Hi @obj, As I couldnβt remember exactly what they said, I went for a drive this afternoon.
I started PiAware at approximately June 2, 2020 @ 13:11 local time. While driving I noted a 3D FIX had been acquired sometime around 13:17 local time. I drove for over 15 minutes and checked the stats page for this feeder. It was still showing Location Set date and time of 30 May 2020 10:53 AM, I restarted PiAware at approximately 13:36 local time, drove for a few minutes and now the stats page sows Location Set 2 June 2020 1:44 PM.
Unfortunately, the output of the sudo journalctl -f -u piaware command is too much to be included in this reply. And as I donβt know what you would be looking for I have just included the first few lines of the first start and the restart. If you want the entire log file just let me know and provide a method for me to send it to you. I noticed the date and time changed suddenly partway through the first snippet I included, I can only conclude the time and date of the pi changed at that point in time.
Jun 01 16:17:20 piaware piaware[509]: creating pidfile /run/piaware/piaware.pid
Jun 01 16:17:20 piaware piaware[509]: ****************************************************
Jun 01 16:17:20 piaware piaware[509]: piaware version 3.8.1 is running, process ID 509
Jun 01 16:17:20 piaware piaware[509]: your system info is: Linux piaware 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l GNU/Linux
Jun 01 16:17:20 piaware piaware[509]: GPS: Connected to gpsd 3.17 at localhost/2947
Jun 01 16:17:21 piaware piaware[509]: Connecting to FlightAware adept server at piaware.flightaware.com/1200
Jun 01 16:17:21 piaware piaware[509]: Connection with adept server at piaware.flightaware.com/1200 established
Jun 01 16:17:22 piaware piaware[509]: TLS handshake with adept server at piaware.flightaware.com/1200 completed
Jun 01 16:17:22 piaware piaware[509]: FlightAware server certificate validated
Jun 01 16:17:22 piaware piaware[509]: encrypted session established with FlightAware
Jun 01 16:17:22 piaware sudo[561]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=list /usr/bin/netstat --program --tcp --wide --all --numeric
Jun 01 16:17:22 piaware sudo[563]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program --tcp --wide --all --numeric
Jun 01 16:17:22 piaware sudo[563]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 01 16:17:22 piaware sudo[563]: pam_unix(sudo:session): session closed for user root
Jun 01 16:17:23 piaware piaware[509]: adept reported location: 43.83130, -79.35283, 150ft AMSL
Jun 01 16:17:23 piaware piaware[509]: Receiver location changed, restarting dump1090 and skyaware978
Jun 01 16:17:23 piaware piaware[509]: attempting to restart dump1090..
Jun 01 16:17:23 piaware sudo[577]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=list /usr/sbin/invoke-rc.d --query dump1090-fa restart
Jun 01 16:17:23 piaware sudo[579]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/sbin/invoke-rc.d --query dump1090-fa restart
Jun 01 16:17:23 piaware sudo[579]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 01 16:17:23 piaware sudo[579]: pam_unix(sudo:session): session closed for user root
Jun 01 16:17:23 piaware piaware[509]: attempting to restart dump1090-fa using 'systemctl --no-block try-restart dump1090-fa.service < /dev/null'...
Jun 01 16:17:23 piaware sudo[590]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=list /usr/bin/systemctl --no-block try-restart dump1090-fa.service
Jun 01 16:17:23 piaware sudo[592]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl --no-block try-restart dump1090-fa.service
Jun 01 16:17:23 piaware sudo[592]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 01 16:17:23 piaware sudo[592]: pam_unix(sudo:session): session closed for user root
Jun 01 16:17:23 piaware piaware[509]: dump1090 restart appears to have been successful
Jun 01 16:17:23 piaware piaware[509]: attempting to restart skyaware978..
Jun 01 16:17:23 piaware sudo[602]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=list /usr/sbin/invoke-rc.d --query skyaware978 restart
Jun 01 16:17:23 piaware sudo[604]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/sbin/invoke-rc.d --query skyaware978 restart
Jun 01 16:17:23 piaware sudo[604]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 01 16:17:23 piaware sudo[604]: pam_unix(sudo:session): session closed for user root
Jun 01 16:17:23 piaware piaware[509]: attempting to restart skyaware978 using 'systemctl --no-block try-restart skyaware978.service < /dev/null'...
