Since we changed from UTC to BST the Pi 3 time is 1 hour slow.
This seems to be affecting the MLAT sync and is saying Local clock source is unstable.
Can anyone tell me how to change the Pi time while running Piaware.
Check this page to have your raspberry pi sync with a time server on the internet and to set the correct timezone
The slow time and MLAT sync problem are not related.
MLAT does not use the clock time on your Pi.
See:
If you want to set your Pi’s clock to account for Daylight saving then run
sudo raspi-config
choose localisation options and set your timezone.
Thank you, I formatted the SD card and installed the 32 bit OS then the Piaware software.
It put everything back to normal. I have left the time to UTC and MLAT syncs ok now
