Hey guys, this is my setup before and after to a semi-permanent install.
Raspberry Pi 3 with the FA filter and pro stick installed from the start. Initially I had to install the antenna on a fire escape pole which covered the back half of the antennas reception. Yesterday at 1830 I moved the antenna up the roof where it has pretty much a clear view and the tip of the antenna stands around seven feet of a three story apartment building.
Looking at my stats, the range increase is around 25-50% more with the antenna on the roof. I’m sure that the pro stick does help a great amount so I can imagine the reports/sightings would be lower than what I have now.
flightaware.com/adsb/stats/user/Solidjake
Temp install of the Raspberry:
i728.photobucket.com/albums/ww29 … opko2m.jpg
Temp antenna install on the fire escape:
i728.photobucket.com/albums/ww29 … yoeetw.jpg
Semi-permanent install on the roof:
i728.photobucket.com/albums/ww29 … zu5se5.jpg
i728.photobucket.com/albums/ww29 … jktdcc.jpg
