Could I have the blacklisting page please?
let me try with my other power supply.
Just read my earlier post…
So I tried my official raspberry pi power supply with the raspberry pi. On boot, I saw on my dump1080 website that the aircraft were tracked for a bit then disappears. Sorry @wiedehopf, didn’t see your post, I think @richkaminski posted before i saw your post. I just added the blacklist, ive rebooted my pi again, waiting for results.
@wiedehopf, after doing the blacklist and rebooting my pi, MLAT no longer runs and i no longer see aircraft on startup.
Doing the RTL_SDR test:
rtl_test -t
Found 1 device(s):
0: , , SN:
Using device 0: Generic RTL2832U OEM
rtlsdr_write_reg failed with -1
Resetting device...
rtlsdr_write_reg failed with -4
rtlsdr_demod_write_reg failed with -4
rtlsdr_demod_read_reg failed with -4
I’m not sure how the blacklist would produce such problems. It just makes sure that the DVB-T drivers for the dongles are not loaded.
Anyway try the dongle on another computer. Then you will know for sure if the dongle is bad.
I only have another Raspberry Pi. Is there any software thats available to test it using a raspberry pi? What about for mac?
use rtl_test on the other raspberry pi
Ok. Let me install it, one second.
Hmmm there is something afoot. I pressed control C because nothing else showed up. rtl_test:
pi@RaspberryPi:~ $ rtl_test
Found 1 device(s):
0: Realtek, RTL2838UHIDIR, SN: 00000001
Detached kernel driver
[R82XX] PLL not locked!
Sampling at 2048000 S/s.
Info: This tool will continuously read from the device, and report if
samples get lost. If you observe no further output, everything is fine.
Reading samples in async mode...
^CSignal caught, exiting!
User cancel, exiting...
Samples per million lost (minimum): 0
Reattached kernel driver
rtl_adsb: (pressed control C pretty quickly because lots of lines of numbers show up)
pi@RaspberryPi:~ $ rtl_adsb
Found 1 device(s):
Tuner gain set to automatic.
Tuned to 1090000000 Hz.
Exact sample rate is: 2000000.052982 Hz
Sampling at 2000000 S/s.
*b90e77b69c5729f4fd31e1665395;
*ccb4cfd998feb29457fa5ec6f3b8;
*d47751a6b709ce2f4c6e61d88fb5;
*9bcc42738fee35f596e3d4e6f658;
*cf102e7a0000e242cf00030a4000;
*a8001a06fff37d303ffc569abe34;
*a8001a069e5a4c09215c2a746a01;
*8b0e62c529c6e12a5416c142fcab;
User cancel, exiting…
Nothing showing up means the dongle is working.
Maybe it’s the USB cable connecting the power supply to the RPi?
Ok heres what I did from the beginning of this post. 1. Used unofficial 3A 24AWG power supply. Getting errors on my Raspberry Pi 3B. Then, I changed the power supply for the official Raspberry Pi 2.5Amp 18AWG 5.1v power supply. Same errors. I plugged in my Raspberry Pi 3B+ with the 3Amp power supply, tried the rtl sdr test and succeeded. So it is NOT the power supply. Also it is not USB, its just a unremovable power supply with wire.
Maybe the 3B is running a bad kernel version. I seem to remember that there some problems with certain pis and certain kernels leading to USB problems.
Try a current raspbian or flightaware image or run rpi-update (at your own risk).
So you suggest just update and dist-upgrade?
No just run
sudo rpi-update
(Maybe you need to install it first)
Or download a current image.
Oh before you do any of that can you post your kernel version?
uname -a
So if it helps i know which version is bad
rpi-update gives tested kernel version. I could potentially mess up something giving even more problems.
It just updates to raspbian stretch and a current kernel. I believe the warning was meant for some very early stages of the 3B+ release or something.
Anyhow a dist-upgrade might also do the trick.
Current firmware with rpi-update would be better though.
Ok I did a dist-upgrade, the Raspberry Pi 3B is running the same kernel as the Raspberry Pi 3B+. Now, ive done sudo systemctl stop dump1090-mutability, sudo systemctl stop fr24feed. Next i tried rtl_adsb:
pi@raspberrypi:~ $ rtl_adsb
Found 1 device(s):
rtlsdr_demod_read_reg failed with -1
rtlsdr_demod_write_reg failed with -1
r82xx_write: i2c wr failed=-1 reg=05 len=1
WARNING: Failed to set tuner gain.
rtlsdr_demod_write_reg failed with -7
rtlsdr_demod_read_reg failed with -7
r82xx_write: i2c wr failed=-1 reg=17 len=1
r82xx_set_freq: failed=-1
WARNING: Failed to set center freq.
Sorry Only just now saw your edited post. So I cant get the bad kernel (or so called bad)
