sudo[7857]: piaware : PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp --wide →
mar 15 20:18:36 armbian piaware[1784]: no ADS-B data program seen listening on port 30005 for 371 seconds, tryin>
mar 15 20:18:16 armbian piaware[1784]: no ADS-B data program is serving on port 30005, not starting multil>
mar 15 20:18:36 armbian piaware[1784]: no ADS-B data program seen listening on port 30005 for 371 seconds, trying to start it>mar 15 20:18:36 armbian piaware[1784]: attempting to start dump1090…
mar 15 20:18:36 armbian sudo[7860]: piaware : PWD=/ ; USER=root ; COMMAND=/usr/sbin/invoke-rc.d --query dump1090-fa start
mar 15 20:18:36 armbian sudo[7860]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=998)
mar 15 20:18:36 armbian sudo[7860]: pam_unix(sudo:session): session closed for user root
mar 15 20:18:36 armbian piaware[1784]: attempting to start dump1090-fa using 'systemctl --no-block restart dump1090-fa.servic>mar 15 20:18:36 armbian sudo[7864]: piaware : PWD=/ ; USER=root ; COMMAND=/bin/systemctl --no-block restart dump1090-fa.serv>mar 15 20:18:36 armbian sudo[7864]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=998)
mar 15 20:18:36 armbian sudo[7864]: pam_unix(sudo:session): session closed for user root
mar 15 20:18:36 armbian piaware[1784]: dump1090 start appears to have been successful
mar 15 20:18:46 armbian sudo[7886]: piaware : PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp --wide --all --numericmar 15 20:18:46 armbian sudo[7886]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=998)
mar 15 20:18:46 armbian sudo[7886]: pam_unix(sudo:session): session closed for user root
mar 15 20:18:46 armbian piaware[1784]: no ADS-B data program seen listening on port 30005 for 10 seconds, next check in 60s
lines 148-165/181 91%
piaware log AND dump1090-fa log
not just one of them.
The manual method you used to build Piaware includes building & installing tcltls-rebuild, as recommended on Flightaware site. The bash script which you used earlier also builds & installs tcltls-rebuild I dont think it is a problem, as since yesterday on Armbian Jammy, I am using piaware package built by bash script, and no issues.
Couple of hours ago, I have uploaded to my Github repository, these version 10 packages built for Ubuntu 22 Jammy. You can install these by following commands:
STEP-1: Add repository to sources list
sudo wget -O /etc/apt/sources.list.d/abcd567a.list https://abcd567a.github.io/ubuntu22/abcd567a.list
sudo wget -O /etc/apt/trusted.gpg.d/abcd567a-key.gpg https://abcd567a.github.io/ubuntu22/KEY2.gpg
sudo apt update
STEP-2: Install packages
sudo apt install dump1090-fa
sudo apt install piaware
sudo apt install piaware-web
sudo apt install dump978-fa    ## For USA only
STEP-3: After installation is completed, remove repository added in STEP-1:
sudo rm /etc/apt/sources.list.d/abcd567a.list
sudo rm /etc/apt/trusted.gpg.d/abcd567a-key.gpg
sudo apt update
luis@armbian:~$ sudo journalctl -u dump1090-fa -n 10
mar 15 20:43:20 armbian dump1090-fa[8824]: Found Rafael Micro R820T tuner
mar 15 20:43:20 armbian dump1090-fa[8824]: rtlsdr: tuner gain set to 49.6 dB (gain step 28)
mar 15 20:43:20 armbian dump1090-fa[8824]: adaptive: using 50% duty cycle
mar 15 20:43:20 armbian dump1090-fa[8824]: adaptive: enabled adaptive gain control with gain limits 0.0dB (step 0) … 58.6dB (step 29)
mar 15 20:43:20 armbian dump1090-fa[8824]: adaptive: enabled dynamic range control, target dynamic range 30.0dB
mar 15 20:43:20 armbian dump1090-fa[8824]: Allocating 4 zero-copy buffers
mar 15 20:43:30 armbian dump1090-fa[8824]: adaptive: available dynamic range (38.5dB) >= required dynamic range (30.0dB), continuing upward scan
mar 15 20:43:30 armbian dump1090-fa[8824]: adaptive: changing gain from 49.6dB (step 28) to 58.6dB (step 29) because: probing dynamic range gain upper bound
mar 15 20:43:30 armbian dump1090-fa[8824]: rtlsdr: tuner gain set to about 58.6 dB (gain step 29) (tuner AGC enabled)
mar 15 20:43:40 armbian dump1090-fa[8824]: adaptive: reached upper gain limit, halting dynamic range scan here
It’s working again, but that’s not enough log.
