In the last month or more, I noticed that my Pi3 with airspy is not producing anymore the same level of data like it used before. I have an Flight Feeder on the same antenna as a reference.
Note that the Airspy is fed from the Pi3 USB port.
The distance shown on map is still greater on the airspy, but the sample number is lower.
When investigating this, I noticed that vcgencmd measure_clock arm result is frequency(45)=600064000
So CPU it is throttling to 600MHz.
If I try to force a different governor with #performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor on all cores… the Pi3 either crashes or… it stops displaying planes (like the airspy is disconnected).
The temperature in the location of Pi3 is higher now in the summer… but the CPU temperature with vcgencmd measure_temp is 58-61C.
Question: can this throttling be because of the power supply? I only have one 3A capable PS, ordered another one yesterday…
Any other ideas?
Is that with or without throttling? My 3A+ runs at 70% and reaches 40 C during the day when it is not hot, with a 80x80mm fan, without a case. On hotter days that jumps to 55-60C, so I guess it would be throttled…
Wouldn’t expect it to throttle at 60C, but i’m not sure what value it throttles exactly.
(Believe it throttles at 75C)
You can put this into your boot/config.txt
force_turbo=1
arm_freq=800
Maybe at 800 MHz it’ll run stable and have enough CPU for the Airspy.
Note you might have to change the values back outside the RPi if it doesn’t boot at 800 MHz.
(But i wouldn’t be surprised if the power supply just dies completely very soon)
In my config.txt I have added a long time ago:
force_turbo=1
boot_delay=1
arm_freq=1350
arm_freq_min=700
core_freq=500
over_voltage=2
dtoverlay=sdhost,overclock_50=100\n
dtoverlay=pi3-disable-wifi
I have made a script from the lines posted by caius above.
pi@pi_3:~ $ ./status.sh
Status: 0x50005
Undervolted:
Now: YES
Run: YES
Throttled:
Now: YES
Run: YES
Frequency Capped:
Now: NO
Run: NO
Then remove all that and just set the frequency to 1000 MHz.
force_turbo=1
arm_freq=1000
Should be enough to run airspy_adsb at 12 MHz and is much more unlikely to get throttled.
(you can leave WiFi disabled obviously but i would really remove the rest and just set a reasonable frequency)
I think that, if there is under-voltage detected, the config.txt settings about frequency are ignored.
I have added there minimum freq as 700 (that’s newly added) and it still stays at 600.
I found out that the arm_freq setting is active to that number only when I change the scaling governor to #performance.
I could try lowering it to 1000, but I really think the core cause is the failing PS.
It probably is the reason.
But with your settings it’s pulling a lot more power than with what i’m suggesting.
Less power being drawn might result in sufficient voltage.
Anyway, might also be the RPi being a goner.
That’s quite some frequency and also over_voltage, increases the likelihood of the thing dying.
I really hate that they used micro USB to power the pi for so long. It’s a really crappy connector. USB-C is better, but I still don’t get what’s wrong with a simple 2 pin plug. I get that they wanted people to be able to power it with spare phone chargers etc, but it’s a real false economy.
I am with you here, hated the trend of putting USB power on everything. Loved the old Nokia power supply.
I have also an Orange Pi and that’s how is fed - coaxial power plug.