Jun 01 16:17:23 piaware sudo[615]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=list /usr/bin/systemctl --no-block try-restart skyaware978.service
Jun 01 16:17:23 piaware sudo[617]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl --no-block try-restart skyaware978.service
Jun 01 16:17:23 piaware sudo[617]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 01 16:17:23 piaware sudo[617]: pam_unix(sudo:session): session closed for user root
Jun 01 16:17:23 piaware piaware[509]: skyaware978 restart appears to have been successful
Jun 01 16:17:23 piaware piaware[509]: logged in to FlightAware as user va3kxp
Jun 01 16:17:23 piaware piaware[509]: my feeder ID is 1aef65e4-a3ca-4cfd-b696-c30b6643a86b
Jun 01 16:17:23 piaware piaware[509]: site statistics URL: https://flightaware.com/adsb/stats/user/va3kxp#stats-115450
Jun 01 16:17:23 piaware sudo[626]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program --tcp --wide --all --numeric
Jun 01 16:17:23 piaware sudo[626]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 01 16:17:23 piaware sudo[626]: pam_unix(sudo:session): session closed for user root
Jun 01 16:17:23 piaware piaware[509]: ADS-B data program 'dump1090-fa' is listening on port 30005, so far so good
Jun 01 16:17:23 piaware piaware[509]: Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 43.831 --lon -79.353
Jun 01 16:17:23 piaware piaware[509]: Started faup1090 (pid 635) to connect to dump1090-fa
Jun 01 16:17:23 piaware piaware[509]: UAT support disabled by local configuration setting: uat-receiver-type
Jun 01 16:17:23 piaware piaware[509]: multilateration data requested
Jun 01 16:17:23 piaware sudo[636]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program --tcp --wide --all --numeric
Jun 01 16:17:23 piaware sudo[636]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 01 16:17:23 piaware sudo[636]: pam_unix(sudo:session): session closed for user root
Jun 01 16:17:23 piaware piaware[509]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 70.42.6.225:5765:3212157679
Jun 01 16:17:24 piaware piaware[509]: mlat-client(645): fa-mlat-client 0.2.11 starting up
Jun 01 16:17:24 piaware piaware[509]: mlat-client(645): Using UDP transport to 70.42.6.225 port 5765
Jun 01 16:17:24 piaware piaware[509]: mlat-client(645): Listening for Beast-format results connection on port 30105
Jun 01 16:17:24 piaware piaware[509]: mlat-client(645): Listening for Extended Basestation-format results connection on port 30106
Jun 01 16:17:24 piaware piaware[509]: mlat-client(645): Route MTU changed to 1500
Jun 01 16:17:24 piaware piaware[509]: mlat-client(645): Input connected to localhost:30005
Jun 01 16:17:24 piaware piaware[509]: mlat-client(645): Input format changed to BEAST, 12MHz clock
Jun 01 16:17:24 piaware piaware[509]: mlat-client(645): Lost connection to localhost:30005
Jun 01 16:17:24 piaware piaware[509]: mlat-client(645): Reconnecting in 30.0 seconds
Jun 01 16:17:24 piaware piaware[509]: lost connection to dump1090-fa via faup1090
Jun 01 16:17:24 piaware piaware[509]: faup1090 exited normally
Jun 01 16:17:24 piaware piaware[509]: will reconnect to dump1090-fa in 30 seconds
Jun 01 16:17:25 piaware piaware[509]: mlat-client(645): Beast-format results connection with ::1:30104: [Errno 111] Connection refused
Jun 02 17:11:43 piaware sudo[682]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program --tcp --wide --all --numeric
Jun 02 17:11:43 piaware sudo[682]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 02 17:11:43 piaware sudo[682]: pam_unix(sudo:session): session closed for user root
Jun 02 17:11:43 piaware piaware[509]: ADS-B data program 'dump1090-fa' is listening on port 30005, so far so good
Jun 02 17:11:43 piaware piaware[509]: Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 43.831 --lon -79.353
Jun 02 17:11:43 piaware piaware[509]: Started faup1090 (pid 694) to connect to dump1090-fa
Jun 02 17:11:43 piaware piaware[509]: 0 msgs recv'd from dump1090-fa; 0 msgs sent to FlightAware
Jun 02 17:11:43 piaware piaware[509]: timed out waiting for alive message from FlightAware, reconnecting...
Jun 02 17:11:43 piaware piaware[509]: multilateration data no longer required, disabling mlat client
Jun 02 17:11:44 piaware piaware[509]: fa-mlat-client exited normally
Jun 02 17:11:44 piaware piaware[509]: reconnecting in 5 seconds...