Both logs at the same time otherwise it isn’t useful.
piaware is probably working again as well.
The SDR might just be defective or not getting enough voltage.
:+1:
:+1:
Hello again. I’ve been testing this whole weekend. The last thing I did was install a new image of Armbian, the latest version 25.05.0, and Noble Ubuntu 24.04, on the SD card. I installed dump1090-fa, Piaware, and fr24feeder, and so far everything is working perfectly. I wanted to install rbfeeder as well, but the official installation script gave me several errors, making it impossible to install. Initially, they were Secure8 key errors, and I used the trick of tricking the script by changing the Version line to Bullseye, but it gave me another error about libraries that it supposedly couldn’t install, and it turns out they’re already installed. If you know of a way to install rbfeeder for my new version of Armbian, I’d appreciate it. Best regards.
First:
sudo apt --fix-broken install
Next:
(a) If you already have a key:
sudo rbfeeder --setkey ‹your sharing key›
(b) If you dont have a key
sudo rbfeeder
The solution you suggested didn’t resolve the issue. I’ve re-run the installation script so you can see what the installation returns. Although the installation is reported as completed successfully, it isn’t, and the rbfeeder service doesn’t exist:
luis@armbian:~$ sudo ./instalador_rbfeerder.sh
Hit:1 http://ports.ubuntu.com noble InRelease
Get:2 http://ports.ubuntu.com noble-security InRelease
[126 kB]
Hit:3 https://repo-feed.flightradar24.com flightradar24
InRelease
Get:4 http://ports.ubuntu.com noble-updates InRelease [
126 kB]
Get:6 http://ports.ubuntu.com noble-backports InRelease
[126 kB]
Hit:7 https://apt.rb24.com bullseye InRelease
Get:5 https://raw.githubusercontent.com/abcd567a/ubuntu
22/master ./ InRelease [2.115 B]
Hit:8 Armbian config package repository | configng stable InRele
ase
Get:9 Index of /apt/ noble InRelease [5
2,4 kB]
Get:10 http://ports.ubuntu.com noble-updates/main arm64
Packages [1.167 kB]
Get:11 http://ports.ubuntu.com noble-updates/universe a
rm64 Packages [1.315 kB]
Get:12 Index of /apt/ noble/noble-utils
arm64 Packages [33,1 kB]
Get:13 Index of /apt/ noble/noble-utils
arm64 Contents (deb) [47,7 kB]
Fetched 2.995 kB in 4s (764 kB/s)
Reading package lists… Done
W: Target Packages (main/binary-arm64/Packages) is conf
igured multiple times in /etc/apt/sources.list:1 and /e
tc/apt/sources.list.d/ubuntu.sources:1
W: Target Packages (main/binary-all/Packages) is config
ured multiple times in /etc/apt/sources.list:1 and /etc
W: Target Contents-deb (main/Contents-arm64) is configu
red multiple times in /etc/apt/sources.list:1 and /etc/
W: Target Contents-deb (main/Contents-all) is configure
d multiple times in /etc/apt/sources.list:1 and /etc/ap
W: Target Packages (restricted/binary-arm64/Packages) i
s configured multiple times in /etc/apt/sources.list:1
and /etc/apt/sources.list.d/ubuntu.sources:1
W: Target Packages (restricted/binary-all/Packages) is
configured multiple times in /etc/apt/sources.list:1 an
W: Target Contents-deb (restricted/Contents-arm64) is c
onfigured multiple times in /etc/apt/sources.list:1 and
W: Target Contents-deb (restricted/Contents-all) is con
figured multiple times in /etc/apt/sources.list:1 and /
W: Target Packages (universe/binary-arm64/Packages) is
W: Target Packages (universe/binary-all/Packages) is co
W: Target Contents-deb (universe/Contents-arm64) is con
W: Target Contents-deb (universe/Contents-all) is confi
gured multiple times in /etc/apt/sources.list:1 and /et
W: https://apt.rb24.com/dists/bullseye/InRelease: Key i
s stored in legacy trusted.gpg keyring (/etc/apt/truste
d.gpg), see the DEPRECATION section in apt-key(8) for d
etails.
