Check your antenna cable. Does the connector on receiver (ProStick) side have the required pin?
It’s quite easy to buy the wrong one with RP-SMA connector instead of SMA.
DIFFERENCE BETWEEN SMA AND RP-SMA
The SMA-male has center pin. The reverse SMA (RP-SMA) male does NOT have a center pin, it has a hole.
The SMA-female does not have center pin. The reverse SMA (RP-SMA) male also does not have a center pin, it has a hole. The center wire connection is open because of missing pin. A temporary workaround is to cut a short piece of center wire of coax and insert in hole of RP-SMA male. This piece of wire will act as the missing pin, and connection will be established.
There is another possibility as @wiedehopf has alresdy mentioned: a strong RF interference. If very strong, it can saturate front end of ProStick and make it deaf to signals from aircraft. The source of this RF interference may be either tv / fm / cell / mobile towers nearby, or some electrical / electronic appliace withi your home. HDMI cables are notorious in radiating RF interference.
Try to relocate your portable antenna and RPi to another room and see if that makes any difference.
To test, disconnect antenna from prostick, and insert a straightened paper clip in hole of SMA female of Prostick. Keep the straightened paper clip vertical. See photo below
The paper clip acts as antenna and is sufficient to receive at least few nearby plane.
ProStick + is plugged directly into the RPi and always has been. I just inserted the paperclip to be used as an antenna. I am unable to place it outside at the moment as it is rainy here today, but is it next to a big window. Previously I had tried the setup(with antenna I mentioned earlier) in several different rooms including out on the deck when is was nice out. Currently still no data coming through with the paperclip
I ran “sudo dmesg --ctime | grep voltage” but it does not produce any output. I am hoping that means there are no voltage issues.
Is there an easy way to determine if I am getting interference from nearby towers? I also thought the point of the ProStick Plus was its embedded filter to help with interference.
Thanks! I ran the scans. I ran one with the paperclip as an antenna and one with the antenna I have. They both look the same:
It looks like that through the entire spectrum. I understand there could be dense and less dense areas, but this through the entire spectrum…does that make any sense?