Jun 02 17:11:44 piaware piaware[509]: piaware received a message from dump1090-fa!
Jun 02 17:11:44 piaware piaware[509]: mlat-client(645): Exiting on connection loss
Jun 02 17:11:49 piaware piaware[509]: Connecting to FlightAware adept server at piaware.flightaware.com/1200
Jun 02 17:11:49 piaware piaware[509]: Connection with adept server at piaware.flightaware.com/1200 established
Jun 02 17:11:50 piaware piaware[509]: TLS handshake with adept server at piaware.flightaware.com/1200 completed
Jun 02 17:11:50 piaware piaware[509]: FlightAware server certificate validated
Jun 02 17:11:50 piaware piaware[509]: encrypted session established with FlightAware
Jun 02 17:11:50 piaware sudo[769]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program --tcp --wide --all --numeric
Jun 02 17:11:50 piaware sudo[769]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 02 17:11:50 piaware sudo[769]: pam_unix(sudo:session): session closed for user root
Jun 02 17:11:50 piaware piaware[509]: logged in to FlightAware as user va3kxp
Jun 02 17:11:50 piaware piaware[509]: my feeder ID is 1aef65e4-a3ca-4cfd-b696-c30b6643a86b
Jun 02 17:11:50 piaware piaware[509]: site statistics URL: https://flightaware.com/adsb/stats/user/va3kxp#stats-115450
Jun 02 17:11:50 piaware piaware[509]: multilateration data requested
Jun 02 17:11:50 piaware sudo[782]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program --tcp --wide --all --numeric
Jun 02 17:11:50 piaware sudo[782]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 02 17:11:50 piaware sudo[782]: pam_unix(sudo:session): session closed for user root
Jun 02 17:11:50 piaware piaware[509]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 70.42.6.224:17719:417293192
Jun 02 17:11:51 piaware piaware[509]: mlat-client(791): fa-mlat-client 0.2.11 starting up
Jun 02 17:11:51 piaware piaware[509]: mlat-client(791): Using UDP transport to 70.42.6.224 port 17719
Jun 02 17:11:51 piaware piaware[509]: mlat-client(791): Listening for Beast-format results connection on port 30105
Jun 02 17:11:51 piaware piaware[509]: mlat-client(791): Listening for Extended Basestation-format results connection on port 30106
Jun 02 17:11:51 piaware piaware[509]: mlat-client(791): Route MTU changed to 1500
Jun 02 17:11:51 piaware piaware[509]: mlat-client(791): Input connected to localhost:30005
Jun 02 17:11:51 piaware piaware[509]: mlat-client(791): Input format changed to BEAST, 12MHz clock
Jun 02 17:11:51 piaware piaware[509]: mlat-client(791): Beast-format results connection with ::1:30104: connection established
Jun 02 17:12:12 piaware piaware[509]: piaware has successfully sent several msgs to FlightAware!
Jun 02 17:12:14 piaware piaware[509]: 12 msgs recv'd from dump1090-fa (12 in last 1m); 9 msgs sent to FlightAware
Jun 02 17:17:14 piaware piaware[509]: 99 msgs recv'd from dump1090-fa (87 in last 5m); 96 msgs sent to FlightAware
Jun 02 17:17:30 piaware piaware[509]: gpsd reported location: 43.75478, -79.35209, 146m (WGS84)
Jun 02 17:17:30 piaware piaware[509]: Receiver location changed, restarting dump1090 and skyaware978
Jun 02 17:17:30 piaware piaware[509]: attempting to restart dump1090..
Jun 02 17:17:30 piaware sudo[1053]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/sbin/invoke-rc.d --query dump1090-fa restart
Jun 02 17:17:30 piaware sudo[1053]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 02 17:17:30 piaware sudo[1053]: pam_unix(sudo:session): session closed for user root
Jun 02 17:17:30 piaware piaware[509]: attempting to restart dump1090-fa using 'systemctl --no-block try-restart dump1090-fa.service < /dev/null'...
Jun 02 17:17:30 piaware sudo[1064]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl --no-block try-restart dump1090-fa.service
Jun 02 17:17:30 piaware sudo[1064]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 02 17:17:30 piaware sudo[1064]: pam_unix(sudo:session): session closed for user root
Jun 02 17:17:30 piaware piaware[509]: dump1090 restart appears to have been successful
Jun 02 17:17:30 piaware piaware[509]: attempting to restart skyaware978..