Building dependency tree… Done
dirmngr is already the newest version (2.4.4-2ubuntu17)
0 upgraded, 0 newly installed, 0 to remove and 13 not u
pgraded.
Warning: apt-key is deprecated. Manage keyring files in
trusted.gpg.d instead (see apt-key(8)).
Executing: /tmp/apt-key-gpghome.JEYx2eib15/gpg.1.sh --k
eyserver hkp://keyserver.ubuntu.com:80 --recv-keys 1D04
3681
gpg: key D4F914061D043681: “AirNav Systems <jceara@airn
avsystems.com>” not changed
gpg: Total number processed: 1
gpg: unchanged: 1
Hit:2 http://ports.ubuntu.com noble-security InRelease
Hit:3 http://ports.ubuntu.com noble-updates InRelease
Hit:4 http://ports.ubuntu.com noble-backports InRelease
Hit:6 https://repo-feed.flightradar24.com flightradar24
InRelease
ase
Release [52,4 kB]
Fetched 54,5 kB in 4s (15,4 kB/s)
etails.
N: Missing Signed-By in the sources.list(5) entry for ’
https://apt.armbian.com
Some packages could not be installed. This may mean tha
t you have
requested an impossible situation or if you are using t
he unstable
distribution that some required packages have not yet b
een created
or been moved out of Incoming.
The following information may help to resolve the situa
tion:
rbfeeder : Depends: librtlsdr0 (>= 0.6.0) but it is no
t installable
E: Unable to correct problems, you have held broken pac
kages.
Do you wish to install dump978-rb program? (y/n) n
-e
-e
-e !!! IMPORTANT !!!
-e
-e By default, RBFeeder is configured to connect to you
r local dump1090 instance (localhost,
-e port 30005). If you want to use a USB RTL-SDR dongle
instead, please run this command:
-e
-e sudo rbfeeder --set-network-mode off --no-start
-e
-e Then, restart the daemon:
-e
-e sudo systemctl restart rbfeeder
-e
-e After a few seconds, RBFeeder will connect to the Ai
rNav servers and you can view your
-e sharing-key with this command:
-e
-e sudo rbfeeder --showkey
-e
-e If you already have a sharing-key from previous a in
stallation, you can set the same
-e key using this command:
-e
-e sudo rbfeeder --setkey ‹your sharing key›
-e
-e
-e Installation finished.
-e
-e
luis@armbian:~$
You used wrong VERS.(bullseye)
Ubuntu Noble is based on Debian 12 Bookworm
Use VERS=bookworm
Note: bookworm, NOT Bookworm
25.05.0 is not the latest version, 25.2.2 is the latest
I have modified bullseye for bookworm but now the key error and distribution error appear earlier. I’ll paste you the last thing that comes out of the process:
Executing: /tmp/apt-key-gpghome.JxpOh0t87m/gpg.1.sh --k
3681
gpg: unchanged: 1
Don’t know how to install for a distribution named
luis@armbian:~$
The script failed to detect version is bookworm. May be due to a typing mistake you made during editing it.
can you please open RB24 installation sh file, and take a screenshot of the area containing VERS=bookworm, as well 2 lines above it & 2 lines below it?
if [ “$(id -u)” != “0” ]; then
echo -e “You must run this script with root privileges” 1>&2
exit 1
fi
VERS=bookworm
Install packages needed by script
apt-get update -y
apt-get install dirmngr -y
post deleted by author
Regarding my new system version, I don’t know if it’s the latest, but it’s the most current one I’ve found that’s compatible with my Amlogic device. I’ll share the details of the installed system.
