I’d use a test meter to see if there a DC continuity between the centre and outer connections of the antenna - if there is no continuity - you don’t need a blocker.
Maybe someone who has both the antenna and a suitable meter can do the check … it would take longer to type a response than to do the check.
I received my FA antenna from Amazon yesterday. I’m going to install it tonight. Updates to follow. Thanks FA the antenna and mounting bracket looks real nice.
I am not sure if I expected to much, but 24 hours trail (just swapped the antennas on existing setup) indicates that the only difference with my 4 legged spider is very slight increase in number of positions from one sector based on the FA stats page. Is there an easy way to check the antenna?
Possibly my antenna building skills are not great but I am defiantly seeing a noticeable increase of both positions and range.
I have made 8 & 11 segment COCO’s, Spiders 4 - 8 legged variety and none of those has worked better.
The site is started testing at a site that is in a valley. This severally limits my range in most directions to less 75 miles but the max range has been as far as 150 miles (further then before).
For the price point I have found it is a excellent antenna for my needs.
I recieved my FA antenna today. I thought I had a multi-meter somewhere to check the continuity, but could not find it. I installed DC blockers just in case.
I swapped out the window 4-legged spider on my secondary RPi with the FA antenna. I’ll give it a few days and then compare the before and after PF polar plots, since this RPi also feeds Plane Finder.
The construction quality of the FA antenna is very good.
… the amplifier is a companion product LNA4all lna4all.blogspot.com/ … but be aware to use ‘ip the line’ injected power you have to source and fit your own surface mount inductor to the amplifier board. (read the writeup)
I’m running with a surface mount SAW filter cut into the R820T pigtail - no circuit board - seems to work OK.
Does it matter if the FA antenna is mounted to a metal mount via the U-Bolts or to a plastic pipe ? Does that affect grounding ?
The reason I ask is that I can extend my metal mount using a plastic pipe to get a couple more feet over the rooftop. The attics in Florida houses is lined with metal foil to reflect heat and so block signal greatly.