Jun 02 17:17:30 piaware sudo[1074]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/sbin/invoke-rc.d --query skyaware978 restart
Jun 02 17:17:30 piaware sudo[1074]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 02 17:17:30 piaware sudo[1074]: pam_unix(sudo:session): session closed for user root
Jun 02 17:17:30 piaware piaware[509]: attempting to restart skyaware978 using 'systemctl --no-block try-restart skyaware978.service < /dev/null'...
Jun 02 17:17:30 piaware sudo[1085]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl --no-block try-restart skyaware978.service
Jun 02 17:17:30 piaware sudo[1085]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 02 17:17:30 piaware sudo[1085]: pam_unix(sudo:session): session closed for user root
Jun 02 17:17:30 piaware piaware[509]: skyaware978 restart appears to have been successful
Jun 02 17:17:30 piaware piaware[509]: Restarting faup1090
Jun 02 17:17:31 piaware piaware[509]: faup1090 exited with SIG SIGHUP
Jun 02 17:17:31 piaware piaware[509]: reconnecting to dump1090-fa
Jun 02 17:17:31 piaware piaware[509]: mlat-client(791): Beast-format results connection with ::1:30104: connection lost
Jun 02 17:17:31 piaware piaware[509]: mlat-client(791): Lost connection to localhost:30005
Jun 02 17:17:31 piaware piaware[509]: mlat-client(791): Reconnecting in 30.0 seconds
Jun 02 17:17:32 piaware sudo[1114]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program --tcp --wide --all --numeric
Jun 02 17:17:32 piaware sudo[1114]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 02 17:17:32 piaware sudo[1114]: pam_unix(sudo:session): session closed for user root
Jun 02 17:17:32 piaware piaware[509]: ADS-B data program 'dump1090-fa' is listening on port 30005, so far so good
Jun 02 17:17:32 piaware piaware[509]: Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 43.831 --lon -79.353
Jun 02 17:17:32 piaware piaware[509]: Started faup1090 (pid 1124) to connect to dump1090-fa
Jun 02 17:17:46 piaware piaware[509]: Receiver location changed, restarting dump1090 and skyaware978
Jun 02 17:17:46 piaware piaware[509]: attempting to restart dump1090..
Jun 02 17:17:46 piaware sudo[1127]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/sbin/invoke-rc.d --query dump1090-fa restart
Jun 02 17:17:46 piaware sudo[1127]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 02 17:17:46 piaware sudo[1127]: pam_unix(sudo:session): session closed for user root
Jun 02 17:17:46 piaware piaware[509]: attempting to restart dump1090-fa using 'systemctl --no-block try-restart dump1090-fa.service < /dev/null'...
Jun 02 17:17:46 piaware sudo[1138]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl --no-block try-restart dump1090-fa.service
Jun 02 17:17:46 piaware sudo[1138]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 02 17:17:46 piaware sudo[1138]: pam_unix(sudo:session): session closed for user root
Jun 02 17:17:46 piaware piaware[509]: dump1090 restart appears to have been successful
Jun 02 17:17:46 piaware piaware[509]: attempting to restart skyaware978..
Jun 02 17:17:46 piaware sudo[1148]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/sbin/invoke-rc.d --query skyaware978 restart
Jun 02 17:17:46 piaware sudo[1148]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 02 17:17:46 piaware sudo[1148]: pam_unix(sudo:session): session closed for user root
Jun 02 17:17:46 piaware piaware[509]: attempting to restart skyaware978 using 'systemctl --no-block try-restart skyaware978.service < /dev/null'...
