Also, if I want to use this with the FlightAware Pro Stick and a ADS-B 1090MHz Band-pass SMA Filter, what is the ideal cable setup (best to be from amazon but could order elsewhere if needed)?
Received my 1090Mhz antenna yesterday and immediately installed it, using the N-SMA pigtail I purchased separately. Unfortunately, I’m not seeing any improvement. In fact, it seems to perform worse than the LTE Antenna I was previously using. Since the LTE antenna is tuned for non-ASDB bands (e.g. 829MHz, 1.59GHz, 1.94GHz, 2.55GHz, 5.4GHz) with bandwidths that don’t include 1090 Mhz, I would expect the FA 1090Mhz to blow it out of the water, but it doesn’t seem to.
My setup:
Before:
LTE Antenna → FA 1090 Mhz Filter → FA ADS-B Receiver → RPi
After:
1090Mhz Antenna → N-to-SMA Pigtail → FA 1090 Mhz Filter → FA ADS-B Receiver → RPi
In order to rule out the pigtail, I’ll grab a couple from work and see if that fixes the issue. If not, I guess I’ll have to return the FA antenna.
BTW, when comparing the two antennas using CubicSDR, I definitely see much higher power from the LTE antenna, so I am hoping that the cable is bad…
Be careful with N connectors. There are two types. 75 Ohm and 50 Ohm,
The 75 ohm has a small pin/socket. The FA Antenna uses the 50 ohm(Larger) socket. If you use a 75 ohm plug, it will likely not contact the socket properly.
Thanks for the quick reply and the added info. While the pigtail is indeed 50 ohms, your post made me check what I actually ordered. And sure enough, I stupidly ordered RP-SMA, which results in a female-female connection at the filter, which clearly is a problem.
So, I’m quite sure an actual N-to-SMA (not N-to-RP-SPA) will make a world of difference!
@ndelregno:
As a temporary measure for testing the antenna, just cut a short piece of core wire of coax, and insert in RP-SMA-Male center hole to make it behave as a SMA-Male.
That did the trick. Now seeing hundreds of aircraft, some as far away as 250 miles, even with the antenna in a west-facing window, indoors. Now to mount it permanently.
That’s because the FCC mandated a (then) unusual connector be used to make it difficult for people to connect high gain antennas to wifi gear. Unsurprisingly, it made very little difference once manufacturers got into gear.
When I was getting setup, I realized I accidentally bought an RP-SMA cable, so I ordered an RP-SMA to SMA adapter. Hooked it all up, thought the antenna was rubbish, went back to the beercantenna. Like two weeks later I realize the adapter I ordered was the inverse of what I needed. All it was doing was adding ANOTHER non connection in the signal path. So don’t feel too bad!
Connectors & adapters are a problem, because of their variety & because some are poor quality. I got frustrated due to dodgey/wrong adaptors when I purchased FA antenna.
Is the N-connector on the ant 50ohm or 75 ohm - did we ever get to the bottom of that?
I already have a couple of N-F adapters, is there a way of telling the ohm’age of those?
On the pic in the ad, it shows the ant mounted in a “collar” that then attaches to the mast with u-bolts…
I dont believe this is included - anyone got a good source for these? What are they known as, so I can search?
THX
EDIT - scrub that, I think it’s the mast itself that’s not included! (cheapskates… )
“Easy mounting to antenna mast that is 2cm to 5cm in diameter (not included)”
Just installed my FA antenna which I bought on amazon UK. Have located it above my roof line 15m above sea level with a 2m coax cable directly into receiver on Raspberry Pi running ADS-B Reciever (https://www.adsbreceiver.net/) and Piaware. I have noticed a "bit " of an improvement