luis@armbian:~$ cat /etc/*release
PLEASE DO NOT EDIT THIS FILE
BOARD=“S905x-T95”
BOARD_NAME=“Aml.S905x”
BOARDFAMILY=“meson-gxl”
BUILD_REPOSITORY_URL=GitHub - armbian/build: Armbian Linux build framework generates custom Debian or Ubuntu image for x86, aarch64, riscv64 & armhf
BUILD_REPOSITORY_COMMIT=2b7cb0d
LINUXFAMILY=“amlogic”
ARCH=arm64
BOOT_SOC=
IMAGE_TYPE=rebuild
BOARD_TYPE=diy
INITRD_ARCH=arm64
KERNEL_IMAGE_TYPE=Image
KERNEL_TARGET=current,edge
KERNEL_TEST_TARGET=current
FORCE_BOOTSCRIPT_UPDATE=“no”
FORCE_UBOOT_UPDATE=
OVERLAY_DIR=“/boot/dtb/amlogic/overlay”
VENDOR=“Armbian OS”
VENDORDOCS=“https://docs.armbian.com/
VENDORURL=“https://duckduckgo.com/
VENDORSUPPORT=“https://community.armbian.com/
VENDORBUGS=“https://armbian.atlassian.net/
BOOTSCRIPT_FORCE_UPDATE=“no”
BOOTSCRIPT_DST=“boot.cmd”
VERSION=“25.05.0”
REVISION=“25.05.0”
IMAGE_UUID=0bf7f9be-4ac5-4c42-a4fd-ee50*******82a
BOARD=“S905x-T95”
ARCH=arm64
BOOT_SOC=
IMAGE_TYPE=rebuild
BOARD_TYPE=diy
INITRD_ARCH=arm64
FORCE_UBOOT_UPDATE=
VENDOR=“Armbian OS”
VERSION=“25.05.0”
REVISION=“25.05.0”
BRANCH=current
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=24.04
DISTRIB_CODENAME=noble
DISTRIB_DESCRIPTION=“Ubuntu 24.04 LTS”
PLATFORM=‘amlogic’
VERSION_CODEID=‘ubuntu’
VERSION_CODENAME=‘noble’
MODEL_ID=‘109’
MODEL_NAME=‘T95,XiaoMI-3S,X96’
SOC=‘s905x’
FDTFILE=‘meson-gxl-s905x-p212.dtb’
FAMILY=‘meson-gxl’
BOARD=‘s905x-t95’
KERNEL_REPO=‘ophub/kernel’
KERNEL_TAGS=‘stable’
KERNEL_VERSION=‘6.6.80’
KERNEL_BACKUP=‘yes’
BOOT_CONF=‘extlinux.conf’
ROOTFS_TYPE=‘ext4’
DISK_TYPE=‘usb’
AMPART_STATUS=‘no’
MLUBOOT_STATUS=‘no’
MAINLINE_UBOOT=‘’
BOOTLOADER_IMG=‘’
UBOOT_OVERLOAD=‘u-boot-s905x-s912.bin’
BUILD_REPOSITORY=‘GitHub - armbian/build: Armbian Linux build framework generates custom Debian or Ubuntu image for x86, aarch64, riscv64 & armhf
REBUILD_REPOSITORY=‘GitHub - ophub/amlogic-s9xxx-armbian: Support for Armbian in Amlogic, Rockchip and Allwinner boxes. Support a311d, s922x, s905x3, s905x2, s912, s905d, s905x, s905w, s905, s905l, rk3588, rk3568, rk3399, rk3328, h6, etc.
CONTRIBUTORS=‘chris4git,shuye1728,Drafteed’
BUILDER_NAME=‘ophub’
PACKAGED_DATE=‘2025-03-02’
PRETTY_NAME=“Armbian OS 25.05.0 noble”
NAME=“Ubuntu”
VERSION_ID=“24.04”
VERSION=“24.04 LTS (Noble Numbat)”
VERSION_CODENAME=noble
ID=ubuntu
ID_LIKE=debian
HOME_URL=“https://www.armbian.com
SUPPORT_URL=“https://forum.armbian.com
BUG_REPORT_URL=“Bug reporting - Armbian
PRIVACY_POLICY_URL=“https://www.armbian.com
UBUNTU_CODENAME=noble
LOGO=“armbian-logo”
ARMBIAN_PRETTY_NAME=“Armbian OS 25.05.0 noble”