Jun 02 17:17:46 piaware sudo[1159]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/systemctl --no-block try-restart skyaware978.service
Jun 02 17:17:46 piaware sudo[1159]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 02 17:17:46 piaware sudo[1159]: pam_unix(sudo:session): session closed for user root
Jun 02 17:17:46 piaware piaware[509]: skyaware978 restart appears to have been successful
Jun 02 17:17:46 piaware piaware[509]: Restarting faup1090
Jun 02 17:17:47 piaware piaware[509]: faup1090 exited with SIG SIGHUP
Jun 02 17:17:47 piaware piaware[509]: reconnecting to dump1090-fa
After the restart
Jun 02 17:36:12 piaware piaware[3489]: creating pidfile /run/piaware/piaware.pid
Jun 02 17:36:12 piaware piaware[3489]: ****************************************************
Jun 02 17:36:12 piaware piaware[3489]: piaware version 3.8.1 is running, process ID 3489
Jun 02 17:36:12 piaware piaware[3489]: your system info is: Linux piaware 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l GNU/Linux
Jun 02 17:36:12 piaware piaware[3489]: GPS: Connected to gpsd 3.17 at localhost/2947
Jun 02 17:36:13 piaware piaware[3489]: gpsd reported location: 43.74451, -79.35447, 136m (WGS84)
Jun 02 17:36:13 piaware piaware[3489]: Connecting to FlightAware adept server at piaware.flightaware.com/1200
Jun 02 17:36:14 piaware piaware[3489]: Connection with adept server at piaware.flightaware.com/1200 established
Jun 02 17:36:14 piaware piaware[3489]: TLS handshake with adept server at piaware.flightaware.com/1200 completed
Jun 02 17:36:14 piaware piaware[3489]: FlightAware server certificate validated
Jun 02 17:36:14 piaware piaware[3489]: encrypted session established with FlightAware
Jun 02 17:36:14 piaware sudo[3496]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=list /usr/bin/netstat --program --tcp --wide --all --numeric
Jun 02 17:36:14 piaware sudo[3498]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program --tcp --wide --all --numeric
Jun 02 17:36:14 piaware sudo[3498]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 02 17:36:14 piaware sudo[3498]: pam_unix(sudo:session): session closed for user root
Jun 02 17:36:14 piaware piaware[3489]: logged in to FlightAware as user va3kxp
Jun 02 17:36:14 piaware piaware[3489]: my feeder ID is 1aef65e4-a3ca-4cfd-b696-c30b6643a86b
Jun 02 17:36:14 piaware piaware[3489]: site statistics URL: https://flightaware.com/adsb/stats/user/va3kxp#stats-115450
Jun 02 17:36:15 piaware piaware[3489]: multilateration data requested
Jun 02 17:36:15 piaware sudo[3511]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program --tcp --wide --all --numeric
Jun 02 17:36:15 piaware sudo[3511]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 02 17:36:15 piaware sudo[3511]: pam_unix(sudo:session): session closed for user root
Jun 02 17:36:15 piaware piaware[3489]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 70.42.6.225:6463:1022437266
Jun 02 17:36:15 piaware sudo[3521]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program --tcp --wide --all --numeric
Jun 02 17:36:15 piaware sudo[3521]: pam_unix(sudo:session): session opened for user root by (uid=0)
Jun 02 17:36:15 piaware sudo[3521]: pam_unix(sudo:session): session closed for user root
Jun 02 17:36:15 piaware piaware[3489]: ADS-B data program 'dump1090-fa' is listening on port 30005, so far so good
Jun 02 17:36:15 piaware piaware[3489]: Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 43.744 --lon -79.356
Jun 02 17:36:15 piaware piaware[3489]: Started faup1090 (pid 3530) to connect to dump1090-fa
Jun 02 17:36:15 piaware piaware[3489]: UAT support disabled by local configuration setting: uat-receiver-type
Jun 02 17:36:15 piaware piaware[3489]: mlat-client(3520): fa-mlat-client 0.2.11 starting up
Jun 02 17:36:15 piaware piaware[3489]: mlat-client(3520): Using UDP transport to 70.42.6.225 port 6463
Jun 02 17:36:15 piaware piaware[3489]: mlat-client(3520): Listening for Beast-format results connection on port 30105
Jun 02 17:36:15 piaware piaware[3489]: mlat-client(3520): Listening for Extended Basestation-format results connection on port 30106
Jun 02 17:36:15 piaware piaware[3489]: mlat-client(3520): Route MTU changed to 1500
Jun 02 17:36:15 piaware piaware[3489]: mlat-client(3520): Input connected to localhost:30005
Jun 02 17:36:15 piaware piaware[3489]: mlat-client(3520): Input format changed to BEAST, 12MHz clock
Jun 02 17:36:16 piaware piaware[3489]: mlat-client(3520): Beast-format results connection with ::1:30104: connection established
Jun 02 17:36:16 piaware piaware[3489]: piaware received a message from dump1090-fa!
Jun 02 17:36:23 piaware piaware[3489]: piaware has successfully sent several msgs to FlightAware!
Jun 02 17:36:46 piaware piaware[3489]: 21 msgs recv'd from dump1090-fa; 21 msgs sent to FlightAware
Jun 02 17:37:23 piaware piaware[3489]: gpsd reported location: 43.74495, -79.35397, 140m (WGS84)
